CAD Forums > CAD General
To model complex object
Lupo76:
Hi everyone,
I know AutoCAD and BricsCAD 3D regarding the modeling of 3D solid objects with flat surfaces (extrudes, Boolean operations, etc.)
Unfortunately I don't know where to start to model the seat of a chair that has an uneven shape (see attached file).
The result of the modeling should be a 3d solid and not a mesh.
Can you give me some indication or video tutorial on how to start?
Thanks in advance.
Lupo
CAB:
It is another level of CAD to do 3D but just takes time and patients & a good use of Z-snaps. :)I have done a few 3D items but am still learning. https://sketchfab.com/ab2draft/models
Lupo76:
--- Quote from: CAB on August 10, 2019, 08:06:49 AM ---It is another level of CAD to do 3D but just takes time and patients & a good use of Z-snaps. :)I have done a few 3D items but am still learning. https://sketchfab.com/ab2draft/models
--- End quote ---
Thank you for your answer.
I saw your models but probably they were made with sketchup that works with surfaces.
I need to get 3D Solids (ACIS).
Is there a way to create the file that I have attached in AutoCAD or BricsCAD?
What are the commands and / or techniques to achieve this result?
CAB:
The USCG, Grate & St Thomas were made using BricsCAD.The others were made using Chief Architect.
Looking at the chair, I would think a modeling software other that CAD would be more appropriate.I think it could be done in CAD but that is beyond may skill set.
ChrisCarlson:
You're already kind of half way there. You just need to convert the mesh into a solid. Check out the command convtosolid.
Unfortuantely, the program which outputted the mesh did a crummy job and I don't there is an easy way to really accomplish what you need quickly.
Navigation
[0] Message Index
[#] Next page
Go to full version
