CAD Forums > Vertically Challenged
Aerial images to FBX
(1/1)
lamarn:
Hi all, i'm having a small challenge to get aerial images into Navisworks for use in BIMcollab isuues software. The only way i can do sthis is by means of FBX as fileformat. However, to only (Autodesk) software i see capable of to do that is to use Infraworks. Using that piece of software gives me little control for orientation and maipulation for output of the FBX. I'm not really a big fan of Infraworks. So it seems really hard to get some (essential!!) aerial photos into my 'infra BIM workflow'. Especially when you all routes cut of the use of any normal Autocad way to this kind of visualisation.
Does anyone know if Blender of other software turn google maps like images into FBX? Would be great to have them drapped over a DTM, but not is not necessary.
Thanks !
mjfarrell:
https://docs.blender.org/manual/en/latest/data_system/files/import_export.html
nobody:
--- Quote from: lamarn on January 15, 2019, 05:36:17 PM ---Hi all, i'm having a small challenge to get aerial images into Navisworks for use in BIMcollab isuues software. The only way i can do sthis is by means of FBX as fileformat. However, to only (Autodesk) software i see capable of to do that is to use Infraworks. Using that piece of software gives me little control for orientation and maipulation for output of the FBX. I'm not really a big fan of Infraworks. So it seems really hard to get some (essential!!) aerial photos into my 'infra BIM workflow'. Especially when you all routes cut of the use of any normal Autocad way to this kind of visualisation.
Thanks !
--- End quote ---
Sketchup pro will do it.
Navigation
[0] Message Index
Go to full version
