How to Add Double Quotes in A Message
MeasureUp:
Sorry I have not wrote codes for a long time.
Here is my question and below is a simplified case.
I'd like to show a message after user input:
--- Code: ---(setq UserInput (getstring "Enter Letters: "))
(strcat "Your Input is " ... UserInput ... ".")
--- End code ---
The message should be shown as below if the input was ABC.
--- Quote ---Your Input is "ABC".
--- End quote ---
Your helps are much appreciated.
kpblc:
--- Code - Auto/Visual Lisp: ---(strcat "Your Inout is \"" UserInput "\".")
Lee Mac:
FWIW, you can determine the required escape characters by evaluating (getstring) at the AutoCAD command-line and entering the string that you wish to display - getstring will then return the string with the appropriate escape characters inserted for correct representation in AutoLISP, e.g.:
--- Code: ---Command: (getstring t "\nEnter string: ")
Enter string: Your input is "ABC"
"Your input is \"ABC\""
--- End code ---
MeasureUp:
Thanks to kpblc & Lee.
And Lee, you are too smart as always. :laugh: It is a good idea.
My confusion is the resault I got.
--- Quote ---"Your input is \"ABC\"."
--- End quote ---
But when "princ" is added it shows correctly at command line.
--- Code: ---(princ (strcat "Your Input is \"" UserInput "\"."))
--- End code ---
--- Quote ---Your input is "ABC".
--- End quote ---
Lee Mac:
--- Quote from: MeasureUp on June 11, 2019, 07:18:23 PM ---My confusion is the resault I got.
--- End quote ---
--- End code ---
--- End quote ---
--- End quote ---
This is because ordinarily the double-quote character represents a string delimiter, signalling the start or end of a string literal. Therefore, in order to give this character an alternative meaning of 'display a literal double-quote' when evaluated by the AutoLISP interpreter, it is prefixed with the backslash escape character.
For more information & resources on this point, see my post here.
Navigation
[0] Message Index
[#] Next page
Go to full version
