Code Red > .NET
opening temporary a ribbon
(1/1)
arnaudalp:
Hi.
I'm a new user of this forum. I'm searching to create a ribbon who do the same action like Hatch command in the Autocad Ribbon.
I make a ribbon, when I click on my icone, my new ribbon is create. I choose a command with a new icone ( circle for exemple ) and when I finished my command, I want close this ribbon for find my first ribbon.
In an other time, i would like active a command and display a new ribbon during my command....
--- Code: ---namespace RibbonSample
public class Ribbon
[CommandMethod("MyRibbon")]
public void MyRibbon()
Autodesk.Windows.RibbonControl ribbonControl = Autodesk.Windows.ComponentManager.Ribbon;
RibbonTab Tab = new RibbonTab();
Tab.Title = "Autodesk .NET forum Ribbon Sample";
Tab.Id = "RibbonSample_TAB_ID";
Tab.IsContextualTab = false;
ribbonControl.Tabs.Add(Tab);
// create Ribbon panels
Autodesk.Windows.RibbonPanelSource panel1Panel = new RibbonPanelSource();
panel1Panel.Title = "Panel1";
RibbonPanel Panel1 = new RibbonPanel();
Panel1.Source = panel1Panel;
Tab.Panels.Add(Panel1);
RibbonButton pan1button1 = new RibbonButton();
pan1button1.Text = "Button1";
pan1button1.ShowText = true;
pan1button1.ShowImage = true;
pan1button1.Image = Images.getBitmap(Properties.Resources.Small);
pan1button1.LargeImage = Images.getBitmap(Properties.Resources.large);
pan1button1.Orientation = System.Windows.Controls.Orientation.Vertical;
pan1button1.Size = RibbonItemSize.Large;
panel1Panel.Items.Add(pan1button1);
Tab.IsActive = true;
pan1button1.CommandHandler = new RibbonCommandHandler();
pan1button1.CommandParameter = "Test ";
[CommandMethod("Test")]
public void MyRibbon2()
RibbonTab Tab1 = new RibbonTab();
Tab1.Title = "Autodesk test";
Tab1.Id = "RibbonSample_TAB_ID";
Tab1.IsContextualTab = false;
ribbonControl.Tabs.Add(Tab1);
Autodesk.Windows.RibbonPanelSource panelPanel = new RibbonPanelSource();
panelPanel.Title = "Panel test";
RibbonPanel Panel = new RibbonPanel();
Panel.Source = panelPanel;
Tab1.Panels.Add(Panel);
pan1button1.Text = "Button test";
pan1button1.Size = RibbonItemSize.Standard;
panelPanel.Items.Add(pan1button1);
Tab1.IsActive = true;
pan1button1.CommandParameter = "_Circle ";
public class RibbonCommandHandler : System.Windows.Input.ICommand
public RibbonTab Getstatus(RibbonTab tab)
return tab;
public bool CanExecute(object parameter)
return true;
public event EventHandler CanExecuteChanged;
public void Execute(object parameter)
Document doc = acadApp.DocumentManager.MdiActiveDocument;
RibbonCommandItem cmd = parameter as RibbonCommandItem;
doc.SendStringToExecute((string)cmd.CommandParameter, true, false, true);
public class Images
public static BitmapImage getBitmap(Bitmap image)
MemoryStream stream = new MemoryStream();
image.Save(stream, ImageFormat.Png);
BitmapImage bmp = new BitmapImage();
bmp.BeginInit();
bmp.StreamSource = stream;
bmp.EndInit();
return bmp;
--- End code ---
Navigation
[0] Message Index
Go to full version
