Author Topic: Don't drain theswamp ( Signatures )  (Read 4867 times)
« on: June 06, 2005, 01:51:45 pm »
Help keep this place as fast as possible and easy to read by reducing your Signature(sig) text in font size and remove all graphics.
To reduce the text size wrap your sig with the BBcode tag "size=". Example:
[size=9]This is my sig[/size]
Which will be rendered as (  This is my sig  ).
You can still have URL's in your sig. Example:
[size=9]This is my [url=http://www.google.com]favorite search engine[/url][/size]
Which will be rendered as (  This is my favorite search engine  ).
Also keep the number of lines to a minimum, remember most of us run very high resolutions thus it takes a very long line of text before it wraps.
Tip: Add the version of acad you use to your sig, this helps when you seek answers about acad, lisp or vba.
