Author Topic: If statement. Layer gets made but color won't set.  (Read 4864 times)
jlogan02
« on: November 16, 2018, 05:33:47 PM »
I can't figure out why in the second "progn" the layer will get made, but it's color won't get set to 136.
  1.
  2. (if (tblsearch "LAYER" "FiberMgt_136") ;Check if the layer exists
  3.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  4.    (command "_chprop" fm136 "" "p" "la" "FiberMgt_136" "" (command)(command))
  5. ) ;End if progn?
  6.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  7.    (command "._Layer" "Make" "FiberMgt_136" "_Color" "136" "" "" (command)(command));;[b]Color won't set here. The layer gets made and objects get moved to the layer. But the color is White:[/i]
  8.    (command "_chprop" fm136 "" "p" "la" "Fibermgt_136" "" (command)(command))
  9.  ) ;End if progn
  10.  ) ;End of if
  11.
  12.     (setvar 'osmode osm)
  13.     (princ)
  14. )
J. Logan
ACAD 218
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
jlogan02
Re: If statement. Layer gets made but color won't set.
« Reply #1 on: November 16, 2018, 05:55:45 PM »
Edit: All of this works fine but my approach is wonky. The FiberMgt layers will only exist on a building equipment plan. There's another portion of the code (not shown) which deals with changing objects from their bylayer color to a construction/rev color. Those changes occur on the building equipment plan and a multitude of schematics, wiring diagrams and etc. As it stands now the code below will create the FiberMgt layer on every type of drawing if the layer doesn't exist.
I don't want that. I want it to do everything it's doing just not on every type of drawing.
Title Block is attributed - Could I...
(if (attribute "titleline4" reads Building Plan
(do the deed
or
(if (block FM insert exists
(do the deed
or is there something more I can add to what I have?
End Edit:
Never mind
Using Chprop doesn't require the "P" in it. Removed it and all is fine.
  1. (if (tblsearch "LAYER" "FiberMgt_136") ;Check if the layer exists
  2.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  3.    (command "_chprop" fm136 "" "la" "FiberMgt_136" "" (command)(command))[i]Removed "P" here[/i]
  4. ) ;End if progn?
  5.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  6.    (command "._Layer" "Make" "FiberMgt_136" "_Color" "136" "" "" (command)(command))
  7.    (command "_chprop" fm136 "" "la" "FiberMgt_136" "" (command)(command))[i]Removed "P" here[/i]
  8.  ) ;End if progn
  9.  ) ;End of if
« Last Edit: November 16, 2018, 07:08:51 PM by jlogan02 »
J. Logan
ACAD 2018
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #2 on: November 16, 2018, 06:55:47 PM »
Does this work for you.
  1.
  2. (setq OldLayerName "AAC"
  3.       NewLayerName "ABCD"
  4.       LayerColor   "136"
  5.       fm136        (ssget "_X" (list (cons 8 OldLayerName)))
  6. )
  7.
  8. (if (not (= (atoi LayerColor)
  9.             (cdr (assoc 62 (tblsearch "LAYER" NewLayerName)))
  10.          )
  11.     )
  12.   (command "._Layer" "_Make" NewLayerName "_Color" LayerColor "" "")
  13. )
  14. (if fm136
  15.   (command "_chprop" fm136 "" "_la" NewLayerName "")
  16. )
  17.
Called Kerry in my other life
I live at UTC + 13.00
jlogan02
« Reply #3 on: November 19, 2018, 05:14:36 PM »
That worked find Kdub.
Using this code gets me the value of the tag "SUBJECTCODE" in the attribute "TBLK_ATT_CTL"
  1.
  2.
  3. (defun c:FOO (/ LM:GetAttributeValue ss attValue)
  4.
  5.   (defun LM:GetAttributeValue (blk tag / val enx)
  6.     (while
  7.       (and
  8.         (null val)
  9.         (= "ATTRIB"
  10.            (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk))))))
  11.         )
  12.       )
  13.        (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
  14.          (setq val (cdr (assoc 1 enx)))
  15.        )
  16.     )
  17.   )
  18.
  19.   (setq ss (ssget "x" '((0 . "INSERT") (2 . "TBLK_ATT_CTL") (66 . 1))))
  20.   (setq attValue (LM:GetAttributeValue (ssname ss 0) "SUBJECTCODE"))
  21.
  22. (if (ATTRIBUTE TAG VALUE = 90????
  23.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  24.    (command "_chprop" fm136 "" "la" "FiberMgt_136" "" (command)(command))
  25. ) ;End if progn?
  26.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  27.    (command "._Layer" "Make" "FiberMgt_136" "_Color" "136" "" "" (command)(command))
  28.    (command "_chprop" fm136 "" "la" "FiberMgt_136" "" (command)(command))
  29.  ) ;End if progn
  30.  ) ;End of if
  31.   (princ)
  32. )
  33. )
Here's where I'm not having any luck. Seems to me, once I verify the attribute value is "90" I should be able to..
(if (subject code is "90"...
do stuff...
If (subject code isn't "90"...
Don't do stuff..
but I'm stuck.
J. Logan
ACAD2018
J. Logan
ACAD 2018
« Reply #4 on: November 19, 2018, 05:38:09 PM »
(if (= attValue "90")
Or:
(if (= (atoi attValue) 90)
kdub_nz
  • SuperMod
« Reply #5 on: November 19, 2018, 05:42:10 PM »
and :
are you certain the value will represent an integer ??
jlogan02
« Reply #6 on: November 19, 2018, 06:33:08 PM »
Lee, I swear to god I tried that!!! Going to try again.
And yes Kdub, it always will. Now it could represent many different integer's, but I'm looking specifically for "90".
J. Logan
ACAD 2018
J. Logan
ACAD 2018
jlogan02
« Reply #7 on: November 19, 2018, 07:25:30 PM »
Works, but doesn't work...
It will do as expected but doesn't honor the (if (= attValue 90)
It skips that line of code.
  1.
  2. (defun c:FOO (/ LM:GetAttributeValue ss attValue)
  3.
  4.   (defun LM:GetAttributeValue (blk tag / val enx)
  5.     (while
  6.       (and
  7.         (null val)
  8.         (= "ATTRIB"
  9.            (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk))))))
  10.         )
  11.       )
  12.        (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
  13.          (setq val (cdr (assoc 1 enx)))
  14.        )
  15.     )
  16.   )
  17.
  18.   (setq cl56 (ssget "x" '((62 . 56)(0 . "LINE,POLYLINE,LWPOLYLINE,TEXT,MTEXT"))))
  19.     (command "_chprop" cl56 "" "C" "136" "" (command)(command))
  20.
  21.   (setq ss (ssget "x" '((0 . "INSERT") (2 . "TBLK_ATT_CTL") (66 . 1))))
  22.   (setq attValue (LM:GetAttributeValue (ssname ss 0) "SUBJECTCODE")) ?????DO I have this line right ????
  23.
  24. (if (= attValue 90)
  25.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  26.    (command "._Layer" "Make" "FiberMgt_136" "_Color" "136" "FiberMgt_136" "" (command)(command))
  27.    (command "_chprop" fm136 "" "P" "LA" "FiberMgt_136" "" (command)(command))
  28. ) ;End if progn?
  29.    (setq fm136 (ssget "x" '((8 . "FiberMgt_56"))))
  30.    (command "._Layer" "Make" "FiberMgt_136" "_Color" "136" "FiberMgt_136" "" (command)(command))
  31.    (command "_chprop" fm136 "" "P" "LA" "FiberMgt_136" "" (command)(command))
  32.  ) ;End if progn
  33.  ) ;End of if
  34.   (princ)
  35. )
Edit Below:
I also get this message from the <Build  Output> window when I "Check TEXT in Editor"
[CHECKING TEXT FM136.lsp loading...]
; warning: local variable used as function: LM:GETATTRIBUTEVALUE
; Check done.
J. Logan
ACAD 2018
« Last Edit: November 19, 2018, 07:29:24 PM by jlogan02 »
J. Logan
ACAD 2018
« Reply #8 on: November 20, 2018, 08:14:31 AM »
The variable attValue will always be a string (or nil), therefore the test should be either:
(= attValue "90")or:
Per my earlier response.
; Check done.
This is only a warning and will not affect the code operation, but the warning appears because you have declared the LM:GetAttributeValue as a symbol local to c:FOO. You can safely remove LM:GetAttributeValue from the list of local variables, as there is no need for this function to be local unless you have another (different) definition of the same function in the document namespace (which I highly doubt).
i.e.:
Can become:
(/ cl56 fm136 ss attValue)
(I've added your other variables)
jlogan02
« Reply #9 on: November 20, 2018, 12:11:50 PM »
Thanks for the help Lee. I'm just too old for this shite.
I changed...
  1. (setq attValue (LM:GetAttributeValue (ssname ss 0) "SUBJECTCODE"))
to
  1. (setq attValue (LM:GetAttributeValue (ssname ss 0) "TITLELINE4"))
and went with...
  1. (if (= attValue "BUILDING EQUIPMENT PLAN")
all works fine. the TitleLine4 and SubjectCode tags are the same thing. One can't be different from the other. All works fine this way.
J. Logan
ACAD2018
J. Logan
ACAD 2018
« Reply #10 on: November 20, 2018, 12:26:19 PM »
Good stuff  :-)
jlogan02
« Reply #11 on: November 21, 2018, 03:50:05 PM »
Damn!!! Discovered I need to add another attValue...
I needed to add Interior Elevations.
  2.
  3.   (if (= attValue "EQUIPMENT PLAN")
  4.    (progn
  5.     (setq fm1 (ssget "x" '((8 . "FiberMgt_1"))))
  6.      (command "._Layer" "Make" "FiberMgt_56" "_Color" "56" "FiberMgt_56" "" (command)(command))
  7.      (command "_chprop" fm1 "" "P" "LA" "FiberMgt_56" "" (command)(command))
  8.     );End if progn
So I added a second
Would that be the correct method? It seems to work. EDIT: No it doesn't
  1.       (= attValue "INTERIOR ELEVATIONS")
  2.       (setq fm1 (ssget "x" '((8 . "FiberMgt_1"))))
  3.      (command "._Layer" "Make" "FiberMgt_56" "_Color" "56" "FiberMgt_56" "" (command)(command))
  4.      (command "_chprop" fm1 "" "P" "LA" "FiberMgt_56" "" (command)(command))
  5.     ) ;End if progn
  6.    ) ;End of if
J. Logan
ACAD2018
« Last Edit: November 21, 2018, 04:01:40 PM by jlogan02 »
J. Logan
ACAD 2018
« Reply #12 on: November 21, 2018, 05:14:45 PM »
With multiple conditions, the cond function becomes more applicable, e.g.:
  1.     (   (= attValue "EQUIPMENT PLAN")
  2.         (setq fm1 (ssget "_x" '((8 . "FiberMgt_1"))))
  3.         ;; ... etc.
  4.     )
  5.     (   (= attValue "INTERIOR ELEVATIONS")
  6.         (setq fm1 (ssget "x" '((8 . "FiberMgt_1"))))
  7.         ;; ... etc.
  8.     )
  9. )
jlogan02
« Reply #13 on: November 26, 2018, 03:05:07 PM »
Perfect. Thanks Lee.
J. Logan
ACAD 2018
« Reply #14 on: November 26, 2018, 04:01:07 PM »
Since it appears you are changing the same properties for both conditions you could use wcmatch as well:
  1. (cond ((wcmatch (strcase attvalue) "EQUIPMENT PLAN,INTERIOR ELEVATIONS")
  3.        (command "._Layer" "Make" "FiberMgt_56" "_Color" "56" "FiberMgt_56" "" (command) (command))
  4.        (command "_chprop" fm1 "" "P" "LA" "FiberMgt_56" "" (command) (command))
  5.       )                                 ;End if prog
  6. )
