Author Topic: Autocad 2020 - No new lisp  (Read 12234 times)
ribarm
  • Marko Ribar, architect
Re: Autocad 2020 - No new lisp
« Reply #30 on: June 24, 2021, 06:21:19 AM »
All I can say is that I corrected my function as much as possible... It took me some time to gather all UPPERCASES from LOWERCASES and create new string, but still something is weird going on :
Command: (lstrcase "POZORIŠTE" t)
"pozorðÓte"
Command: (lstrcase "АБВГДЂЕЖЗИЈКЛЉМНЊОПРСТЋУФХЦЧЏШ" t)
Command: (lstrcase "ЙЦУКЕНГШЩЗХҐФИВАПРОЛДЖЄЯЧСМІТЬБЮЇ" t)
And here is it - my newest version :
(defun lstrcase ( str arg / str1 str2 str3 str4 str5 str6 strn )
  (if (null arg)
    (setq strn (xstrcase str))
      (setq str1 (vl-string-translate " ABCDEFGHIJKLMNOPQRSTUVWXYZΜSÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖØÙÚÛÜÝÞŸĀĂĄĆĈĊČĎĐĒĔĖĘĚĜĞĠĢĤĦĨĪĬĮIIJĴĶ ĹĻĽĿŁŃŅŇʼŊŌŎŐŒŔŖŘŚŜŞŠŢŤŦŨŪŬŮŰŲŴŶŹŻŽSɃƂƄƇƋ ƑǶƘȽ ȠƠƢƤƧ  ƬƯƳƵƸ Ƽ ǷDŽLJNJǍǏǑǓǕǗǙǛƎǞǠǢǤǦǨǪǬǮJDZǴǸǺǼǾȀȂȄȆȈȊȌȎȐȒȔȖȘȚȜȞ ȢȤȦȨȪȬȮȰȲ      ȻⱾⱿɁɆɈɊɌɎⱯⱭⱰƁƆ ƉƊ Ə ƐꞫ   ƓꞬ Ɣ ꞍꞪ ƗƖꞮⱢꞭ  Ɯ ⱮƝ  Ɵ       Ɽ  Ʀ ꟅƩ   ꞱƮɄƱƲɅ     Ʒ         ꞲꞰ                 ͰͲͶϽϾϿΙΆΈΉΊΥΑΒΓΔΕΖΗΘΙΚΛΜΝΞΟΠΡΣΣΤΥΦΧΨΩΪΫΌΎΏΒΘΦΠϏϘϚϜϞϠϢϤϦϨϪϬϮΚΡϹͿΕϷϺ АБВГДЕЖЗИЙКЛМНОПРСТУФХЦЧШЩЪЫЬЭЮЯЀЁЂЃЄЅІЇЈЉЊЋЌЍЎЏѠѢѤѦѨѪѬѮѰѲѴѶѸѺѼѾҀҊҌҎҐҒҔҖҘҚҜҞҠҢҤҦҨҪҬҮҰҲҴҶҸҺҼҾӁӃӅӇӉӋӍӀӐӒӔӖӘӚӜӞӠӢӤӦӨӪӬӮӰӲӴӶӸӺӼӾԀԂԄԆԈԊԌԎԐԒԔԖԘԚԜԞԠԢԤԦԨԪԬԮ " " abcdefghijklmnopqrstuvwxyzµßàáâãäåæçèéêëìíîïðñòóôõöøùúûüýþÿāăąćĉċčďđēĕėęěĝğġģĥħĩīĭįıijĵķĸĺļľŀłńņňʼnŋōŏőœŕŗřśŝşšţťŧũūŭůűųŵŷźżžſƀƃƅƈƌƍƒƕƙƚƛƞơƣƥƨƪƫƭưƴƶƹƺƽƾƿdžljnjǎǐǒǔǖǘǚǜǝǟǡǣǥǧǩǫǭǯǰdzǵǹǻǽǿȁȃȅȇȉȋȍȏȑȓȕȗșțȝȟȡȣȥȧȩȫȭȯȱȳȴȵȶȷȸȹȼȿɀɂɇɉɋɍɏɐɑɒɓɔɕɖɗɘəɚɛɜɝɞɟɠɡɢɣɤɥɦɧɨɩɪɫɬɭɮɯɰɱɲɳɴɵɶɷɸɹɺɻɼɽɾɿʀʁʂʃʄʅʆʇʈʉʊʋʌʍʎʏʐʑʒʓʕʖʗʘʙʚʛʜʝʞʟʠʡʢʣʤʥʦʧʨʩʪʫʬʭʮʯͱͳͷͻͼͽΐάέήίΰαβγδεζηθικλμνξοπρςστυφχψωϊϋόύώϐϑϕϖϗϙϛϝϟϡϣϥϧϩϫϭϯϰϱϲϳϵϸϻϼабвгдежзийклмнопрстуфхцчшщъыьэюяѐёђѓєѕіїјљњћќѝўџѡѣѥѧѩѫѭѯѱѳѵѷѹѻѽѿҁҋҍҏґғҕҗҙқҝҟҡңҥҧҩҫҭүұҳҵҷҹһҽҿӂӄӆӈӊӌӎӏӑӓӕӗәӛӝӟӡӣӥӧөӫӭӯӱӳӵӷӹӻӽӿԁԃԅԇԉԋԍԏԑԓԕԗԙԛԝԟԡԣԥԧԩԫԭԯՠ" str))
      (setq str2 (vl-string-translate "ԱԲԳԴԵԶԷԸԹԺԻԼԽԾԿՀՁՂՃՄՅՆՇՈՉՊՋՌՍՎՏՐՑՒՓՔՕՖԵ ᲐᲑᲒᲓᲔᲕᲖᲗᲘᲙᲚᲛᲜᲝᲞᲟᲠᲡᲢᲣᲤᲥᲦᲧᲨᲩᲪᲫᲬᲭᲮᲯᲰᲱᲲᲳᲴᲵᲶᲷᲸᲹᲺᲽᲾᲿᏰᏱᏲᏳᏴᏵВДОСТТЪѢꙊ                                                         Ᵹ   Ᵽ                Ᶎ            ḀḂḄḆḈḊḌḎḐḒḔḖḘḚḜḞḠḢḤḦḨḪḬḮḰḲḴḶḸḺḼḾṀṂṄṆṈṊṌṎṐṒṔṖṘṚṜṞṠṢṤṦṨṪṬṮṰṲṴṶṸṺṼṾẀẂẄẆẈẊẌẎẐẒẔHTWYAṠ   ẠẢẤẦẨẪẬẮẰẲẴẶẸẺẼẾỀỂỄỆỈỊỌỎỐỒỔỖỘỚỜỞỠỢỤỦỨỪỬỮỰỲỴỶỸỺỼỾἈἉἊἋἌἍἎἏἘἙἚἛἜἝἨἩἪἫἬἭἮἯἸἹἺἻἼἽἾἿὈὉὊὋὌὍΥὙΥὛΥὝΥὟὨὩὪὫὬὭὮὯᾺΆῈΈῊΉῚΊῸΌῪΎῺΏἈἉἊἋἌἍἎἏἨἩἪἫἬἭἮἯὨὩὪὫὬὭὮὯᾸᾹᾺΑΆΑΑΙῊΗΉΗΗῘῙΙΙΙΙῨῩΥΥΡῬΥΥῺΩΏΩΩ             ℲↃⰀⰁⰂⰃⰄⰅⰆⰇⰈⰉⰊⰋⰌⰍⰎⰏⰐⰑⰒⰓⰔⰕⰖⰗⰘⰙⰚⰛⰜⰝⰞⰟⰠⰡⰢⰣⰤⰥⰦⰧⰨⰩⰪⰫⰬⰭⰮⱠȺȾⱧⱩⱫ Ⱳ Ⱶ     " "աբգդեզէըթժիլխծկհձղճմյնշոչպջռսվտրցւփքօֆևֈაბგდევზთიკლმნოპჟრსტუფქღყშჩცძწჭხჯჰჱჲჳჴჵჶჷჸჹჺჽჾჿᏸᏹᏺᏻᏼᏽᲀᲁᲂᲃᲄᲅᲆᲇᲈᴀᴁᴂᴃᴄᴅᴆᴇᴈᴉᴊᴋᴌᴍᴎᴏᴐᴑᴒᴓᴔᴕᴖᴗᴘᴙᴚᴛᴜᴝᴞᴟᴠᴡᴢᴣᴤᴥᴦᴧᴨᴩᴪᴫᵫᵬᵭᵮᵯᵰᵱᵲᵳᵴᵵᵶᵷᵹᵺᵻᵼᵽᵾᵿᶀᶁᶂᶃᶄᶅᶆᶇᶈᶉᶊᶋᶌᶍᶎᶏᶐᶑᶒᶓᶔᶕᶖᶗᶘᶙᶚḁḃḅḇḉḋḍḏḑḓḕḗḙḛḝḟḡḣḥḧḩḫḭḯḱḳḵḷḹḻḽḿṁṃṅṇṉṋṍṏṑṓṕṗṙṛṝṟṡṣṥṧṩṫṭṯṱṳṵṷṹṻṽṿẁẃẅẇẉẋẍẏẑẓẕẖẗẘẙẚẛẜẝẟạảấầẩẫậắằẳẵặẹẻẽếềểễệỉịọỏốồổỗộớờởỡợụủứừửữựỳỵỷỹỻỽỿἀἁἂἃἄἅἆἇἐἑἒἓἔἕἠἡἢἣἤἥἦἧἰἱἲἳἴἵἶἷὀὁὂὃὄὅὐὑὒὓὔὕὖὗὠὡὢὣὤὥὦὧὰάὲέὴήὶίὸόὺύὼώᾀᾁᾂᾃᾄᾅᾆᾇᾐᾑᾒᾓᾔᾕᾖᾗᾠᾡᾢᾣᾤᾥᾦᾧᾰᾱᾲᾳᾴᾶᾷιῂῃῄῆῇῐῑῒΐῖῗῠῡῢΰῤῥῦῧῲῳῴῶῷℊℎℏℓℯℴℹℼℽⅆⅇⅈⅉⅎↄⰰⰱⰲⰳⰴⰵⰶⰷⰸⰹⰺⰻⰼⰽⰾⰿⱀⱁⱂⱃⱄⱅⱆⱇⱈⱉⱊⱋⱌⱍⱎⱏⱐⱑⱒⱓⱔⱕⱖⱗⱘⱙⱚⱛⱜⱝⱞⱡⱥⱦⱨⱪⱬⱱⱳⱴⱶⱷⱸⱹⱺⱻ" str1))
      (setq str3 (vl-string-translate "ⲀⲂⲄⲆⲈⲊⲌⲎⲐⲒⲔⲖⲘⲚⲜⲞⲠⲢⲤⲦⲨⲪⲬⲮⲰⲲⲴⲶⲸⲺⲼⲾⳀⳂⳄⳆⳈⳊⳌⳎⳐⳒⳔⳖⳘⳚⳜⳞⳠⳢ ⳫⳭⳲႠႡႢႣႤႥႦႧႨႩႪႫႬႭႮႯႰႱႲႳႴႵႶႷႸႹႺႻႼႽႾႿჀჁჂჃჄჅჇჍꙀꙂꙄꙆꙈꙊꙌꙎꙐꙒꙔꙖꙘꙚꙜꙞꙠꙢꙤꙦꙨꙪꙬꚀꚂꚄꚆꚈꚊꚌꚎꚐꚒꚔꚖꚘꚚꜢꜤꜦꜨꜪꜬꜮ  ꜲꜴꜶꜸꜺꜼꜾꝀꝂꝄꝆꝈꝊꝌꝎꝐꝒꝔꝖꝘꝚꝜꝞꝠꝢꝤꝦꝨꝪꝬꝮ        ꝹꝻꝾꞀꞂꞄꞆꞋ ꞐꞒꟄ ꞖꞘꞚꞜꞞꞠꞢꞤꞦꞨ ꞴꞶꞸꞺꞼꞾꟂꟇꟉꟵ                                    Ꭓ                ᎠᎡᎢᎣᎤᎥᎦᎧᎨᎩᎪᎫᎬᎭᎮᎯᎰᎱᎲᎳᎴᎵᎶᎷᎸᎹᎺᎻᎼᎽᎾᎿᏀᏁᏂᏃᏄᏅᏆᏇᏈᏉᏊᏋᏌᏍᏎᏏᏐᏑᏒᏓᏔᏕᏖᏗᏘᏙᏚᏛᏜᏝᏞᏟᏠᏡᏢᏣᏤᏥᏦᏧᏨᏩᏪᏫᏬᏭᏮᏯFFFFFFSՄՄՄՎՄABCDEFGHIJKLMNOPQRSTUVWXYZ𐐀𐐁𐐂𐐃𐐄𐐅𐐆𐐇𐐈𐐉𐐊𐐋𐐌𐐍𐐎𐐏𐐐𐐑𐐒𐐓𐐔𐐕𐐖𐐗𐐘𐐙𐐚𐐛𐐜𐐝𐐞𐐟𐐠𐐡𐐢𐐣𐐤𐐥𐐦𐐧𐒰𐒱𐒲𐒳𐒴𐒵𐒶𐒷𐒸𐒹𐒺𐒻𐒼𐒽𐒾𐒿𐓀𐓁𐓂𐓃𐓄𐓅𐓆𐓇𐓈𐓉𐓊𐓋𐓌𐓍𐓎𐓏𐓐𐓑𐓒𐓓" "ⲁⲃⲅⲇⲉⲋⲍⲏⲑⲓⲕⲗⲙⲛⲝⲟⲡⲣⲥⲧⲩⲫⲭⲯⲱⲳⲵⲷⲹⲻⲽⲿⳁⳃⳅⳇⳉⳋⳍⳏⳑⳓⳕⳗⳙⳛⳝⳟⳡⳣⳤⳬⳮⳳⴀⴁⴂⴃⴄⴅⴆⴇⴈⴉⴊⴋⴌⴍⴎⴏⴐⴑⴒⴓⴔⴕⴖⴗⴘⴙⴚⴛⴜⴝⴞⴟⴠⴡⴢⴣⴤⴥⴧⴭꙁꙃꙅꙇꙉꙋꙍꙏꙑꙓꙕꙗꙙꙛꙝꙟꙡꙣꙥꙧꙩꙫꙭꚁꚃꚅꚇꚉꚋꚍꚏꚑꚓꚕꚗꚙꚛꜣꜥꜧꜩꜫꜭꜯꜰꜱꜳꜵꜷꜹꜻꜽꜿꝁꝃꝅꝇꝉꝋꝍꝏꝑꝓꝕꝗꝙꝛꝝꝟꝡꝣꝥꝧꝩꝫꝭꝯꝱꝲꝳꝴꝵꝶꝷꝸꝺꝼꝿꞁꞃꞅꞇꞌꞎꞑꞓꞔꞕꞗꞙꞛꞝꞟꞡꞣꞥꞧꞩꞯꞵꞷꞹꞻꞽꞿꟃꟈꟊꟶꟺꬰꬱꬲꬳꬴꬵꬶꬷꬸꬹꬺꬻꬼꬽꬾꬿꭀꭁꭂꭃꭄꭅꭆꭇꭈꭉꭊꭋꭌꭍꭎꭏꭐꭑꭒꭓꭔꭕꭖꭗꭘꭙꭚꭠꭡꭢꭣꭤꭥꭦꭧꭨꭰꭱꭲꭳꭴꭵꭶꭷꭸꭹꭺꭻꭼꭽꭾꭿꮀꮁꮂꮃꮄꮅꮆꮇꮈꮉꮊꮋꮌꮍꮎꮏꮐꮑꮒꮓꮔꮕꮖꮗꮘꮙꮚꮛꮜꮝꮞꮟꮠꮡꮢꮣꮤꮥꮦꮧꮨꮩꮪꮫꮬꮭꮮꮯꮰꮱꮲꮳꮴꮵꮶꮷꮸꮹꮺꮻꮼꮽꮾꮿfffiflffifflſtstﬓﬔﬕﬖﬗabcdefghijklmnopqrstuvwxyz𐐨𐐩𐐪𐐫𐐬𐐭𐐮𐐯𐐰𐐱𐐲𐐳𐐴𐐵𐐶𐐷𐐸𐐹𐐺𐐻𐐼𐐽𐐾𐐿𐑀𐑁𐑂𐑃𐑄𐑅𐑆𐑇𐑈𐑉𐑊𐑋𐑌𐑍𐑎𐑏𐓘𐓙𐓚𐓛𐓜𐓝𐓞𐓟𐓠𐓡𐓢𐓣𐓤𐓥𐓦𐓧𐓨𐓩𐓪𐓫𐓬𐓭𐓮𐓯𐓰𐓱𐓲𐓳𐓴𐓵𐓶𐓷𐓸𐓹𐓺𐓻" str2))
      (setq str4 (vl-string-translate "𐲀𐲁𐲂𐲃𐲄𐲅𐲆𐲇𐲈𐲉𐲊𐲋𐲌𐲍𐲎𐲏𐲐𐲑𐲒𐲓𐲔𐲕𐲖𐲗𐲘𐲙𐲚𐲛𐲜𐲝𐲞𐲟𐲠𐲡𐲢𐲣𐲤𐲥𐲦𐲧𐲨𐲩𐲪𐲫𐲬𐲭𐲮𐲯𐲰𐲱𐲲𑢠𑢡𑢢𑢣𑢤𑢥𑢦𑢧𑢨𑢩𑢪𑢫𑢬𑢭𑢮𑢯𑢰𑢱𑢲𑢳𑢴𑢵𑢶𑢷𑢸𑢹𑢺𑢻𑢼𑢽𑢾𑢿𖹀𖹁𖹂𖹃𖹄𖹅𖹆𖹇𖹈𖹉𖹊𖹋𖹌𖹍𖹎𖹏𖹐𖹑𖹒𖹓𖹔𖹕𖹖𖹗𖹘𖹙𖹚𖹛𖹜𖹝𖹞𖹟" "𐳀𐳁𐳂𐳃𐳄𐳅𐳆𐳇𐳈𐳉𐳊𐳋𐳌𐳍𐳎𐳏𐳐𐳑𐳒𐳓𐳔𐳕𐳖𐳗𐳘𐳙𐳚𐳛𐳜𐳝𐳞𐳟𐳠𐳡𐳢𐳣𐳤𐳥𐳦𐳧𐳨𐳩𐳪𐳫𐳬𐳭𐳮𐳯𐳰𐳱𐳲𑣀𑣁𑣂𑣃𑣄𑣅𑣆𑣇𑣈𑣉𑣊𑣋𑣌𑣍𑣎𑣏𑣐𑣑𑣒𑣓𑣔𑣕𑣖𑣗𑣘𑣙𑣚𑣛𑣜𑣝𑣞𑣟𖹠𖹡𖹢𖹣𖹤𖹥𖹦𖹧𖹨𖹩𖹪𖹫𖹬𖹭𖹮𖹯𖹰𖹱𖹲𖹳𖹴𖹵𖹶𖹷𖹸𖹹𖹺𖹻𖹼𖹽𖹾𖹿" str3))
      (setq str5 (vl-string-translate "        " "𝐚𝐛𝐜𝐝𝐞𝐟𝐠𝐡𝐢𝐣𝐤𝐥𝐦𝐧𝐨𝐩𝐪𝐫𝐬𝐭𝐮𝐯𝐰𝐱𝐲𝐳𝑎𝑏𝑐𝑑𝑒𝑓𝑔𝑖𝑗𝑘𝑙𝑚𝑛𝑜𝑝𝑞𝑟𝑠𝑡𝑢𝑣𝑤𝑥𝑦𝑧𝒂𝒃𝒄𝒅𝒆𝒇𝒈𝒉𝒊𝒋𝒌𝒍𝒎𝒏𝒐𝒑𝒒𝒓𝒔𝒕𝒖𝒗𝒘𝒙𝒚𝒛𝒶𝒷𝒸𝒹𝒻𝒽𝒾𝒿𝓀𝓁𝓂𝓃𝓅𝓆𝓇𝓈𝓉𝓊𝓋𝓌𝓍𝓎𝓏𝓪𝓫𝓬𝓭𝓮𝓯𝓰𝓱𝓲𝓳𝓴𝓵𝓶𝓷𝓸𝓹𝓺𝓻𝓼𝓽𝓾𝓿𝔀𝔁𝔂𝔃𝔞𝔟𝔠𝔡𝔢𝔣𝔤𝔥𝔦𝔧𝔨𝔩𝔪𝔫𝔬𝔭𝔮𝔯𝔰𝔱𝔲𝔳𝔴𝔵𝔶𝔷𝕒𝕓𝕔𝕕𝕖𝕗𝕘𝕙𝕚𝕛𝕜𝕝𝕞𝕟𝕠𝕡𝕢𝕣𝕤𝕥𝕦𝕧𝕨𝕩𝕪𝕫𝖆𝖇𝖈𝖉𝖊𝖋𝖌𝖍𝖎𝖏𝖐𝖑𝖒𝖓𝖔𝖕𝖖𝖗𝖘𝖙𝖚𝖛𝖜𝖝𝖞𝖟𝖺𝖻𝖼𝖽𝖾𝖿𝗀𝗁𝗂𝗃𝗄𝗅𝗆𝗇𝗈𝗉𝗊𝗋𝗌𝗍𝗎𝗏𝗐𝗑𝗒𝗓𝗮𝗯𝗰𝗱𝗲𝗳𝗴𝗵𝗶𝗷𝗸𝗹𝗺𝗻𝗼𝗽𝗾𝗿𝘀𝘁𝘂𝘃𝘄𝘅𝘆𝘇𝘢𝘣𝘤𝘥𝘦𝘧𝘨𝘩𝘪𝘫𝘬𝘭𝘮𝘯𝘰𝘱𝘲𝘳𝘴𝘵𝘶𝘷𝘸𝘹𝘺𝘻𝙖𝙗𝙘𝙙𝙚𝙛𝙜𝙝𝙞𝙟𝙠𝙡𝙢𝙣𝙤𝙥𝙦𝙧𝙨𝙩𝙪𝙫𝙬𝙭𝙮𝙯𝚊𝚋𝚌𝚍𝚎𝚏𝚐𝚑𝚒𝚓𝚔𝚕𝚖𝚗𝚘𝚙𝚚𝚛𝚜𝚝𝚞𝚟𝚠𝚡𝚢𝚣𝚤𝚥𝛂𝛃𝛄𝛅𝛆𝛇𝛈𝛉𝛊𝛋𝛌𝛍𝛎𝛏𝛐𝛑𝛒𝛓𝛔𝛕𝛖𝛗𝛘𝛙𝛚𝛜𝛝𝛞𝛟𝛠𝛡𝛼𝛽𝛾𝛿𝜀𝜁𝜂𝜃𝜄𝜅𝜆𝜇𝜈𝜉𝜊𝜋𝜌𝜍𝜎𝜏𝜐𝜑𝜒𝜓𝜔𝜖𝜗𝜘𝜙𝜚𝜛𝜶𝜷𝜸𝜹𝜺𝜻𝜼𝜽𝜾𝜿𝝀𝝁𝝂𝝃𝝄𝝅𝝆𝝇𝝈𝝉𝝊𝝋𝝌𝝍𝝎𝝐𝝑𝝒𝝓𝝔𝝕𝝰𝝱𝝲𝝳𝝴𝝵𝝶𝝷𝝸𝝹𝝺𝝻𝝼𝝽𝝾𝝿𝞀𝞁𝞂𝞃𝞄𝞅𝞆𝞇𝞈𝞊𝞋𝞌𝞍𝞎𝞏𝞪𝞫𝞬𝞭𝞮𝞯𝞰𝞱𝞲𝞳𝞴𝞵𝞶𝞷𝞸𝞹𝞺𝞻𝞼𝞽𝞾𝞿𝟀𝟁𝟂𝟄𝟅𝟆𝟇𝟈𝟉𝟋" str4))
      (setq str6 (vl-string-translate "𞤀𞤁𞤂𞤃𞤄𞤅𞤆𞤇𞤈𞤉𞤊𞤋𞤌𞤍𞤎𞤏𞤐𞤑𞤒𞤓𞤔𞤕𞤖𞤗𞤘𞤙𞤚𞤛𞤜𞤝𞤞𞤟𞤠𞤡" "𞤢𞤣𞤤𞤥𞤦𞤧𞤨𞤩𞤪𞤫𞤬𞤭𞤮𞤯𞤰𞤱𞤲𞤳𞤴𞤵𞤶𞤷𞤸𞤹𞤺𞤻𞤼𞤽𞤾𞤿𞥀𞥁𞥂𞥃" str5))
      (setq strn str6)
  strn
Regards, M.R.
M.R. on Youtube
ribarm
« Reply #31 on: June 24, 2021, 08:51:19 AM »
When you exclude letters that don't have matching uppercase-lowercase pair, function truncates... So it actually should look something like this :
(defun lstrcase ( str arg / str1 str2 str3 str4 strn )
  (if (null arg)
      (setq str1 (vl-string-translate "ABCDEFGHIJKLMNOPQRSTUVWXYZΜSÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖØÙÚÛÜÝÞŸĀĂĄĆĈĊČĎĐĒĔĖĘĚĜĞĠĢĤĦĨĪĬĮIIJĴĶĹĻĽĿŁŃŅŇʼŊŌŎŐŒŔŖŘŚŜŞŠŢŤŦŨŪŬŮŰŲŴŶŹŻŽSɃƂƄƇƋƑǶƘȽȠƠƢƤƧƬƯƳƵƸƼǷDŽLJNJǍǏǑǓǕǗǙǛƎǞǠǢǤǦǨǪǬǮJDZǴǸǺǼǾȀȂȄȆȈȊȌȎȐȒȔȖȘȚȜȞȢȤȦȨȪȬȮȰȲȻⱾⱿɁɆɈɊɌɎⱯⱭⱰƁƆƉƊƏƐƓƔƗƖⱢƜⱮƝƟⱤƦƩƮɄƱƲɅƷͰͲͶϽϾϿΙΆΈΉΊΥΑΒΓΔΕΖΗΘΙΚΛΜΝΞΟΠΡΣΣΤΥΦΧΨΩΪΫΌΎΏΒΘΦΠϏϘϚϜϞϠϢϤϦϨϪϬϮΚΡϹͿΕϷϺАБВГДЕЖЗИЙКЛМНОПРСТУФХЦЧШЩЪЫЬЭЮЯЀЁЂЃЄЅІЇЈЉЊЋЌЍЎЏѠѢѤѦѨѪѬѮѰѲѴѶѸѺѼѾҀҊҌҎҐҒҔҖҘҚҜҞҠҢҤҦҨҪҬҮҰҲҴҶҸҺҼҾӁӃӅӇӉӋӍӀӐӒӔӖӘӚӜӞӠӢӤӦӨӪӬӮӰӲӴӶӸӺӼӾԀԂԄԆԈԊԌԎԐԒԔԖԘԚԜԞԠԢԤԦԨԪԬԮ" "abcdefghijklmnopqrstuvwxyzµßàáâãäåæçèéêëìíîïðñòóôõöøùúûüýþÿāăąćĉċčďđēĕėęěĝğġģĥħĩīĭįıijĵķĺļľŀłńņňʼnŋōŏőœŕŗřśŝşšţťŧũūŭůűųŵŷźżžſƀƃƅƈƌƒƕƙƚƞơƣƥƨƭưƴƶƹƽƿdžljnjǎǐǒǔǖǘǚǜǝǟǡǣǥǧǩǫǭǯǰdzǵǹǻǽǿȁȃȅȇȉȋȍȏȑȓȕȗșțȝȟȣȥȧȩȫȭȯȱȳȼȿɀɂɇɉɋɍɏɐɑɒɓɔɖɗəɛɠɣɨɩɫɯɱɲɵɽʀʃʈʉʊʋʌʒͱͳͷͻͼͽΐάέήίΰαβγδεζηθικλμνξοπρςστυφχψωϊϋόύώϐϑϕϖϗϙϛϝϟϡϣϥϧϩϫϭϯϰϱϲϳϵϸϻабвгдежзийклмнопрстуфхцчшщъыьэюяѐёђѓєѕіїјљњћќѝўџѡѣѥѧѩѫѭѯѱѳѵѷѹѻѽѿҁҋҍҏґғҕҗҙқҝҟҡңҥҧҩҫҭүұҳҵҷҹһҽҿӂӄӆӈӊӌӎӏӑӓӕӗәӛӝӟӡӣӥӧөӫӭӯӱӳӵӷӹӻӽӿԁԃԅԇԉԋԍԏԑԓԕԗԙԛԝԟԡԣԥԧԩԫԭԯ" str))
      (setq str2 (vl-string-translate "ԱԲԳԴԵԶԷԸԹԺԻԼԽԾԿՀՁՂՃՄՅՆՇՈՉՊՋՌՍՎՏՐՑՒՓՔՕՖԵᲐᲑᲒᲓᲔᲕᲖᲗᲘᲙᲚᲛᲜᲝᲞᲟᲠᲡᲢᲣᲤᲥᲦᲧᲨᲩᲪᲫᲬᲭᲮᲯᲰᲱᲲᲳᲴᲵᲶᲷᲸᲹᲺᲽᲾᲿᏰᏱᏲᏳᏴᏵВДОСТТЪѢꙊⱣḀḂḄḆḈḊḌḎḐḒḔḖḘḚḜḞḠḢḤḦḨḪḬḮḰḲḴḶḸḺḼḾṀṂṄṆṈṊṌṎṐṒṔṖṘṚṜṞṠṢṤṦṨṪṬṮṰṲṴṶṸṺṼṾẀẂẄẆẈẊẌẎẐẒẔHTWYAṠẠẢẤẦẨẪẬẮẰẲẴẶẸẺẼẾỀỂỄỆỈỊỌỎỐỒỔỖỘỚỜỞỠỢỤỦỨỪỬỮỰỲỴỶỸỺỼỾἈἉἊἋἌἍἎἏἘἙἚἛἜἝἨἩἪἫἬἭἮἯἸἹἺἻἼἽἾἿὈὉὊὋὌὍΥὙΥὛΥὝΥὟὨὩὪὫὬὭὮὯᾺΆῈΈῊΉῚΊῸΌῪΎῺΏἈἉἊἋἌἍἎἏἨἩἪἫἬἭἮἯὨὩὪὫὬὭὮὯᾸᾹᾺΑΆΑΑΙῊΗΉΗΗῘῙΙΙΙΙῨῩΥΥΡῬΥΥῺΩΏΩΩℲↃⰀⰁⰂⰃⰄⰅⰆⰇⰈⰉⰊⰋⰌⰍⰎⰏⰐⰑⰒⰓⰔⰕⰖⰗⰘⰙⰚⰛⰜⰝⰞⰟⰠⰡⰢⰣⰤⰥⰦⰧⰨⰩⰪⰫⰬⰭⰮⱠȺȾⱧⱩⱫⱲⱵ" "աբգդեզէըթժիլխծկհձղճմյնշոչպջռսվտրցւփքօֆևაბგდევზთიკლმნოპჟრსტუფქღყშჩცძწჭხჯჰჱჲჳჴჵჶჷჸჹჺჽჾჿᏸᏹᏺᏻᏼᏽᲀᲁᲂᲃᲄᲅᲆᲇᲈᵽḁḃḅḇḉḋḍḏḑḓḕḗḙḛḝḟḡḣḥḧḩḫḭḯḱḳḵḷḹḻḽḿṁṃṅṇṉṋṍṏṑṓṕṗṙṛṝṟṡṣṥṧṩṫṭṯṱṳṵṷṹṻṽṿẁẃẅẇẉẋẍẏẑẓẕẖẗẘẙẚẛạảấầẩẫậắằẳẵặẹẻẽếềểễệỉịọỏốồổỗộớờởỡợụủứừửữựỳỵỷỹỻỽỿἀἁἂἃἄἅἆἇἐἑἒἓἔἕἠἡἢἣἤἥἦἧἰἱἲἳἴἵἶἷὀὁὂὃὄὅὐὑὒὓὔὕὖὗὠὡὢὣὤὥὦὧὰάὲέὴήὶίὸόὺύὼώᾀᾁᾂᾃᾄᾅᾆᾇᾐᾑᾒᾓᾔᾕᾖᾗᾠᾡᾢᾣᾤᾥᾦᾧᾰᾱᾲᾳᾴᾶᾷιῂῃῄῆῇῐῑῒΐῖῗῠῡῢΰῤῥῦῧῲῳῴῶῷⅎↄⰰⰱⰲⰳⰴⰵⰶⰷⰸⰹⰺⰻⰼⰽⰾⰿⱀⱁⱂⱃⱄⱅⱆⱇⱈⱉⱊⱋⱌⱍⱎⱏⱐⱑⱒⱓⱔⱕⱖⱗⱘⱙⱚⱛⱜⱝⱞⱡⱥⱦⱨⱪⱬⱳⱶ" str1))
      (setq str3 (vl-string-translate "ⳫⳭⳲႠႡႢႣႤႥႦႧႨႩႪႫႬႭႮႯႰႱႲႳႴႵႶႷႸႹႺႻႼႽႾႿჀჁჂჃჄჅჇჍꙀꙂꙄꙆꙈꙊꙌꙎꙐꙒꙔꙖꙘꙚꙜꙞꙠꙢꙤꙦꙨꙪꞋᎠᎡᎢᎣᎤᎥᎦᎧᎨᎩᎪᎫᎬᎭᎮᎯᎰᎱᎲᎳᎴᎵᎶᎷᎸᎹᎺᎻᎼᎽᎾᎿᏀᏁᏂᏃᏄᏅᏆᏇᏈᏉᏊᏋᏌᏍᏎᏏᏐᏑᏒᏓᏔᏕᏖᏗᏘᏙᏚᏛᏜᏝᏞᏟᏠᏡᏢᏣᏤᏥᏦᏧᏨᏩᏪᏫᏬᏭᏮᏯFFFFFFSՄՄՄՎՄABCDEFGHIJKLMNOPQRSTUVWXYZ𐐀𐐁𐐂𐐃𐐄𐐅𐐆𐐇𐐈𐐉𐐊𐐋𐐌𐐍𐐎𐐏𐐐𐐑𐐒𐐓𐐔𐐕𐐖𐐗𐐘𐐙𐐚𐐛𐐜𐐝𐐞𐐟𐐠𐐡𐐢𐐣𐐤𐐥𐐦𐐧𐒰𐒱𐒲𐒳𐒴𐒵𐒶𐒷𐒸𐒹𐒺𐒻𐒼𐒽𐒾𐒿𐓀𐓁𐓂𐓃𐓄𐓅𐓆𐓇𐓈𐓉𐓊𐓋𐓌𐓍𐓎𐓏𐓐𐓑𐓒𐓓" "ⳬⳮⳳⴀⴁⴂⴃⴄⴅⴆⴇⴈⴉⴊⴋⴌⴍⴎⴏⴐⴑⴒⴓⴔⴕⴖⴗⴘⴙⴚⴛⴜⴝⴞⴟⴠⴡⴢⴣⴤⴥⴧⴭꙁꙃꙅꙇꙉꙋꙍꙏꙑꙓꙕꙗꙙꙛꙝꙟꙡꙣꙥꙧꙩꙫꞌꭰꭱꭲꭳꭴꭵꭶꭷꭸꭹꭺꭻꭼꭽꭾꭿꮀꮁꮂꮃꮄꮅꮆꮇꮈꮉꮊꮋꮌꮍꮎꮏꮐꮑꮒꮓꮔꮕꮖꮗꮘꮙꮚꮛꮜꮝꮞꮟꮠꮡꮢꮣꮤꮥꮦꮧꮨꮩꮪꮫꮬꮭꮮꮯꮰꮱꮲꮳꮴꮵꮶꮷꮸꮹꮺꮻꮼꮽꮾꮿfffiflffifflſtstﬓﬔﬕﬖﬗabcdefghijklmnopqrstuvwxyz𐐨𐐩𐐪𐐫𐐬𐐭𐐮𐐯𐐰𐐱𐐲𐐳𐐴𐐵𐐶𐐷𐐸𐐹𐐺𐐻𐐼𐐽𐐾𐐿𐑀𐑁𐑂𐑃𐑄𐑅𐑆𐑇𐑈𐑉𐑊𐑋𐑌𐑍𐑎𐑏𐓘𐓙𐓚𐓛𐓜𐓝𐓞𐓟𐓠𐓡𐓢𐓣𐓤𐓥𐓦𐓧𐓨𐓩𐓪𐓫𐓬𐓭𐓮𐓯𐓰𐓱𐓲𐓳𐓴𐓵𐓶𐓷𐓸𐓹𐓺𐓻" str2))
      (setq str4 (vl-string-translate "𞤀𞤁𞤂𞤃𞤄𞤅𞤆𞤇𞤈𞤉𞤊𞤋𞤌𞤍𞤎𞤏𞤐𞤑𞤒𞤓𞤔𞤕𞤖𞤗𞤘𞤙𞤚𞤛𞤜𞤝𞤞𞤟𞤠𞤡" "𞤢𞤣𞤤𞤥𞤦𞤧𞤨𞤩𞤪𞤫𞤬𞤭𞤮𞤯𞤰𞤱𞤲𞤳𞤴𞤵𞤶𞤷𞤸𞤹𞤺𞤻𞤼𞤽𞤾𞤿𞥀𞥁𞥂𞥃" str3))
      (setq strn str4)
  strn
But, no avail...
"pozorðâte"
« Last Edit: June 24, 2021, 08:54:57 AM by ribarm »
M.R. on Youtube
ribarm
« Reply #32 on: June 24, 2021, 05:07:22 PM »
Still no good results, but some progression is made...
My newest version :
(defun lstrcase ( str arg / str0 strs1 strs2 strs3 strs4 strs5 strs6 strs7 strs8 strs9 strs10 strr1 strr2 strr3 strr4 strr5 strr6 strr7 strr8 strr9 strr10 strn )
  (if (null arg)
      (setq str0 (strcase str t))
      (setq strs1 "ABCDEFGHIJKLMNOPQRSTUVWXYZΜSÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖØÙÚÛÜÝÞŸĀĂĄĆĈĊČĎĐĒĔĖĘĚĜĞĠĢĤĦĨĪĬĮIIJĴĶĹĻĽĿŁŃŅŇʼŊŌŎŐŒŔŖŘŚŜŞŠŢŤŦŨŪŬŮŰŲŴŶŹŻŽ")
      (setq strs2 "SɃƂƄƇƋƑǶƘȽȠƠƢƤƧƬƯƳƵƸƼǷDŽLJNJǍǏǑǓǕǗǙǛƎǞǠǢǤǦǨǪǬǮJDZǴǸǺǼǾȀȂȄȆȈȊȌȎȐȒȔȖȘȚȜȞȢȤȦȨȪȬȮȰȲȻⱾⱿɁɆɈɊɌɎⱯⱭⱰƁƆƉƊƏƐƓƔƗƖⱢƜⱮƝƟⱤƦƩƮɄƱƲɅƷͰͲͶϽϾϿΙΆΈΉΊΥ")
      (setq strs3 "ΑΒΓΔΕΖΗΘΙΚΛΜΝΞΟΠΡΣΣΤΥΦΧΨΩΪΫΌΎΏΒΘΦΠϏϘϚϜϞϠϢϤϦϨϪϬϮΚΡϹͿΕϷϺ")
      (setq strs4 "АБВГДЕЖЗИЙКЛМНОПРСТУФХЦЧШЩЪЫЬЭЮЯЀЁЂЃЄЅІЇЈЉЊЋЌЍЎЏѠѢѤѦѨѪѬѮѰѲѴѶѸѺѼѾҀҊҌҎҐҒҔҖҘҚҜҞҠҢҤҦҨҪҬҮҰҲҴҶҸҺҼҾӁӃӅӇӉӋӍӀӐӒӔӖӘӚӜӞӠӢӤӦӨӪӬӮӰӲӴӶӸӺӼӾԀԂԄԆԈԊԌԎԐԒԔԖԘԚԜԞԠԢԤԦԨԪԬԮ")
      (setq strs5 "ԱԲԳԴԵԶԷԸԹԺԻԼԽԾԿՀՁՂՃՄՅՆՇՈՉՊՋՌՍՎՏՐՑՒՓՔՕՖԵᲐᲑᲒᲓᲔᲕᲖᲗᲘᲙᲚᲛᲜᲝᲞᲟᲠᲡᲢᲣᲤᲥᲦᲧᲨᲩᲪᲫᲬᲭᲮᲯᲰᲱᲲᲳᲴᲵᲶᲷᲸᲹᲺᲽᲾᲿᏰᏱᏲᏳᏴᏵ")
      (setq strs6 "ⱣḀḂḄḆḈḊḌḎḐḒḔḖḘḚḜḞḠḢḤḦḨḪḬḮḰḲḴḶḸḺḼḾṀṂṄṆṈṊṌṎṐṒṔṖṘṚṜṞṠṢṤṦṨṪṬṮṰṲṴṶṸṺṼṾẀẂẄẆẈẊẌẎẐẒẔHTWYAṠẠẢẤẦẨẪẬẮẰẲẴẶẸẺẼẾỀỂỄỆỈỊỌỎỐỒỔỖỘỚỜỞỠỢỤỦỨỪỬỮỰỲỴỶỸỺỼỾἈἉἊἋἌἍἎἏἘἙἚἛἜἝἨἩἪἫἬἭἮἯἸἹἺἻἼἽἾἿὈὉὊὋὌὍΥὙΥὛΥὝΥὟὨὩὪὫὬὭὮὯᾺΆῈΈῊΉῚΊῸΌῪΎῺΏἈἉἊἋἌἍἎἏἨἩἪἫἬἭἮἯὨὩὪὫὬὭὮὯᾸᾹᾺΑΆΑΑΙῊΗΉΗΗῘῙΙΙΙΙῨῩΥΥΡῬΥΥῺΩΏΩΩℲↃ")
      (setq strs7 "ⰀⰁⰂⰃⰄⰅⰆⰇⰈⰉⰊⰋⰌⰍⰎⰏⰐⰑⰒⰓⰔⰕⰖⰗⰘⰙⰚⰛⰜⰝⰞⰟⰠⰡⰢⰣⰤⰥⰦⰧⰨⰩⰪⰫⰬⰭⰮⱠȺȾⱧⱩⱫⱲⱵⳫⳭⳲႠႡႢႣႤႥႦႧႨႩႪႫႬႭႮႯႰႱႲႳႴႵႶႷႸႹႺႻႼႽႾႿჀჁჂჃჄჅჇჍ")
      (setq strs8 "ᎠᎡᎢᎣᎤᎥᎦᎧᎨᎩᎪᎫᎬᎭᎮᎯᎰᎱᎲᎳᎴᎵᎶᎷᎸᎹᎺᎻᎼᎽᎾᎿᏀᏁᏂᏃᏄᏅᏆᏇᏈᏉᏊᏋᏌᏍᏎᏏᏐᏑᏒᏓᏔᏕᏖᏗᏘᏙᏚᏛᏜᏝᏞᏟᏠᏡᏢᏣᏤᏥᏦᏧᏨᏩᏪᏫᏬᏭᏮᏯ")
      (setq strs9 "FFFFFFSՄՄՄՎՄABCDEFGHIJKLMNOPQRSTUVWXYZ𐐀𐐁𐐂𐐃𐐄𐐅𐐆𐐇𐐈𐐉𐐊𐐋𐐌𐐍𐐎𐐏𐐐𐐑𐐒𐐓𐐔𐐕𐐖𐐗𐐘𐐙𐐚𐐛𐐜𐐝𐐞𐐟𐐠𐐡𐐢𐐣𐐤𐐥𐐦𐐧𐒰𐒱𐒲𐒳𐒴𐒵𐒶𐒷𐒸𐒹𐒺𐒻𐒼𐒽𐒾𐒿𐓀𐓁𐓂𐓃𐓄𐓅𐓆𐓇𐓈𐓉𐓊𐓋𐓌𐓍𐓎𐓏𐓐𐓑𐓒𐓓")
      (setq strs10 "𞤀𞤁𞤂𞤃𞤄𞤅𞤆𞤇𞤈𞤉𞤊𞤋𞤌𞤍𞤎𞤏𞤐𞤑𞤒𞤓𞤔𞤕𞤖𞤗𞤘𞤙𞤚𞤛𞤜𞤝𞤞𞤟𞤠𞤡")
      (setq strr1 "abcdefghijklmnopqrstuvwxyzµßàáâãäåæçèéêëìíîïðñòóôõöøùúûüýþÿāăąćĉċčďđēĕėęěĝğġģĥħĩīĭįıijĵķĺļľŀłńņňʼnŋōŏőœŕŗřśŝşšţťŧũūŭůűųŵŷźżž")
      (setq strr2 "ſƀƃƅƈƌƒƕƙƚƞơƣƥƨƭưƴƶƹƽƿdžljnjǎǐǒǔǖǘǚǜǝǟǡǣǥǧǩǫǭǯǰdzǵǹǻǽǿȁȃȅȇȉȋȍȏȑȓȕȗșțȝȟȣȥȧȩȫȭȯȱȳȼȿɀɂɇɉɋɍɏɐɑɒɓɔɖɗəɛɠɣɨɩɫɯɱɲɵɽʀʃʈʉʊʋʌʒͱͳͷͻͼͽΐάέήίΰ")
      (setq strr3 "αβγδεζηθικλμνξοπρςστυφχψωϊϋόύώϐϑϕϖϗϙϛϝϟϡϣϥϧϩϫϭϯϰϱϲϳϵϸϻ")
      (setq strr4 "абвгдежзийклмнопрстуфхцчшщъыьэюяѐёђѓєѕіїјљњћќѝўџѡѣѥѧѩѫѭѯѱѳѵѷѹѻѽѿҁҋҍҏґғҕҗҙқҝҟҡңҥҧҩҫҭүұҳҵҷҹһҽҿӂӄӆӈӊӌӎӏӑӓӕӗәӛӝӟӡӣӥӧөӫӭӯӱӳӵӷӹӻӽӿԁԃԅԇԉԋԍԏԑԓԕԗԙԛԝԟԡԣԥԧԩԫԭԯ")
      (setq strr5 "աբգդեզէըթժիլխծկհձղճմյնշոչպջռսվտրցւփքօֆևაბგდევზთიკლმნოპჟრსტუფქღყშჩცძწჭხჯჰჱჲჳჴჵჶჷჸჹჺჽჾჿᏸᏹᏺᏻᏼᏽ")
      (setq strr6 "ᵽḁḃḅḇḉḋḍḏḑḓḕḗḙḛḝḟḡḣḥḧḩḫḭḯḱḳḵḷḹḻḽḿṁṃṅṇṉṋṍṏṑṓṕṗṙṛṝṟṡṣṥṧṩṫṭṯṱṳṵṷṹṻṽṿẁẃẅẇẉẋẍẏẑẓẕẖẗẘẙẚẛạảấầẩẫậắằẳẵặẹẻẽếềểễệỉịọỏốồổỗộớờởỡợụủứừửữựỳỵỷỹỻỽỿἀἁἂἃἄἅἆἇἐἑἒἓἔἕἠἡἢἣἤἥἦἧἰἱἲἳἴἵἶἷὀὁὂὃὄὅὐὑὒὓὔὕὖὗὠὡὢὣὤὥὦὧὰάὲέὴήὶίὸόὺύὼώᾀᾁᾂᾃᾄᾅᾆᾇᾐᾑᾒᾓᾔᾕᾖᾗᾠᾡᾢᾣᾤᾥᾦᾧᾰᾱᾲᾳᾴᾶᾷιῂῃῄῆῇῐῑῒΐῖῗῠῡῢΰῤῥῦῧῲῳῴῶῷⅎↄ")
      (setq strr7 "ⰰⰱⰲⰳⰴⰵⰶⰷⰸⰹⰺⰻⰼⰽⰾⰿⱀⱁⱂⱃⱄⱅⱆⱇⱈⱉⱊⱋⱌⱍⱎⱏⱐⱑⱒⱓⱔⱕⱖⱗⱘⱙⱚⱛⱜⱝⱞⱡⱥⱦⱨⱪⱬⱳⱶⳬⳮⳳⴀⴁⴂⴃⴄⴅⴆⴇⴈⴉⴊⴋⴌⴍⴎⴏⴐⴑⴒⴓⴔⴕⴖⴗⴘⴙⴚⴛⴜⴝⴞⴟⴠⴡⴢⴣⴤⴥⴧⴭ")
      (setq strr8 "ꭰꭱꭲꭳꭴꭵꭶꭷꭸꭹꭺꭻꭼꭽꭾꭿꮀꮁꮂꮃꮄꮅꮆꮇꮈꮉꮊꮋꮌꮍꮎꮏꮐꮑꮒꮓꮔꮕꮖꮗꮘꮙꮚꮛꮜꮝꮞꮟꮠꮡꮢꮣꮤꮥꮦꮧꮨꮩꮪꮫꮬꮭꮮꮯꮰꮱꮲꮳꮴꮵꮶꮷꮸꮹꮺꮻꮼꮽꮾꮿ")
      (setq strr9 "fffiflffifflſtstﬓﬔﬕﬖﬗabcdefghijklmnopqrstuvwxyz𐐨𐐩𐐪𐐫𐐬𐐭𐐮𐐯𐐰𐐱𐐲𐐳𐐴𐐵𐐶𐐷𐐸𐐹𐐺𐐻𐐼𐐽𐐾𐐿𐑀𐑁𐑂𐑃𐑄𐑅𐑆𐑇𐑈𐑉𐑊𐑋𐑌𐑍𐑎𐑏𐓘𐓙𐓚𐓛𐓜𐓝𐓞𐓟𐓠𐓡𐓢𐓣𐓤𐓥𐓦𐓧𐓨𐓩𐓪𐓫𐓬𐓭𐓮𐓯𐓰𐓱𐓲𐓳𐓴𐓵𐓶𐓷𐓸𐓹𐓺𐓻")
      (setq strr10 "𞤢𞤣𞤤𞤥𞤦𞤧𞤨𞤩𞤪𞤫𞤬𞤭𞤮𞤯𞤰𞤱𞤲𞤳𞤴𞤵𞤶𞤷𞤸𞤹𞤺𞤻𞤼𞤽𞤾𞤿𞥀𞥁𞥂𞥃")
      (setq strn (vl-string-translate (apply 'strcat (list strs1 strs2 strs3 strs4 strs5 strs6 strs7 strs8 strs9 strs10)) (apply 'strcat (list strr1 strr2 strr3 strr4 strr5 strr6 strr7 strr8 strr9 strr10)) str0))
  strn
M.R. on Youtube
ribarm
« Reply #33 on: June 25, 2021, 07:27:11 PM »
Look VovKa, I think I solved the problem... The problem is that I now don't have quite much nerves to finish the code... I am leaving only robotic thingy to be done - mapping all letters to each other... So, finally, my version is not using (vl-string-translate) which is buggy with unicode characters, but rather split string and do replacements in (mapcar)...
We'll be all grateful if someone could finish it...
Now I am waiting...
[EDIT] : I've finished... [/EDIT]
BUT, STILL WEIRD THINGS ARE HAPPENING...
Command: (lstrcase "POZORIŠTE" T)
"pozoriŠte"
I really don't know what is now the problem...
« Last Edit: June 26, 2021, 09:14:34 AM by ribarm »
M.R. on Youtube
ribarm
« Reply #34 on: June 26, 2021, 07:43:39 AM »
This version is working... But I had to add an alert message to inform that you must copy+paste 2 definitions : UPPERCASE and LOWERCASE into AutoCAD interface prior using function (lstrcase), as if you load them throuh *.lsp file - defuns are evaluated and definitions are saved wrongly in AutoCAD memory... I don't quite know how to overcome this issue, but to make users do it this way I explained... I have the code for copy to clipboard from Patrick_35, but this assumes you specify string and that is already evaluated through process, so IMHO there is no other way... Perhaps AutoDesk will change original APPLOAD command, or make different recognizing stored definitions inside *.lsp file during loading of files, I don't know, but I suppose that this opinion is only valid for this kind of situations...
Here is correct file...
Regards, M.R.
[EDIT]
Here is my complete output :
"pozorište"
"абвгдђежзијклљмнњопрстћуфхцчџш"
"йцукенгшщзхґфивапролджєячсмітьбюї"
So, still something is wrong, but now I don't know what is it and how to fix it... I think that I successfully contributed to the task according to my capabilities and knowledge... I hope that someone will find it useful after all...
[/EDIT]
« Last Edit: June 26, 2021, 09:45:20 AM by ribarm »
M.R. on Youtube
VovKa
  • Ukraine
« Reply #35 on: June 26, 2021, 01:06:37 PM »
i could not load (cut and paste) it into acad2008
ribarm
« Reply #36 on: June 26, 2021, 01:17:15 PM »
You load *.lsp normaly, but you open *.lsp, then you find at the beggining 2 (defun)s - UPPERCASE and LOWERCASE, you select them, you press ctrl+C... You go to AutoCAD, press F2, textscreen will pop up, click with mouse on Command: prompt and press ctrl+V... Textscreen should be filled with codes... You must firstly load *.lsp so that while reload definitions wouldn't be changed... Then you just type whatever you like like normal sub function : for ex. (lstrcase "bla bla bla" nil) => "BLA BLA BLA"... That's all...
M.R. on Youtube
VovKa
  • Ukraine
« Reply #37 on: June 26, 2021, 01:57:02 PM »
https://imgur.com/C1pKaUy
that is what i get
ribarm
« Reply #38 on: June 26, 2021, 02:16:31 PM »
Well, you should type ")" wthout quotes, perhaps several times... I get this too, but I just type once and definitions load like should...
M.R. on Youtube
ribarm
« Reply #39 on: June 26, 2021, 02:24:14 PM »
I see it now... It seems that your A2008 fails to copy complete lists while copy+paste operations... Maybe memory issue, or perhaps you should get more recent version of AutoCAD after all... I use Vanilla AutoCAD2018 and BricsCAD V21 - never had problems with this procedure - my subs aren't so big - it should have done it well - I don't know...
M.R. on Youtube
ribarm
« Reply #40 on: June 27, 2021, 06:50:49 AM »
Just to explain what is happening when you are loading through file...
Copy+paste this line to Command: prompt and look what it returns :
(vl-string->list "Μ")
The correct output should be : (92 85 43 48 51 57 67)
Then just copy the same line into some lsp file - I used qqq.lsp
This is what I get when loaded into AutoCAD interface :
Command: _pasteclip
Command: (LOAD "C:/TESTING ROUTINES/qqq.lsp") (206 156)
The same thing is happening with : (uppercase) and (lowercase)... Simply AutoCAD/BricsCAD evaluates those defuns while loading through lsp file and complete list of lists from unicode chars is different than it should be... This causes that when you type string and provide it to (lstrcase) function, lstrcase splits string to chars and then when simply search for correct list inside list of lists, unicode char could not be found, leaving in resulting output no changes in caseing of letter... Simply char "Μ" - list (92 85 43 48 51 57 67) is incorrectly interpreted with list (206 156) and this list (206 156) can't be reconverted back to "Μ" ( (vl-list->string '(206 156)) => "Îœ" and that is not "Μ" )... And when you save (vl-list->string '(206 156)) to file qqqq.lsp, result is :
Command: _pasteclip
Command: (LOAD "C:/TESTING ROUTINES/qqqq.lsp") "Μ"
And "Îœ" is not "Μ", so there is no other workaround but to use copy+paste method for loading those 2 defuns - (uppercase) and (lowercase)...
M.R. on Youtube
ribarm
« Reply #41 on: June 27, 2021, 07:57:57 AM »
VovKa, you should have told me... I just watched list by entering (uppercase) and (lowercase) upon my copy+paste into Command: prompt... So I just hardcoded those lists in (setq up ... ) and (setq lw ... )... Everything now works as should... You just simply load "lstrcase.lsp" normally and there you should have it (lstrcase) function ready for usage... Now lisp is little bigger...
M.R. on Youtube
ribarm
« Reply #42 on: June 27, 2021, 09:01:38 AM »
If I may conclude... There are 2 possible scenarios : Either there is a problem with CAD with recognizing code while loading *.lsp file literally, or there is actually problem with (vl-string->list) function itself - how it behaves directly at Command: prompt or processing from *.lsp that is loaded... Now I am starting to believe that it's more that (vl-string->list) is buggy and that's my second discovery beside buggy (rem) function... (strcase) wasn't the problem - it's just designed for English alphabet - (xstrcase) was also not the problem - it's designed for lowercases to uppercases for other international characters and it was introduced without arguments - I don't quite know how much it covers, and now there is my "lstrcase.lsp" which covers 1118 pars lowercase-uppercase letters with punctuation or not...
M.R. on Youtube
ribarm
« Reply #43 on: June 27, 2021, 09:30:55 AM »
And if I may notice AutoCAD and BricsCAD are different with (lstrcase) functionality...
AutoCAD - correct :
Command: (lstrcase "ŠĐČĆŽ" t)
"šđčćž"
BricsCAD - wrong :
"šðccž"
M.R. on Youtube
VovKa
  • Ukraine
« Reply #44 on: June 27, 2021, 01:11:48 PM »
sorry Marko
Command: (lstrcase "йцукенгшщзхґєждлорпавифячсмітьбюї" nil)
"ЙЦУКЕНГШЩЗХґєЖДЛОРПАВИФџчСМіТЬБЮї"
