I'm revising a dwg that I didn't create. There are alot of mleaders, and the box for the mtext seems to be the same for all of them. Many are one line of text, or hard wrapped multi-line, but the box is much larger than needed. This creates a problem when masking because the mask it too large. I have tried double-clicking the ruler to shrink the box, but it reverts back to the original height when I exit the command.
I don't see a "defined height" setting in the properties window like with mtext.
If anyone has a good solution to fix this, I would love to know what it is.
