Author Topic: Autocad 2020 - No new lisp  (Read 12189 times)
VovKa
  • Ukraine
Re: Autocad 2020 - No new lisp
« Reply #15 on: March 27, 2019, 06:25:41 PM »
@Vovka -
thank you
i got
(TBLOBJNAME "STYLE" n) -> nil
(TBLOBJNAME "STYLE" (strcase n)) -> nil
(TBLSEARCH "STYLE" n) -> ((0 . "STYLE") (2 . "ь") (70 . 0) (40 . 0.0) (41 . 1.0) (50 . 0.0) (71 . 0) (42 . 2.5) (3 . "arial.ttf") (4 . ""))
(TBLSEARCH "STYLE" (strcase n)) -> nil
what is your acad's version?
Grrr1337
« Reply #16 on: March 27, 2019, 06:40:33 PM »
I'm with ACAD 2017 (forgot to mention).
And on Windows 8.1 pro (if that matters).
(apply ''((a b c)(a b c))
vevo.bg
ribarm
  • Marko Ribar, architect
« Reply #17 on: March 28, 2019, 07:02:45 AM »
Command: (chr 252)
And it works with this letter...
A2018
How did you get "ь" with (chr 252)?
M.R. on Youtube
lamarn
Design is something you should do with both hands. My 2d hand , my 3d hand ..
VovKa
  • Ukraine
« Reply #19 on: March 28, 2019, 09:43:57 AM »
windows uses this code page https://en.wikipedia.org/wiki/Windows-1251 in Ukraine
"ь" is 044C
i think there's no such letter in Serbian
ribarm
« Reply #20 on: June 22, 2021, 12:44:39 PM »
@VovKa,
I found on manusoft.com info that there is undocumented ALISP function (xstrcase) which is good for translating international language lowercase letters to uppercase... Unfortunately there is no argument specification allowed to work like normal (strcase)... So I took my time to gather all lowercase letters from this site : https://www.compart.com/en/unicode/category/Ll
But unfortunately my function (lstrcase) won't work as (xstrcase) can't process string with that size... Anyway, I tried... At least if I may say so, don't do this again - all letters are gathered into string by doing copy+paste method which is tedious... If you can use my work good, but just saying - don't waste your time...
(defun lstrcase ( str arg )
  (if (null arg)
    (xstrcase str)
    (vl-string-translate (xstrcase "abcdefghijklmnopqrstuvwxyzāăąćĉċčďđēĕėęěĝğġģĥħĩīĭįıijĵķĸĺļľŀłńņňʼnŋōŏőŕŗřśŝşţťŧũūŭůűųŵŷźżſƀƃƅƈƌƍƕƙƚƛƞơƣƥƨƪƫƭưƴƶƹƺƽƾƿdžljnjǎǐǒǔǖǘǚǜǝǟǡǣǥǧǩǫǭǯǰdzǵǹǻǽǿȁȃȅȇȉȋȍȏȑȓȕȗșțȝȟȡȣȥȧȩȫȭȯȱȳȴȵȶȷȸȹȼȿɀɂɇɉɋɍɏɐɑɒɓɔɕɖɗɘəɚɛɜɝɞɟɠɡɢɣɤɥɦɧɨɩɪɫɬɭɮɯɰɱɲɳɴɵɶɷɸɹɺɻɼɽɾɿʀʁʂʃʄʅʆʇʈʉʊʋʌʍʎʏʐʑʒʓʕʖʗʘʙʚʛʜʝʞʟʠʡʢʣʤʥʦʧʨʩʪʫʬʭʮʯͱͳͷͻͼͽΐάέήίΰαβγδεζηθικλμνξοπρςστυφχψωϊϋόύώϐϑϕϖϗϙϛϝϟϡϣϥϧϩϫϭϯϰϱϲϳϵϸϻϼабвгдежзийклмнопрстуфхцчшщъыьэюяѐёђѓєѕіїјљњћќѝўџѡѣѥѧѩѫѭѯѱѳѵѷѹѻѽѿҁҋҍҏґғҕҗҙқҝҟҡңҥҧҩҫҭүұҳҵҷҹһҽҿӂӄӆӈӊӌӎӏӑӓӕӗәӛӝӟӡӣӥӧөӫӭӯӱӳӵӷӹӻӽӿԁԃԅԇԉԋԍԏԑԓԕԗԙԛԝԟԡԣԥԧԩԫԭԯՠաբգդեզէըթժիլխծկհձղճմյնշոչպջռսվտրցւփքօֆևֈაბგდევზთიკლმნოპჟრსტუფქღყშჩცძწჭხჯჰჱჲჳჴჵჶჷჸჹჺჽჾჿᏸᏹᏺᏻᏼᏽᲀᲁᲂᲃᲄᲅᲆᲇᲈᴀᴁᴂᴃᴄᴅᴆᴇᴈᴉᴊᴋᴌᴍᴎᴏᴐᴑᴒᴓᴔᴕᴖᴗᴘᴙᴚᴛᴜᴝᴞᴟᴠᴡᴢᴣᴤᴥᴦᴧᴨᴩᴪᴫᵫᵬᵭᵮᵯᵰᵱᵲᵳᵴᵵᵶᵷᵹᵺᵻᵼᵽᵾᵿᶀᶁᶂᶃᶄᶅᶆᶇᶈᶉᶊᶋᶌᶍᶎᶏᶐᶑᶒᶓᶔᶕᶖᶗᶘᶙᶚḁḃḅḇḉḋḍḏḑḓḕḗḙḛḝḟḡḣḥḧḩḫḭḯḱḳḵḷḹḻḽḿṁṃṅṇṉṋṍṏṑṓṕṗṙṛṝṟṡṣṥṧṩṫṭṯṱṳṵṷṹṻṽṿẁẃẅẇẉẋẍẏẑẓẕẖẗẘẙẚẛẜẝẟạảấầẩẫậắằẳẵặẹẻẽếềểễệỉịọỏốồổỗộớờởỡợụủứừửữựỳỵỷỹỻỽỿἀἁἂἃἄἅἆἇἐἑἒἓἔἕἠἡἢἣἤἥἦἧἰἱἲἳἴἵἶἷὀὁὂὃὄὅὐὑὒὓὔὕὖὗὠὡὢὣὤὥὦὧὰάὲέὴήὶίὸόὺύὼώᾀᾁᾂᾃᾄᾅᾆᾇᾐᾑᾒᾓᾔᾕᾖᾗᾠᾡᾢᾣᾤᾥᾦᾧᾰᾱᾲᾳᾴᾶᾷιῂῃῄῆῇῐῑῒΐῖῗῠῡῢΰῤῥῦῧῲῳῴῶῷℊℎℏℓℯℴℹℼℽⅆⅇⅈⅉⅎↄⰰⰱⰲⰳⰴⰵⰶⰷⰸⰹⰺⰻⰼⰽⰾⰿⱀⱁⱂⱃⱄⱅⱆⱇⱈⱉⱊⱋⱌⱍⱎⱏⱐⱑⱒⱓⱔⱕⱖⱗⱘⱙⱚⱛⱜⱝⱞⱡⱥⱦⱨⱪⱬⱱⱳⱴⱶⱷⱸⱹⱺⱻⲁⲃⲅⲇⲉⲋⲍⲏⲑⲓⲕⲗⲙⲛⲝⲟⲡⲣⲥⲧⲩⲫⲭⲯⲱⲳⲵⲷⲹⲻⲽⲿⳁⳃⳅⳇⳉⳋⳍⳏⳑⳓⳕⳗⳙⳛⳝⳟⳡⳣⳤⳬⳮⳳⴀⴁⴂⴃⴄⴅⴆⴇⴈⴉⴊⴋⴌⴍⴎⴏⴐⴑⴒⴓⴔⴕⴖⴗⴘⴙⴚⴛⴜⴝⴞⴟⴠⴡⴢⴣⴤⴥⴧⴭꙁꙃꙅꙇꙉꙋꙍꙏꙑꙓꙕꙗꙙꙛꙝꙟꙡꙣꙥꙧꙩꙫꙭꚁꚃꚅꚇꚉꚋꚍꚏꚑꚓꚕꚗꚙꚛꜣꜥꜧꜩꜫꜭꜯꜰꜱꜳꜵꜷꜹꜻꜽꜿꝁꝃꝅꝇꝉꝋꝍꝏꝑꝓꝕꝗꝙꝛꝝꝟꝡꝣꝥꝧꝩꝫꝭꝯꝱꝲꝳꝴꝵꝶꝷꝸꝺꝼꝿꞁꞃꞅꞇꞌꞎꞑꞓꞔꞕꞗꞙꞛꞝꞟꞡꞣꞥꞧꞩꞯꞵꞷꞹꞻꞽꞿꟃꟈꟊꟶꟺꬰꬱꬲꬳꬴꬵꬶꬷꬸꬹꬺꬻꬼꬽꬾꬿꭀꭁꭂꭃꭄꭅꭆꭇꭈꭉꭊꭋꭌꭍꭎꭏꭐꭑꭒꭓꭔꭕꭖꭗꭘꭙꭚꭠꭡꭢꭣꭤꭥꭦꭧꭨꭰꭱꭲꭳꭴꭵꭶꭷꭸꭹꭺꭻꭼꭽꭾꭿꮀꮁꮂꮃꮄꮅꮆꮇꮈꮉꮊꮋꮌꮍꮎꮏꮐꮑꮒꮓꮔꮕꮖꮗꮘꮙꮚꮛꮜꮝꮞꮟꮠꮡꮢꮣꮤꮥꮦꮧꮨꮩꮪꮫꮬꮭꮮꮯꮰꮱꮲꮳꮴꮵꮶꮷꮸꮹꮺꮻꮼꮽꮾꮿfffiflffifflſtstﬓﬔﬕﬖﬗabcdefghijklmnopqrstuvwxyz𐐨𐐩𐐪𐐫𐐬𐐭𐐮𐐯𐐰𐐱𐐲𐐳𐐴𐐵𐐶𐐷𐐸𐐹𐐺𐐻𐐼𐐽𐐾𐐿𐑀𐑁𐑂𐑃𐑄𐑅𐑆𐑇𐑈𐑉𐑊𐑋𐑌𐑍𐑎𐑏𐓘𐓙𐓚𐓛𐓜𐓝𐓞𐓟𐓠𐓡𐓢𐓣𐓤𐓥𐓦𐓧𐓨𐓩𐓪𐓫𐓬𐓭𐓮𐓯𐓰𐓱𐓲𐓳𐓴𐓵𐓶𐓷𐓸𐓹𐓺𐓻𐳀𐳁𐳂𐳃𐳄𐳅𐳆𐳇𐳈𐳉𐳊𐳋𐳌𐳍𐳎𐳏𐳐𐳑𐳒𐳓𐳔𐳕𐳖𐳗𐳘𐳙𐳚𐳛𐳜𐳝𐳞𐳟𐳠𐳡𐳢𐳣𐳤𐳥𐳦𐳧𐳨𐳩𐳪𐳫𐳬𐳭𐳮𐳯𐳰𐳱𐳲𑣀𑣁𑣂𑣃𑣄𑣅𑣆𑣇𑣈𑣉𑣊𑣋𑣌𑣍𑣎𑣏𑣐𑣑𑣒𑣓𑣔𑣕𑣖𑣗𑣘𑣙𑣚𑣛𑣜𑣝𑣞𑣟𖹠𖹡𖹢𖹣𖹤𖹥𖹦𖹧𖹨𖹩𖹪𖹫𖹬𖹭𖹮𖹯𖹰𖹱𖹲𖹳𖹴𖹵𖹶𖹷𖹸𖹹𖹺𖹻𖹼𖹽𖹾𖹿𝐚𝐛𝐜𝐝𝐞𝐟𝐠𝐡𝐢𝐣𝐤𝐥𝐦𝐧𝐨𝐩𝐪𝐫𝐬𝐭𝐮𝐯𝐰𝐱𝐲𝐳𝑎𝑏𝑐𝑑𝑒𝑓𝑔𝑖𝑗𝑘𝑙𝑚𝑛𝑜𝑝𝑞𝑟𝑠𝑡𝑢𝑣𝑤𝑥𝑦𝑧𝒂𝒃𝒄𝒅𝒆𝒇𝒈𝒉𝒊𝒋𝒌𝒍𝒎𝒏𝒐𝒑𝒒𝒓𝒔𝒕𝒖𝒗𝒘𝒙𝒚𝒛𝒶𝒷𝒸𝒹𝒻𝒽𝒾𝒿𝓀𝓁𝓂𝓃𝓅𝓆𝓇𝓈𝓉𝓊𝓋𝓌𝓍𝓎𝓏𝓪𝓫𝓬𝓭𝓮𝓯𝓰𝓱𝓲𝓳𝓴𝓵𝓶𝓷𝓸𝓹𝓺𝓻𝓼𝓽𝓾𝓿𝔀𝔁𝔂𝔃𝔞𝔟𝔠𝔡𝔢𝔣𝔤𝔥𝔦𝔧𝔨𝔩𝔪𝔫𝔬𝔭𝔮𝔯𝔰𝔱𝔲𝔳𝔴𝔵𝔶𝔷𝕒𝕓𝕔𝕕𝕖𝕗𝕘𝕙𝕚𝕛𝕜𝕝𝕞𝕟𝕠𝕡𝕢𝕣𝕤𝕥𝕦𝕧𝕨𝕩𝕪𝕫𝖆𝖇𝖈𝖉𝖊𝖋𝖌𝖍𝖎𝖏𝖐𝖑𝖒𝖓𝖔𝖕𝖖𝖗𝖘𝖙𝖚𝖛𝖜𝖝𝖞𝖟𝖺𝖻𝖼𝖽𝖾𝖿𝗀𝗁𝗂𝗃𝗄𝗅𝗆𝗇𝗈𝗉𝗊𝗋𝗌𝗍𝗎𝗏𝗐𝗑𝗒𝗓𝗮𝗯𝗰𝗱𝗲𝗳𝗴𝗵𝗶𝗷𝗸𝗹𝗺𝗻𝗼𝗽𝗾𝗿𝘀𝘁𝘂𝘃𝘄𝘅𝘆𝘇𝘢𝘣𝘤𝘥𝘦𝘧𝘨𝘩𝘪𝘫𝘬𝘭𝘮𝘯𝘰𝘱𝘲𝘳𝘴𝘵𝘶𝘷𝘸𝘹𝘺𝘻𝙖𝙗𝙘𝙙𝙚𝙛𝙜𝙝𝙞𝙟𝙠𝙡𝙢𝙣𝙤𝙥𝙦𝙧𝙨𝙩𝙪𝙫𝙬𝙭𝙮𝙯𝚊𝚋𝚌𝚍𝚎𝚏𝚐𝚑𝚒𝚓𝚔𝚕𝚖𝚗𝚘𝚙𝚚𝚛𝚜𝚝𝚞𝚟𝚠𝚡𝚢𝚣𝚤𝚥𝛂𝛃𝛄𝛅𝛆𝛇𝛈𝛉𝛊𝛋𝛌𝛍𝛎𝛏𝛐𝛑𝛒𝛓𝛔𝛕𝛖𝛗𝛘𝛙𝛚𝛜𝛝𝛞𝛟𝛠𝛡𝛼𝛽𝛾𝛿𝜀𝜁𝜂𝜃𝜄𝜅𝜆𝜇𝜈𝜉𝜊𝜋𝜌𝜍𝜎𝜏𝜐𝜑𝜒𝜓𝜔𝜖𝜗𝜘𝜙𝜚𝜛𝜶𝜷𝜸𝜹𝜺𝜻𝜼𝜽𝜾𝜿𝝀𝝁𝝂𝝃𝝄𝝅𝝆𝝇𝝈𝝉𝝊𝝋𝝌𝝍𝝎𝝐𝝑𝝒𝝓𝝔𝝕𝝰𝝱𝝲𝝳𝝴𝝵𝝶𝝷𝝸𝝹𝝺𝝻𝝼𝝽𝝾𝝿𝞀𝞁𝞂𝞃𝞄𝞅𝞆𝞇𝞈𝞊𝞋𝞌𝞍𝞎𝞏𝞪𝞫𝞬𝞭𝞮𝞯𝞰𝞱𝞲𝞳𝞴𝞵𝞶𝞷𝞸𝞹𝞺𝞻𝞼𝞽𝞾𝞿𝟀𝟁𝟂𝟄𝟅𝟆𝟇𝟈𝟉𝟋𞤢𞤣𞤤𞤥𞤦𞤧𞤨𞤩𞤪𞤫𞤬𞤭𞤮𞤯𞤰𞤱𞤲𞤳𞤴𞤵𞤶𞤷𞤸𞤹𞤺𞤻𞤼𞤽𞤾𞤿𞥀𞥁𞥂𞥃") "abcdefghijklmnopqrstuvwxyzāăąćĉċčďđēĕėęěĝğġģĥħĩīĭįıijĵķĸĺļľŀłńņňʼnŋōŏőŕŗřśŝşţťŧũūŭůűųŵŷźżſƀƃƅƈƌƍƕƙƚƛƞơƣƥƨƪƫƭưƴƶƹƺƽƾƿdžljnjǎǐǒǔǖǘǚǜǝǟǡǣǥǧǩǫǭǯǰdzǵǹǻǽǿȁȃȅȇȉȋȍȏȑȓȕȗșțȝȟȡȣȥȧȩȫȭȯȱȳȴȵȶȷȸȹȼȿɀɂɇɉɋɍɏɐɑɒɓɔɕɖɗɘəɚɛɜɝɞɟɠɡɢɣɤɥɦɧɨɩɪɫɬɭɮɯɰɱɲɳɴɵɶɷɸɹɺɻɼɽɾɿʀʁʂʃʄʅʆʇʈʉʊʋʌʍʎʏʐʑʒʓʕʖʗʘʙʚʛʜʝʞʟʠʡʢʣʤʥʦʧʨʩʪʫʬʭʮʯͱͳͷͻͼͽΐάέήίΰαβγδεζηθικλμνξοπρςστυφχψωϊϋόύώϐϑϕϖϗϙϛϝϟϡϣϥϧϩϫϭϯϰϱϲϳϵϸϻϼабвгдежзийклмнопрстуфхцчшщъыьэюяѐёђѓєѕіїјљњћќѝўџѡѣѥѧѩѫѭѯѱѳѵѷѹѻѽѿҁҋҍҏґғҕҗҙқҝҟҡңҥҧҩҫҭүұҳҵҷҹһҽҿӂӄӆӈӊӌӎӏӑӓӕӗәӛӝӟӡӣӥӧөӫӭӯӱӳӵӷӹӻӽӿԁԃԅԇԉԋԍԏԑԓԕԗԙԛԝԟԡԣԥԧԩԫԭԯՠաբգդեզէըթժիլխծկհձղճմյնշոչպջռսվտրցւփքօֆևֈაბგდევზთიკლმნოპჟრსტუფქღყშჩცძწჭხჯჰჱჲჳჴჵჶჷჸჹჺჽჾჿᏸᏹᏺᏻᏼᏽᲀᲁᲂᲃᲄᲅᲆᲇᲈᴀᴁᴂᴃᴄᴅᴆᴇᴈᴉᴊᴋᴌᴍᴎᴏᴐᴑᴒᴓᴔᴕᴖᴗᴘᴙᴚᴛᴜᴝᴞᴟᴠᴡᴢᴣᴤᴥᴦᴧᴨᴩᴪᴫᵫᵬᵭᵮᵯᵰᵱᵲᵳᵴᵵᵶᵷᵹᵺᵻᵼᵽᵾᵿᶀᶁᶂᶃᶄᶅᶆᶇᶈᶉᶊᶋᶌᶍᶎᶏᶐᶑᶒᶓᶔᶕᶖᶗᶘᶙᶚḁḃḅḇḉḋḍḏḑḓḕḗḙḛḝḟḡḣḥḧḩḫḭḯḱḳḵḷḹḻḽḿṁṃṅṇṉṋṍṏṑṓṕṗṙṛṝṟṡṣṥṧṩṫṭṯṱṳṵṷṹṻṽṿẁẃẅẇẉẋẍẏẑẓẕẖẗẘẙẚẛẜẝẟạảấầẩẫậắằẳẵặẹẻẽếềểễệỉịọỏốồổỗộớờởỡợụủứừửữựỳỵỷỹỻỽỿἀἁἂἃἄἅἆἇἐἑἒἓἔἕἠἡἢἣἤἥἦἧἰἱἲἳἴἵἶἷὀὁὂὃὄὅὐὑὒὓὔὕὖὗὠὡὢὣὤὥὦὧὰάὲέὴήὶίὸόὺύὼώᾀᾁᾂᾃᾄᾅᾆᾇᾐᾑᾒᾓᾔᾕᾖᾗᾠᾡᾢᾣᾤᾥᾦᾧᾰᾱᾲᾳᾴᾶᾷιῂῃῄῆῇῐῑῒΐῖῗῠῡῢΰῤῥῦῧῲῳῴῶῷℊℎℏℓℯℴℹℼℽⅆⅇⅈⅉⅎↄⰰⰱⰲⰳⰴⰵⰶⰷⰸⰹⰺⰻⰼⰽⰾⰿⱀⱁⱂⱃⱄⱅⱆⱇⱈⱉⱊⱋⱌⱍⱎⱏⱐⱑⱒⱓⱔⱕⱖⱗⱘⱙⱚⱛⱜⱝⱞⱡⱥⱦⱨⱪⱬⱱⱳⱴⱶⱷⱸⱹⱺⱻⲁⲃⲅⲇⲉⲋⲍⲏⲑⲓⲕⲗⲙⲛⲝⲟⲡⲣⲥⲧⲩⲫⲭⲯⲱⲳⲵⲷⲹⲻⲽⲿⳁⳃⳅⳇⳉⳋⳍⳏⳑⳓⳕⳗⳙⳛⳝⳟⳡⳣⳤⳬⳮⳳⴀⴁⴂⴃⴄⴅⴆⴇⴈⴉⴊⴋⴌⴍⴎⴏⴐⴑⴒⴓⴔⴕⴖⴗⴘⴙⴚⴛⴜⴝⴞⴟⴠⴡⴢⴣⴤⴥⴧⴭꙁꙃꙅꙇꙉꙋꙍꙏꙑꙓꙕꙗꙙꙛꙝꙟꙡꙣꙥꙧꙩꙫꙭꚁꚃꚅꚇꚉꚋꚍꚏꚑꚓꚕꚗꚙꚛꜣꜥꜧꜩꜫꜭꜯꜰꜱꜳꜵꜷꜹꜻꜽꜿꝁꝃꝅꝇꝉꝋꝍꝏꝑꝓꝕꝗꝙꝛꝝꝟꝡꝣꝥꝧꝩꝫꝭꝯꝱꝲꝳꝴꝵꝶꝷꝸꝺꝼꝿꞁꞃꞅꞇꞌꞎꞑꞓꞔꞕꞗꞙꞛꞝꞟꞡꞣꞥꞧꞩꞯꞵꞷꞹꞻꞽꞿꟃꟈꟊꟶꟺꬰꬱꬲꬳꬴꬵꬶꬷꬸꬹꬺꬻꬼꬽꬾꬿꭀꭁꭂꭃꭄꭅꭆꭇꭈꭉꭊꭋꭌꭍꭎꭏꭐꭑꭒꭓꭔꭕꭖꭗꭘꭙꭚꭠꭡꭢꭣꭤꭥꭦꭧꭨꭰꭱꭲꭳꭴꭵꭶꭷꭸꭹꭺꭻꭼꭽꭾꭿꮀꮁꮂꮃꮄꮅꮆꮇꮈꮉꮊꮋꮌꮍꮎꮏꮐꮑꮒꮓꮔꮕꮖꮗꮘꮙꮚꮛꮜꮝꮞꮟꮠꮡꮢꮣꮤꮥꮦꮧꮨꮩꮪꮫꮬꮭꮮꮯꮰꮱꮲꮳꮴꮵꮶꮷꮸꮹꮺꮻꮼꮽꮾꮿfffiflffifflſtstﬓﬔﬕﬖﬗabcdefghijklmnopqrstuvwxyz𐐨𐐩𐐪𐐫𐐬𐐭𐐮𐐯𐐰𐐱𐐲𐐳𐐴𐐵𐐶𐐷𐐸𐐹𐐺𐐻𐐼𐐽𐐾𐐿𐑀𐑁𐑂𐑃𐑄𐑅𐑆𐑇𐑈𐑉𐑊𐑋𐑌𐑍𐑎𐑏𐓘𐓙𐓚𐓛𐓜𐓝𐓞𐓟𐓠𐓡𐓢𐓣𐓤𐓥𐓦𐓧𐓨𐓩𐓪𐓫𐓬𐓭𐓮𐓯𐓰𐓱𐓲𐓳𐓴𐓵𐓶𐓷𐓸𐓹𐓺𐓻𐳀𐳁𐳂𐳃𐳄𐳅𐳆𐳇𐳈𐳉𐳊𐳋𐳌𐳍𐳎𐳏𐳐𐳑𐳒𐳓𐳔𐳕𐳖𐳗𐳘𐳙𐳚𐳛𐳜𐳝𐳞𐳟𐳠𐳡𐳢𐳣𐳤𐳥𐳦𐳧𐳨𐳩𐳪𐳫𐳬𐳭𐳮𐳯𐳰𐳱𐳲𑣀𑣁𑣂𑣃𑣄𑣅𑣆𑣇𑣈𑣉𑣊𑣋𑣌𑣍𑣎𑣏𑣐𑣑𑣒𑣓𑣔𑣕𑣖𑣗𑣘𑣙𑣚𑣛𑣜𑣝𑣞𑣟𖹠𖹡𖹢𖹣𖹤𖹥𖹦𖹧𖹨𖹩𖹪𖹫𖹬𖹭𖹮𖹯𖹰𖹱𖹲𖹳𖹴𖹵𖹶𖹷𖹸𖹹𖹺𖹻𖹼𖹽𖹾𖹿𝐚𝐛𝐜𝐝𝐞𝐟𝐠𝐡𝐢𝐣𝐤𝐥𝐦𝐧𝐨𝐩𝐪𝐫𝐬𝐭𝐮𝐯𝐰𝐱𝐲𝐳𝑎𝑏𝑐𝑑𝑒𝑓𝑔𝑖𝑗𝑘𝑙𝑚𝑛𝑜𝑝𝑞𝑟𝑠𝑡𝑢𝑣𝑤𝑥𝑦𝑧𝒂𝒃𝒄𝒅𝒆𝒇𝒈𝒉𝒊𝒋𝒌𝒍𝒎𝒏𝒐𝒑𝒒𝒓𝒔𝒕𝒖𝒗𝒘𝒙𝒚𝒛𝒶𝒷𝒸𝒹𝒻𝒽𝒾𝒿𝓀𝓁𝓂𝓃𝓅𝓆𝓇𝓈𝓉𝓊𝓋𝓌𝓍𝓎𝓏𝓪𝓫𝓬𝓭𝓮𝓯𝓰𝓱𝓲𝓳𝓴𝓵𝓶𝓷𝓸𝓹𝓺𝓻𝓼𝓽𝓾𝓿𝔀𝔁𝔂𝔃𝔞𝔟𝔠𝔡𝔢𝔣𝔤𝔥𝔦𝔧𝔨𝔩𝔪𝔫𝔬𝔭𝔮𝔯𝔰𝔱𝔲𝔳𝔴𝔵𝔶𝔷𝕒𝕓𝕔𝕕𝕖𝕗𝕘𝕙𝕚𝕛𝕜𝕝𝕞𝕟𝕠𝕡𝕢𝕣𝕤𝕥𝕦𝕧𝕨𝕩𝕪𝕫𝖆𝖇𝖈𝖉𝖊𝖋𝖌𝖍𝖎𝖏𝖐𝖑𝖒𝖓𝖔𝖕𝖖𝖗𝖘𝖙𝖚𝖛𝖜𝖝𝖞𝖟𝖺𝖻𝖼𝖽𝖾𝖿𝗀𝗁𝗂𝗃𝗄𝗅𝗆𝗇𝗈𝗉𝗊𝗋𝗌𝗍𝗎𝗏𝗐𝗑𝗒𝗓𝗮𝗯𝗰𝗱𝗲𝗳𝗴𝗵𝗶𝗷𝗸𝗹𝗺𝗻𝗼𝗽𝗾𝗿𝘀𝘁𝘂𝘃𝘄𝘅𝘆𝘇𝘢𝘣𝘤𝘥𝘦𝘧𝘨𝘩𝘪𝘫𝘬𝘭𝘮𝘯𝘰𝘱𝘲𝘳𝘴𝘵𝘶𝘷𝘸𝘹𝘺𝘻𝙖𝙗𝙘𝙙𝙚𝙛𝙜𝙝𝙞𝙟𝙠𝙡𝙢𝙣𝙤𝙥𝙦𝙧𝙨𝙩𝙪𝙫𝙬𝙭𝙮𝙯𝚊𝚋𝚌𝚍𝚎𝚏𝚐𝚑𝚒𝚓𝚔𝚕𝚖𝚗𝚘𝚙𝚚𝚛𝚜𝚝𝚞𝚟𝚠𝚡𝚢𝚣𝚤𝚥𝛂𝛃𝛄𝛅𝛆𝛇𝛈𝛉𝛊𝛋𝛌𝛍𝛎𝛏𝛐𝛑𝛒𝛓𝛔𝛕𝛖𝛗𝛘𝛙𝛚𝛜𝛝𝛞𝛟𝛠𝛡𝛼𝛽𝛾𝛿𝜀𝜁𝜂𝜃𝜄𝜅𝜆𝜇𝜈𝜉𝜊𝜋𝜌𝜍𝜎𝜏𝜐𝜑𝜒𝜓𝜔𝜖𝜗𝜘𝜙𝜚𝜛𝜶𝜷𝜸𝜹𝜺𝜻𝜼𝜽𝜾𝜿𝝀𝝁𝝂𝝃𝝄𝝅𝝆𝝇𝝈𝝉𝝊𝝋𝝌𝝍𝝎𝝐𝝑𝝒𝝓𝝔𝝕𝝰𝝱𝝲𝝳𝝴𝝵𝝶𝝷𝝸𝝹𝝺𝝻𝝼𝝽𝝾𝝿𝞀𝞁𝞂𝞃𝞄𝞅𝞆𝞇𝞈𝞊𝞋𝞌𝞍𝞎𝞏𝞪𝞫𝞬𝞭𝞮𝞯𝞰𝞱𝞲𝞳𝞴𝞵𝞶𝞷𝞸𝞹𝞺𝞻𝞼𝞽𝞾𝞿𝟀𝟁𝟂𝟄𝟅𝟆𝟇𝟈𝟉𝟋𞤢𞤣𞤤𞤥𞤦𞤧𞤨𞤩𞤪𞤫𞤬𞤭𞤮𞤯𞤰𞤱𞤲𞤳𞤴𞤵𞤶𞤷𞤸𞤹𞤺𞤻𞤼𞤽𞤾𞤿𞥀𞥁𞥂𞥃" str)
Regards, M.R.
M.R. on Youtube
VovKa
  • Ukraine
« Reply #21 on: June 22, 2021, 01:44:49 PM »
Marko,
vlide does not support unicode
as soon as you copy and paste your lstrcase function into vlide, all characters except those from you active windows code page will turn to '?'
i'm sure it's impossible to write a universal substitute for strcase by just using vl-string-translate
ribarm
« Reply #22 on: June 22, 2021, 02:01:46 PM »
VovKa, this guy stumbled with the same problem and as a solution it was proposed (vl-string-translate)...
Just for info here is a link :
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/strcase-and-accented-characters/m-p/6378503#M341948
M.R. on Youtube
VovKa
  • Ukraine
« Reply #23 on: June 22, 2021, 02:50:50 PM »
in this case we will need an individual substitution table for every code page
i believe windows is keeping these tables in .nls files
i myself do use vl-string-translate for my custom strcase but it is not universal and supports only windows-1251
ribarm
« Reply #24 on: June 23, 2021, 04:34:51 AM »
I divided main string into 4 smaller ones and combined them to work together, but it seems that it isn't working just like should :
Command: (lstrcase "pozorite" nil)
"POZORITE"
Command: (lstrcase "POZORITE" t)
"pozorite"
Here is my revised (lstrcase) function...
(defun lstrcase ( str arg / str1 str2 str3 str4 strn )
  (if (null arg)
    (setq strn (xstrcase str))
      (setq str1 (vl-string-translate (xstrcase "abcdefghijklmnopqrstuvwxyzāăąćĉċčďđēĕėęěĝğġģĥħĩīĭįıijĵķĸĺļľŀłńņňʼnŋōŏőŕŗřśŝşţťŧũūŭůűųŵŷźżſƀƃƅƈƌƍƕƙƚƛƞơƣƥƨƪƫƭưƴƶƹƺƽƾƿdžljnjǎǐǒǔǖǘǚǜǝǟǡǣǥǧǩǫǭǯǰdzǵǹǻǽǿȁȃȅȇȉȋȍȏȑȓȕȗșțȝȟȡȣȥȧȩȫȭȯȱȳȴȵȶȷȸȹȼȿɀɂɇɉɋɍɏɐɑɒɓɔɕɖɗɘəɚɛɜɝɞɟɠɡɢɣɤɥɦɧɨɩɪɫɬɭɮɯɰɱɲɳɴɵɶɷɸɹɺɻɼɽɾɿʀʁʂʃʄʅʆʇʈʉʊʋʌʍʎʏʐʑʒʓʕʖʗʘʙʚʛʜʝʞʟʠʡʢʣʤʥʦʧʨʩʪʫʬʭʮʯͱͳͷͻͼͽΐάέήίΰαβγδεζηθικλμνξοπρςστυφχψωϊϋόύώϐϑϕϖϗϙϛϝϟϡϣϥϧϩϫϭϯϰϱϲϳϵϸϻϼабвгдежзийклмнопрстуфхцчшщъыьэюяѐёђѓєѕіїјљњћќѝўџѡѣѥѧѩѫѭѯѱѳѵѷѹѻѽѿҁҋҍҏґғҕҗҙқҝҟҡңҥҧҩҫҭүұҳҵҷҹһҽҿӂӄӆӈӊӌӎӏӑӓӕӗәӛӝӟӡӣӥӧөӫӭӯӱӳӵӷӹӻӽӿԁԃԅԇԉԋԍԏԑԓԕԗԙԛԝԟԡԣԥԧԩԫԭԯՠաբգդեզէը") "abcdefghijklmnopqrstuvwxyzāăąćĉċčďđēĕėęěĝğġģĥħĩīĭįıijĵķĸĺļľŀłńņňʼnŋōŏőŕŗřśŝşţťŧũūŭůűųŵŷźżſƀƃƅƈƌƍƕƙƚƛƞơƣƥƨƪƫƭưƴƶƹƺƽƾƿdžljnjǎǐǒǔǖǘǚǜǝǟǡǣǥǧǩǫǭǯǰdzǵǹǻǽǿȁȃȅȇȉȋȍȏȑȓȕȗșțȝȟȡȣȥȧȩȫȭȯȱȳȴȵȶȷȸȹȼȿɀɂɇɉɋɍɏɐɑɒɓɔɕɖɗɘəɚɛɜɝɞɟɠɡɢɣɤɥɦɧɨɩɪɫɬɭɮɯɰɱɲɳɴɵɶɷɸɹɺɻɼɽɾɿʀʁʂʃʄʅʆʇʈʉʊʋʌʍʎʏʐʑʒʓʕʖʗʘʙʚʛʜʝʞʟʠʡʢʣʤʥʦʧʨʩʪʫʬʭʮʯͱͳͷͻͼͽΐάέήίΰαβγδεζηθικλμνξοπρςστυφχψωϊϋόύώϐϑϕϖϗϙϛϝϟϡϣϥϧϩϫϭϯϰϱϲϳϵϸϻϼабвгдежзийклмнопрстуфхцчшщъыьэюяѐёђѓєѕіїјљњћќѝўџѡѣѥѧѩѫѭѯѱѳѵѷѹѻѽѿҁҋҍҏґғҕҗҙқҝҟҡңҥҧҩҫҭүұҳҵҷҹһҽҿӂӄӆӈӊӌӎӏӑӓӕӗәӛӝӟӡӣӥӧөӫӭӯӱӳӵӷӹӻӽӿԁԃԅԇԉԋԍԏԑԓԕԗԙԛԝԟԡԣԥԧԩԫԭԯՠաբգդեզէը" str))
      (setq str2 (vl-string-translate (xstrcase "թժիլխծկհձղճմյնշոչպջռսվտրցւփքօֆևֈაბგდევზთიკლმნოპჟრსტუფქღყშჩცძწჭხჯჰჱჲჳჴჵჶჷჸჹჺჽჾჿᏸᏹᏺᏻᏼᏽᲀᲁᲂᲃᲄᲅᲆᲇᲈᴀᴁᴂᴃᴄᴅᴆᴇᴈᴉᴊᴋᴌᴍᴎᴏᴐᴑᴒᴓᴔᴕᴖᴗᴘᴙᴚᴛᴜᴝᴞᴟᴠᴡᴢᴣᴤᴥᴦᴧᴨᴩᴪᴫᵫᵬᵭᵮᵯᵰᵱᵲᵳᵴᵵᵶᵷᵹᵺᵻᵼᵽᵾᵿᶀᶁᶂᶃᶄᶅᶆᶇᶈᶉᶊᶋᶌᶍᶎᶏᶐᶑᶒᶓᶔᶕᶖᶗᶘᶙᶚḁḃḅḇḉḋḍḏḑḓḕḗḙḛḝḟḡḣḥḧḩḫḭḯḱḳḵḷḹḻḽḿṁṃṅṇṉṋṍṏṑṓṕṗṙṛṝṟṡṣṥṧṩṫṭṯṱṳṵṷṹṻṽṿẁẃẅẇẉẋẍẏẑẓẕẖẗẘẙẚẛẜẝẟạảấầẩẫậắằẳẵặẹẻẽếềểễệỉịọỏốồổỗộớờởỡợụủứừửữựỳỵỷỹỻỽỿἀἁἂἃἄἅἆἇἐἑἒἓἔἕἠἡἢἣἤἥἦἧἰἱἲἳἴἵἶἷὀὁὂὃὄὅὐὑὒὓὔὕὖὗὠὡὢὣὤὥὦὧὰάὲέὴήὶίὸόὺύὼώᾀᾁᾂᾃᾄᾅᾆᾇᾐᾑᾒᾓᾔᾕᾖᾗᾠᾡᾢᾣᾤᾥᾦᾧᾰᾱᾲᾳᾴᾶᾷιῂῃῄῆῇῐῑῒΐῖῗῠῡῢΰῤῥῦῧῲῳῴῶῷℊℎℏℓℯℴℹℼℽⅆⅇⅈⅉⅎↄⰰⰱⰲⰳⰴⰵⰶⰷⰸⰹⰺⰻⰼⰽⰾⰿⱀⱁⱂⱃⱄⱅⱆⱇⱈⱉⱊⱋⱌⱍⱎⱏⱐⱑⱒⱓⱔⱕⱖⱗⱘⱙⱚⱛⱜⱝⱞⱡⱥⱦⱨⱪⱬⱱⱳⱴⱶⱷⱸⱹⱺⱻⲁⲃⲅⲇⲉⲋⲍⲏⲑⲓⲕⲗⲙⲛⲝⲟⲡⲣⲥⲧⲩⲫⲭⲯ")"թժիլխծկհձղճմյնշոչպջռսվտրցւփքօֆևֈაბგდევზთიკლმნოპჟრსტუფქღყშჩცძწჭხჯჰჱჲჳჴჵჶჷჸჹჺჽჾჿᏸᏹᏺᏻᏼᏽᲀᲁᲂᲃᲄᲅᲆᲇᲈᴀᴁᴂᴃᴄᴅᴆᴇᴈᴉᴊᴋᴌᴍᴎᴏᴐᴑᴒᴓᴔᴕᴖᴗᴘᴙᴚᴛᴜᴝᴞᴟᴠᴡᴢᴣᴤᴥᴦᴧᴨᴩᴪᴫᵫᵬᵭᵮᵯᵰᵱᵲᵳᵴᵵᵶᵷᵹᵺᵻᵼᵽᵾᵿᶀᶁᶂᶃᶄᶅᶆᶇᶈᶉᶊᶋᶌᶍᶎᶏᶐᶑᶒᶓᶔᶕᶖᶗᶘᶙᶚḁḃḅḇḉḋḍḏḑḓḕḗḙḛḝḟḡḣḥḧḩḫḭḯḱḳḵḷḹḻḽḿṁṃṅṇṉṋṍṏṑṓṕṗṙṛṝṟṡṣṥṧṩṫṭṯṱṳṵṷṹṻṽṿẁẃẅẇẉẋẍẏẑẓẕẖẗẘẙẚẛẜẝẟạảấầẩẫậắằẳẵặẹẻẽếềểễệỉịọỏốồổỗộớờởỡợụủứừửữựỳỵỷỹỻỽỿἀἁἂἃἄἅἆἇἐἑἒἓἔἕἠἡἢἣἤἥἦἧἰἱἲἳἴἵἶἷὀὁὂὃὄὅὐὑὒὓὔὕὖὗὠὡὢὣὤὥὦὧὰάὲέὴήὶίὸόὺύὼώᾀᾁᾂᾃᾄᾅᾆᾇᾐᾑᾒᾓᾔᾕᾖᾗᾠᾡᾢᾣᾤᾥᾦᾧᾰᾱᾲᾳᾴᾶᾷιῂῃῄῆῇῐῑῒΐῖῗῠῡῢΰῤῥῦῧῲῳῴῶῷℊℎℏℓℯℴℹℼℽⅆⅇⅈⅉⅎↄⰰⰱⰲⰳⰴⰵⰶⰷⰸⰹⰺⰻⰼⰽⰾⰿⱀⱁⱂⱃⱄⱅⱆⱇⱈⱉⱊⱋⱌⱍⱎⱏⱐⱑⱒⱓⱔⱕⱖⱗⱘⱙⱚⱛⱜⱝⱞⱡⱥⱦⱨⱪⱬⱱⱳⱴⱶⱷⱸⱹⱺⱻⲁⲃⲅⲇⲉⲋⲍⲏⲑⲓⲕⲗⲙⲛⲝⲟⲡⲣⲥⲧⲩⲫⲭⲯ"str1))
      (setq str3 (vl-string-translate (xstrcase "ⲱⲳⲵⲷⲹⲻⲽⲿⳁⳃⳅⳇⳉⳋⳍⳏⳑⳓⳕⳗⳙⳛⳝⳟⳡⳣⳤⳬⳮⳳⴀⴁⴂⴃⴄⴅⴆⴇⴈⴉⴊⴋⴌⴍⴎⴏⴐⴑⴒⴓⴔⴕⴖⴗⴘⴙⴚⴛⴜⴝⴞⴟⴠⴡⴢⴣⴤⴥⴧⴭꙁꙃꙅꙇꙉꙋꙍꙏꙑꙓꙕꙗꙙꙛꙝꙟꙡꙣꙥꙧꙩꙫꙭꚁꚃꚅꚇꚉꚋꚍꚏꚑꚓꚕꚗꚙꚛꜣꜥꜧꜩꜫꜭꜯꜰꜱꜳꜵꜷꜹꜻꜽꜿꝁꝃꝅꝇꝉꝋꝍꝏꝑꝓꝕꝗꝙꝛꝝꝟꝡꝣꝥꝧꝩꝫꝭꝯꝱꝲꝳꝴꝵꝶꝷꝸꝺꝼꝿꞁꞃꞅꞇꞌꞎꞑꞓꞔꞕꞗꞙꞛꞝꞟꞡꞣꞥꞧꞩꞯꞵꞷꞹꞻꞽꞿꟃꟈꟊꟶꟺꬰꬱꬲꬳꬴꬵꬶꬷꬸꬹꬺꬻꬼꬽꬾꬿꭀꭁꭂꭃꭄꭅꭆꭇꭈꭉꭊꭋꭌꭍꭎꭏꭐꭑꭒꭓꭔꭕꭖꭗꭘꭙꭚꭠꭡꭢꭣꭤꭥꭦꭧꭨꭰꭱꭲꭳꭴꭵꭶꭷꭸꭹꭺꭻꭼꭽꭾꭿꮀꮁꮂꮃꮄꮅꮆꮇꮈꮉꮊꮋꮌꮍꮎꮏꮐꮑꮒꮓꮔꮕꮖꮗꮘꮙꮚꮛꮜꮝꮞꮟꮠꮡꮢꮣꮤꮥꮦꮧꮨꮩꮪꮫꮬꮭꮮꮯꮰꮱꮲꮳꮴꮵꮶꮷꮸꮹꮺꮻꮼꮽꮾꮿfffiflffifflſtstﬓﬔﬕﬖﬗabcdefghijklmnopqrstuvwxyz𐐨𐐩𐐪𐐫𐐬𐐭𐐮𐐯𐐰𐐱𐐲𐐳𐐴𐐵𐐶𐐷𐐸𐐹𐐺𐐻𐐼𐐽𐐾𐐿𐑀𐑁𐑂𐑃𐑄𐑅𐑆𐑇𐑈𐑉𐑊𐑋𐑌𐑍𐑎𐑏𐓘𐓙𐓚𐓛𐓜𐓝𐓞𐓟𐓠𐓡𐓢𐓣𐓤𐓥𐓦𐓧𐓨𐓩𐓪𐓫𐓬𐓭𐓮𐓯𐓰𐓱𐓲𐓳𐓴𐓵𐓶𐓷𐓸𐓹𐓺𐓻𐳀𐳁𐳂𐳃𐳄𐳅𐳆𐳇𐳈𐳉𐳊𐳋𐳌𐳍𐳎𐳏𐳐𐳑𐳒𐳓𐳔𐳕𐳖𐳗𐳘𐳙𐳚𐳛𐳜𐳝𐳞𐳟𐳠𐳡𐳢𐳣𐳤𐳥𐳦𐳧𐳨𐳩𐳪𐳫𐳬𐳭𐳮𐳯𐳰𐳱𐳲𑣀𑣁𑣂𑣃𑣄𑣅𑣆𑣇𑣈𑣉𑣊𑣋𑣌𑣍𑣎𑣏𑣐𑣑𑣒𑣓𑣔𑣕𑣖𑣗𑣘𑣙𑣚𑣛𑣜𑣝𑣞𑣟𖹠𖹡𖹢𖹣𖹤𖹥𖹦𖹧𖹨𖹩𖹪𖹫𖹬𖹭𖹮𖹯𖹰𖹱𖹲𖹳") "ⲱⲳⲵⲷⲹⲻⲽⲿⳁⳃⳅⳇⳉⳋⳍⳏⳑⳓⳕⳗⳙⳛⳝⳟⳡⳣⳤⳬⳮⳳⴀⴁⴂⴃⴄⴅⴆⴇⴈⴉⴊⴋⴌⴍⴎⴏⴐⴑⴒⴓⴔⴕⴖⴗⴘⴙⴚⴛⴜⴝⴞⴟⴠⴡⴢⴣⴤⴥⴧⴭꙁꙃꙅꙇꙉꙋꙍꙏꙑꙓꙕꙗꙙꙛꙝꙟꙡꙣꙥꙧꙩꙫꙭꚁꚃꚅꚇꚉꚋꚍꚏꚑꚓꚕꚗꚙꚛꜣꜥꜧꜩꜫꜭꜯꜰꜱꜳꜵꜷꜹꜻꜽꜿꝁꝃꝅꝇꝉꝋꝍꝏꝑꝓꝕꝗꝙꝛꝝꝟꝡꝣꝥꝧꝩꝫꝭꝯꝱꝲꝳꝴꝵꝶꝷꝸꝺꝼꝿꞁꞃꞅꞇꞌꞎꞑꞓꞔꞕꞗꞙꞛꞝꞟꞡꞣꞥꞧꞩꞯꞵꞷꞹꞻꞽꞿꟃꟈꟊꟶꟺꬰꬱꬲꬳꬴꬵꬶꬷꬸꬹꬺꬻꬼꬽꬾꬿꭀꭁꭂꭃꭄꭅꭆꭇꭈꭉꭊꭋꭌꭍꭎꭏꭐꭑꭒꭓꭔꭕꭖꭗꭘꭙꭚꭠꭡꭢꭣꭤꭥꭦꭧꭨꭰꭱꭲꭳꭴꭵꭶꭷꭸꭹꭺꭻꭼꭽꭾꭿꮀꮁꮂꮃꮄꮅꮆꮇꮈꮉꮊꮋꮌꮍꮎꮏꮐꮑꮒꮓꮔꮕꮖꮗꮘꮙꮚꮛꮜꮝꮞꮟꮠꮡꮢꮣꮤꮥꮦꮧꮨꮩꮪꮫꮬꮭꮮꮯꮰꮱꮲꮳꮴꮵꮶꮷꮸꮹꮺꮻꮼꮽꮾꮿfffiflffifflſtstﬓﬔﬕﬖﬗabcdefghijklmnopqrstuvwxyz𐐨𐐩𐐪𐐫𐐬𐐭𐐮𐐯𐐰𐐱𐐲𐐳𐐴𐐵𐐶𐐷𐐸𐐹𐐺𐐻𐐼𐐽𐐾𐐿𐑀𐑁𐑂𐑃𐑄𐑅𐑆𐑇𐑈𐑉𐑊𐑋𐑌𐑍𐑎𐑏𐓘𐓙𐓚𐓛𐓜𐓝𐓞𐓟𐓠𐓡𐓢𐓣𐓤𐓥𐓦𐓧𐓨𐓩𐓪𐓫𐓬𐓭𐓮𐓯𐓰𐓱𐓲𐓳𐓴𐓵𐓶𐓷𐓸𐓹𐓺𐓻𐳀𐳁𐳂𐳃𐳄𐳅𐳆𐳇𐳈𐳉𐳊𐳋𐳌𐳍𐳎𐳏𐳐𐳑𐳒𐳓𐳔𐳕𐳖𐳗𐳘𐳙𐳚𐳛𐳜𐳝𐳞𐳟𐳠𐳡𐳢𐳣𐳤𐳥𐳦𐳧𐳨𐳩𐳪𐳫𐳬𐳭𐳮𐳯𐳰𐳱𐳲𑣀𑣁𑣂𑣃𑣄𑣅𑣆𑣇𑣈𑣉𑣊𑣋𑣌𑣍𑣎𑣏𑣐𑣑𑣒𑣓𑣔𑣕𑣖𑣗𑣘𑣙𑣚𑣛𑣜𑣝𑣞𑣟𖹠𖹡𖹢𖹣𖹤𖹥𖹦𖹧𖹨𖹩𖹪𖹫𖹬𖹭𖹮𖹯𖹰𖹱𖹲𖹳" str2))
      (setq str4 (vl-string-translate (xstrcase "𖹴𖹵𖹶𖹷𖹸𖹹𖹺𖹻𖹼𖹽𖹾𖹿𝐚𝐛𝐜𝐝𝐞𝐟𝐠𝐡𝐢𝐣𝐤𝐥𝐦𝐧𝐨𝐩𝐪𝐫𝐬𝐭𝐮𝐯𝐰𝐱𝐲𝐳𝑎𝑏𝑐𝑑𝑒𝑓𝑔𝑖𝑗𝑘𝑙𝑚𝑛𝑜𝑝𝑞𝑟𝑠𝑡𝑢𝑣𝑤𝑥𝑦𝑧𝒂𝒃𝒄𝒅𝒆𝒇𝒈𝒉𝒊𝒋𝒌𝒍𝒎𝒏𝒐𝒑𝒒𝒓𝒔𝒕𝒖𝒗𝒘𝒙𝒚𝒛𝒶𝒷𝒸𝒹𝒻𝒽𝒾𝒿𝓀𝓁𝓂𝓃𝓅𝓆𝓇𝓈𝓉𝓊𝓋𝓌𝓍𝓎𝓏𝓪𝓫𝓬𝓭𝓮𝓯𝓰𝓱𝓲𝓳𝓴𝓵𝓶𝓷𝓸𝓹𝓺𝓻𝓼𝓽𝓾𝓿𝔀𝔁𝔂𝔃𝔞𝔟𝔠𝔡𝔢𝔣𝔤𝔥𝔦𝔧𝔨𝔩𝔪𝔫𝔬𝔭𝔮𝔯𝔰𝔱𝔲𝔳𝔴𝔵𝔶𝔷𝕒𝕓𝕔𝕕𝕖𝕗𝕘𝕙𝕚𝕛𝕜𝕝𝕞𝕟𝕠𝕡𝕢𝕣𝕤𝕥𝕦𝕧𝕨𝕩𝕪𝕫𝖆𝖇𝖈𝖉𝖊𝖋𝖌𝖍𝖎𝖏𝖐𝖑𝖒𝖓𝖔𝖕𝖖𝖗𝖘𝖙𝖚𝖛𝖜𝖝𝖞𝖟𝖺𝖻𝖼𝖽𝖾𝖿𝗀𝗁𝗂𝗃𝗄𝗅𝗆𝗇𝗈𝗉𝗊𝗋𝗌𝗍𝗎𝗏𝗐𝗑𝗒𝗓𝗮𝗯𝗰𝗱𝗲𝗳𝗴𝗵𝗶𝗷𝗸𝗹𝗺𝗻𝗼𝗽𝗾𝗿𝘀𝘁𝘂𝘃𝘄𝘅𝘆𝘇𝘢𝘣𝘤𝘥𝘦𝘧𝘨𝘩𝘪𝘫𝘬𝘭𝘮𝘯𝘰𝘱𝘲𝘳𝘴𝘵𝘶𝘷𝘸𝘹𝘺𝘻𝙖𝙗𝙘𝙙𝙚𝙛𝙜𝙝𝙞𝙟𝙠𝙡𝙢𝙣𝙤𝙥𝙦𝙧𝙨𝙩𝙪𝙫𝙬𝙭𝙮𝙯𝚊𝚋𝚌𝚍𝚎𝚏𝚐𝚑𝚒𝚓𝚔𝚕𝚖𝚗𝚘𝚙𝚚𝚛𝚜𝚝𝚞𝚟𝚠𝚡𝚢𝚣𝚤𝚥𝛂𝛃𝛄𝛅𝛆𝛇𝛈𝛉𝛊𝛋𝛌𝛍𝛎𝛏𝛐𝛑𝛒𝛓𝛔𝛕𝛖𝛗𝛘𝛙𝛚𝛜𝛝𝛞𝛟𝛠𝛡𝛼𝛽𝛾𝛿𝜀𝜁𝜂𝜃𝜄𝜅𝜆𝜇𝜈𝜉𝜊𝜋𝜌𝜍𝜎𝜏𝜐𝜑𝜒𝜓𝜔𝜖𝜗𝜘𝜙𝜚𝜛𝜶𝜷𝜸𝜹𝜺𝜻𝜼𝜽𝜾𝜿𝝀𝝁𝝂𝝃𝝄𝝅𝝆𝝇𝝈𝝉𝝊𝝋𝝌𝝍𝝎𝝐𝝑𝝒𝝓𝝔𝝕𝝰𝝱𝝲𝝳𝝴𝝵𝝶𝝷𝝸𝝹𝝺𝝻𝝼𝝽𝝾𝝿𝞀𝞁𝞂𝞃𝞄𝞅𝞆𝞇𝞈𝞊𝞋𝞌𝞍𝞎𝞏𝞪𝞫𝞬𝞭𝞮𝞯𝞰𝞱𝞲𝞳𝞴𝞵𝞶𝞷𝞸𝞹𝞺𝞻𝞼𝞽𝞾𝞿𝟀𝟁𝟂𝟄𝟅𝟆𝟇𝟈𝟉𝟋𞤢𞤣𞤤𞤥𞤦𞤧𞤨𞤩𞤪𞤫𞤬𞤭𞤮𞤯𞤰𞤱𞤲𞤳𞤴𞤵𞤶𞤷𞤸𞤹𞤺𞤻𞤼𞤽𞤾𞤿𞥀𞥁𞥂𞥃") "𖹴𖹵𖹶𖹷𖹸𖹹𖹺𖹻𖹼𖹽𖹾𖹿𝐚𝐛𝐜𝐝𝐞𝐟𝐠𝐡𝐢𝐣𝐤𝐥𝐦𝐧𝐨𝐩𝐪𝐫𝐬𝐭𝐮𝐯𝐰𝐱𝐲𝐳𝑎𝑏𝑐𝑑𝑒𝑓𝑔𝑖𝑗𝑘𝑙𝑚𝑛𝑜𝑝𝑞𝑟𝑠𝑡𝑢𝑣𝑤𝑥𝑦𝑧𝒂𝒃𝒄𝒅𝒆𝒇𝒈𝒉𝒊𝒋𝒌𝒍𝒎𝒏𝒐𝒑𝒒𝒓𝒔𝒕𝒖𝒗𝒘𝒙𝒚𝒛𝒶𝒷𝒸𝒹𝒻𝒽𝒾𝒿𝓀𝓁𝓂𝓃𝓅𝓆𝓇𝓈𝓉𝓊𝓋𝓌𝓍𝓎𝓏𝓪𝓫𝓬𝓭𝓮𝓯𝓰𝓱𝓲𝓳𝓴𝓵𝓶𝓷𝓸𝓹𝓺𝓻𝓼𝓽𝓾𝓿𝔀𝔁𝔂𝔃𝔞𝔟𝔠𝔡𝔢𝔣𝔤𝔥𝔦𝔧𝔨𝔩𝔪𝔫𝔬𝔭𝔮𝔯𝔰𝔱𝔲𝔳𝔴𝔵𝔶𝔷𝕒𝕓𝕔𝕕𝕖𝕗𝕘𝕙𝕚𝕛𝕜𝕝𝕞𝕟𝕠𝕡𝕢𝕣𝕤𝕥𝕦𝕧𝕨𝕩𝕪𝕫𝖆𝖇𝖈𝖉𝖊𝖋𝖌𝖍𝖎𝖏𝖐𝖑𝖒𝖓𝖔𝖕𝖖𝖗𝖘𝖙𝖚𝖛𝖜𝖝𝖞𝖟𝖺𝖻𝖼𝖽𝖾𝖿𝗀𝗁𝗂𝗃𝗄𝗅𝗆𝗇𝗈𝗉𝗊𝗋𝗌𝗍𝗎𝗏𝗐𝗑𝗒𝗓𝗮𝗯𝗰𝗱𝗲𝗳𝗴𝗵𝗶𝗷𝗸𝗹𝗺𝗻𝗼𝗽𝗾𝗿𝘀𝘁𝘂𝘃𝘄𝘅𝘆𝘇𝘢𝘣𝘤𝘥𝘦𝘧𝘨𝘩𝘪𝘫𝘬𝘭𝘮𝘯𝘰𝘱𝘲𝘳𝘴𝘵𝘶𝘷𝘸𝘹𝘺𝘻𝙖𝙗𝙘𝙙𝙚𝙛𝙜𝙝𝙞𝙟𝙠𝙡𝙢𝙣𝙤𝙥𝙦𝙧𝙨𝙩𝙪𝙫𝙬𝙭𝙮𝙯𝚊𝚋𝚌𝚍𝚎𝚏𝚐𝚑𝚒𝚓𝚔𝚕𝚖𝚗𝚘𝚙𝚚𝚛𝚜𝚝𝚞𝚟𝚠𝚡𝚢𝚣𝚤𝚥𝛂𝛃𝛄𝛅𝛆𝛇𝛈𝛉𝛊𝛋𝛌𝛍𝛎𝛏𝛐𝛑𝛒𝛓𝛔𝛕𝛖𝛗𝛘𝛙𝛚𝛜𝛝𝛞𝛟𝛠𝛡𝛼𝛽𝛾𝛿𝜀𝜁𝜂𝜃𝜄𝜅𝜆𝜇𝜈𝜉𝜊𝜋𝜌𝜍𝜎𝜏𝜐𝜑𝜒𝜓𝜔𝜖𝜗𝜘𝜙𝜚𝜛𝜶𝜷𝜸𝜹𝜺𝜻𝜼𝜽𝜾𝜿𝝀𝝁𝝂𝝃𝝄𝝅𝝆𝝇𝝈𝝉𝝊𝝋𝝌𝝍𝝎𝝐𝝑𝝒𝝓𝝔𝝕𝝰𝝱𝝲𝝳𝝴𝝵𝝶𝝷𝝸𝝹𝝺𝝻𝝼𝝽𝝾𝝿𝞀𝞁𝞂𝞃𝞄𝞅𝞆𝞇𝞈𝞊𝞋𝞌𝞍𝞎𝞏𝞪𝞫𝞬𝞭𝞮𝞯𝞰𝞱𝞲𝞳𝞴𝞵𝞶𝞷𝞸𝞹𝞺𝞻𝞼𝞽𝞾𝞿𝟀𝟁𝟂𝟄𝟅𝟆𝟇𝟈𝟉𝟋𞤢𞤣𞤤𞤥𞤦𞤧𞤨𞤩𞤪𞤫𞤬𞤭𞤮𞤯𞤰𞤱𞤲𞤳𞤴𞤵𞤶𞤷𞤸𞤹𞤺𞤻𞤼𞤽𞤾𞤿𞥀𞥁𞥂𞥃" str3))
      (setq strn str4)
  strn
Now I don't know where is the problem... Small letter "" clearly exist in my first string - you can search it with ctrl+F when you copy the code...
M.R. on Youtube
ribarm
« Reply #25 on: June 23, 2021, 04:44:13 AM »
And these examples with alphabets are even worse...
Command: (lstrcase "ЙЦУКЕНГШЩЗХҐФИВАПРОЛДЖЄЯЧСМІТЬБЮЇ" t)
"ԝ4Ԟԝ426ԝ423ԝ4aԝ45ԝ4dԝ43ԝ428ԝ42Ԟԝ47ԝ425ԝ4Ԟԝ424ԝ48ԝ42ԝ4Ԟԝ4fԝ42Ԟԝ4eԝ4bԝ44ԝ46ԝ44ԝ42fԝ427ԝ42ԝ4cԝ46ԝ422ԝ42cԝ4ԝ42eԝ47"
Command: (lstrcase "АБВГДЂЕЖЗИЈКЛЉМНЊОПРСТЋУФХЦЧЏШ" t)
"ԝ4Ԟԝ4ԝ42ԝ43ԝ44ԝ42ԝ45ԝ46ԝ47ԝ48ԝ48ԝ4aԝ4bԝ4Ԟԝ4cԝ4dԝ4aԝ4eԝ4fԝ42Ԟԝ42ԝ422ԝ4bԝ423ԝ424ԝ425ԝ426ԝ427ԝ4fԝ428"
M.R. on Youtube
d2010
« Reply #26 on: June 23, 2021, 04:58:03 AM »
Perhaps , Autodesk do not expand more LISP function/s.
But is time for improve all already exists function/s LISP and repair all functionLISP that exists in AutoCad
 :-P
I wouldn't except anything new on the Lisp front anytime soon. If AutoDesk didn't have to support it and fix large issues, I'm sure they wouldn't.
VovKa
  • Ukraine
« Reply #27 on: June 23, 2021, 05:20:23 AM »
lisp does not support unicode
d2010
« Reply #28 on: June 23, 2021, 05:40:27 AM »
I am agree, because the VLIDE is INTREPRETOR, using Unicode.chars , the speed will be  slow-down , more down of speed of to  Low0speed  of Lisp.
 :blink:
Even windows10 slow down the speed , when you use Unicode.Chars!<
Quote from: VovKa link=topic=55041.msg605248#msg605248
date=1624440023
mhupp
« Reply #29 on: June 23, 2021, 09:56:11 AM »
LOL this 100% remember updating to like AutoCAD2016 and the wipeout command didn't work like the last years version when printing to PDF you could still see bits of what you used it on. When I submitted a bug report Autocad response was either use last years version or wait til next release to see if its fixed. thats when we switched over to BricsCAD
