Author Topic: Lisp Help  (Read 1641 times)
renkor
Lisp Help
« on: September 11, 2018, 01:06:57 PM »
Hello, I have one lisp that was made to align objects to a reference without displacemente. But i can only select one object and i would like to be able to select some objects with a selection box.
Could it be possible? thanks.
(defun C:RotTo (/ var ev getobj :angle2UCS ent obj ang-in ang-to)
  (defun :angle2UCS (ang / ucs)
    (setq ucs (- ang (angle '(0 0 0) (getvar "UCSXDIR"))))
    (if (< ucs 0.) (setq ucs (+ ucs (* 2 PI))))
    ucs)
    (defun VAR (typ) ; build variable name with number
    (read (strcat typ num))
  (defun EV (typ) ; evaluate what's in variable name with number
    (eval (read (strcat typ num)))
    ;GETOBJ from ReportAngle.LSP by Kent Cooper, 11/2011, edited for UCS
  (defun GETOBJ (esel num / edata etype subedata subetype path pt1 pt2)
    (while (not (and (setq edata (if esel (entget (car esel)))
   etype (if esel (cdr (assoc 0 edata))))
     (set (var "pick"); = pick1 or pick2
  (osnap (cadr esel) "nea")); for (vlax-curve) later; also prohibits things like text elements of Dimensions
     (wcmatch etype "ARC,LINE,*POLYLINE,@LINE,RAY,INSERT,HATCH,DIMENSION,LEADER,*SOLID,3DFACE,WIPEOUT,TRACE,REGION,IMAGE,VIEWPORT,TOLERANCE")
     (or (wcmatch etype "ARC,*POLYLINE")
(not (osnap (ev "pick") "cen")))    ; if Polyline/Block/Region/3DSolid/angular Dimension, not on arc/ellipse segment or circle/arc/ellipse element
       ((= etype "INSERT")
(and (setq subedata (entget (car (nentselp (ev "pick"))))            ; then, use nested object -- same checks as above, except:
   subetype (cdr (assoc 0 subedata)))                        ; no center Osnap check [earlier check covers it] ; no Insert or heavy Polyline object types [never returned by (nentselp)]
     (wcmatch subetype "LINE,LWPOLYLINE,VERTEX,@LINE,RAY,HATCH,DIMENSION,LEADER,*SOLID,3DFACE,WIPEOUT,TRACE,REGION,IMAGE,VIEWPORT,TOLERANCE")
     (if (= subetype "LEADER") (= (cdr (assoc 72 subedata)) 0) T); STraight, not Splined
     (if (= subetype "VERTEX") (= (boole 1 8 (cdr (assoc 70 subedata))) 0) T))); not Splined 2DPolyline
       ((= etype "LEADER") (= (cdr (assoc 72 edata)) 0)); STraight, not Splined
       ((= etype "POLYLINE") (= (boole 1 4 (cdr (assoc 70 edata))) 0)); not Splined 2DPolyline
       (T)))) ; all other object types
      (prompt "\nNothing selected, or not a straight object with linearity --")
      (exit)); while
    (cond ((wcmatch etype "ARC") ;arc
   (setq path (car esel))
   (set (var "ang")   ; = ang1 or ang2
(angle (setq pt1 (vlax-curve-getStartPoint path))
       (setq pt2 (vlax-curve-getEndPoint path))))
   (grdraw (trans pt1 0 1) (trans pt2 0 1) 7 -1))
  ((and (wcmatch etype "*POLYLINE") ;arc segment of polyline
(angle (setq pt1 (vlax-curve-getPointAtParam path (fix (vlax-curve-getParamAtPoint path (trans (ev "pick") 1 0)))))
       (setq pt2 (vlax-curve-getPointAtParam path (1+ (fix (vlax-curve-getParamAtPoint path (trans (ev "pick") 1 0))))))))
  ((wcmatch etype "POLYLINE,XLINE,RAY"); vlax-curve-applicable types
(angle '(0 0 0)
       (vlax-curve-getFirstDeriv path (vlax-curve-getParamAtPoint path (trans (ev "pick") 1 0))))))
  (T
(angle (setq pt2 (trans (osnap (ev "pick") (if (= subetype "RAY") "nea" "mid")) 1 0))     ; account for Ray in Block [no midpoint]
       (setq pt1 (trans (osnap (ev "pick") (if (= subetype "XLINE") "nea" "end")) 1 0)))) ; account for Xline in Block [no endpoint]
   (grdraw (trans pt1 0 1) (trans pt2 0 1) 7 -1)))
    (set (var "ang") (+ (ev "ang") PI))
    (if (> (ev "ang") (* 2 PI))   (set (var "ang") (- (ev "ang") (* 2 PI))))
    (ev "ang")
  (if (and (setq ent (ssget "_+.:E:S"))
           (setq ent (ssname ent 0))
           (setq obj (vlax-ename->vla-object ent))
           (setq pnt (getpoint "\nReference point: "))
           (or (not (vl-catch-all-error-p (setq ang-in (vl-catch-all-apply 'vla-get-rotation (list obj)))))
               (setq ang-in 0.))
           (or (setq ang-to (getangle "\nSpecify final angle <by object>: "))
               (setq ang-to (:angle2UCS (getobj (entsel "\nSelect to aling to: ") "1"))))
      (if (/= (cdr (assoc 0 (entget ent))) "MTEXT")
        (setq ang-in (:angle2UCS ang-in)))
    (command "_.ROTATE" ent "" "_none" pnt "_R" (angtos ang-in (getvar 'AUNITS) 8) (angtos ang-to (getvar 'AUNITS) 8))))
tombu
  • ByLayer=>Not0
Re: Lisp Help
« Reply #1 on: September 11, 2018, 02:52:44 PM »
RotateObjects to match angle of curve or any other object's angle by alanjt might be worth taking a look at.
https://www.theswamp.org/index.php?topic=40450.0
Tom Beauford P.S.M.
renkor
Re: Lisp Help
« Reply #2 on: September 11, 2018, 03:14:37 PM »
Hello
Thanks for replying. It's a good lisp, but it only works for texts and blocks, and i would need it for all objects (lines, polylines...)
The code i shared do it, but just object by object, no by selection box.
BIGAL
  • 40 + years of using Autocad
Re: Lisp Help
« Reply #3 on: September 13, 2018, 07:36:13 AM »
Renkor you have not posted all the code "defun GETOBJ (esel num" the num is no where in the code you posted the esel I guess is from entsel.
renkor
Re: Lisp Help
« Reply #4 on: September 14, 2018, 04:22:54 AM »
Hello Bigal
Yes, it is the full code. Maybe there are some useless information and functions.
Regards.
