CAD Forums > CAD General
Thoughts on Block Library
(1/1)
MSTG007:
What are your thoughts on managing / creating a block library? What is the best practice would you say?
Keep all blocks in (one) dwg.
Keep separate dwgs for each block.
The end result would be that the user would access the blocks via the tool palette.
what do you think?
MP:
--- Quote from: MSTG007 on May 13, 2019, 08:55:47 AM ---Keep separate dwgs for each block.
The end result would be that the user would access the blocks via self updating dialog(s).
--- End quote ---
this
dgorsman:
When dealing with multiple clients, there may be cases where some blocks need to be different but not others. When you have multiple blocks defined in a single file it makes managing a default/override arrangement difficult. I usually prefer individual source files and let the SFSP determine which block is inserted.
It's Alive!:
Both
kdub_nz:
It depends ...
Navigation
[0] Message Index
Go to full version
