Author Topic: Nil function definition when key is pressed  (Read 2810 times)
cmwade77
« on: July 23, 2018, 06:21:06 PM »
I am working on rewriting a routine and whenever I press a key, I keep getting the following error: ** Error: no function definition: nil **
Here is the code I have so far, I am not sure what is causing this, any ideas?
Edit: I figured that out, but for some reason F10 causes an error, it doesn't toggle polar mode.
(defun c:uleader (/ *ThisDrawing* *Space* *Scale* *IsCivil* *Path* *Prompt* *Align* *Match* *Types* Pt1 Pt2 Input Data Code Ent1 POS)
    (vl-cmdf "._-insert" "Uleader.dwg")(command); Insert in leader styles
    (setq *Types* (LIST "MTEXT" "1M08" "PL08" "AH08" "CFM" "FXU" "GPM" "PANEL" "FEEDER"))
    ;Supporting Functions
    (defun eraseold (obj /) ;Erases the previous version of a VLA object - Code modifcation provided by ronjonp at http://www.theswamp.org/index.php?topic=54340.msg589085#msg589085
        (and (= 'vla-object (type obj))
            (not (vlax-erased-p obj))
            (vlax-write-enabled-p obj)
            (vla-delete obj)
    (defun GetVportScale ()
        (/ 1 (vla-get-CustomScale (vla-get-ActivePViewport (vla-get-activedocument (vlax-get-acad-object)))))
    (defun PolarRound (ang deg)
        (* (/ pi (/ 180 (r2d deg))) (fix (/ (+ (/ pi (/ 360 (r2d deg))) ang) (/ pi (/ 180 (r2d deg))))))
    (defun bitcodef (value bit)
        ;; Originally Written by Lee Ambrosius on: 6/6/04
        ;; Modified by Chris Wade 1/13/2010
        (if (zerop(logand bit value))
            nil
            T
    ) ;defun bitcode
    (defun D2R (numberOfDegrees)
        (* pi (/ numberOfDegrees 180.0))
    ) ;_ end of defun
    (defun R2D (nbrOfRadians)
        (* 180.0 (/ nbrOfRadians pi))
    ;End of Supporting Functions
    (setq *Path* (getvar "dwgprefix")
          *ThisDrawing* (vla-get-activedocument (vlax-get-acad-object)) ;_ Set Drawing and Space
      *Space*
            (if (zerop (vla-get-activespace *ThisDrawing*))
                (if (= (vla-get-mspace *ThisDrawing*) :vlax-true)
                    (vla-get-modelspace *ThisDrawing*) ; active VP
                    (vla-get-paperspace *ThisDrawing*)
(If (> (strlen *path*) 5);Determine if this is a civil drawing
(setq pos (vl-string-position (ascii "\\") *Path* (+ (vl-string-position (ascii "\\") *path* 5) 1)))
(If (or (= (strcase (substr *path* (+ pos 8) 1)) "C") (= (getvar "USERS5") "CIVIL"))
(setq *IsCivil* T)
    (if (zerop (vla-get-activespace *ThisDrawing*)); Set scale
            (setq *Scale* (GetVportScale))
            (setq *Scale* 1.0)
        (setq *Scale* (getvar "DimScale"))
    (vla-StartUndoMark *ThisDrawing*)
    ;ERROR HANDLER
    (defun *error* (msg)
        (if mlObj
                (vla-highlight mlObj :vlax-false)
                (EraseOld mlObj)
        ;; Added by Pkenewell on 3/28/2014
        (vla-EndUndoMark *ThisDrawing*)
        (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
            (princ (strcat "\n** Error: " msg " **"))
    (if (not (tblsearch "LAYER" "LEADER")) ; Check to see if layer exists
(if (= 1 (getvar "pstylemode"))
(command "._-layer" "n" "LEADER" "color" "WHITE" "" "lweight" "DEFAULT" "" "ltype" "CONTINUOUS" "" "")
(command "._-layer" "n" "LEADER" "color" "WHITE" "" "lweight" "DEFAULT" "" "ltype" "CONTINUOUS" "" "pstyle" "BLACK" "" "")
(setvar "annoautoscale" 4)
(while (not Pt1)
    (initget "Select _Select")
    (setq Pt1 (getpoint "\nPick starting point of leader [Select leader]:"))
        ((= Pt1 "Select")
            (while (not Ent1)
                (setq Ent1 "\nSelect leader to modify or align to:")
                (if (not Ent1)
                    (princ "\r*** You must select a leader ***")
                (setq Pt1 (cadr Ent1))
(if (not Ent1)
    (setq Ent1 (nentselp "" Pt1))
(if Ent1
    (progn ;If existing leader is selected allow for modifying or aligning to the leader
        (princ "\nAdd code for modifying/aligning leader here")
    (progn ;If existing leader is not selected, draw a new leader
        (while (not Pt2)
            (setq *Prompt* "\rSpeciy second point [Content ")
            (if (or (not *Content*) (= *Content* ""))
                (setq *Content* "MTEXT")
            (setq *Prompt* (strcat *Prompt* "(" *Content* ")"))
            (if *Note*
                (setq *Prompt* (strcat *Prompt* "/** Note **"))
                (setq *Prompt* (strcat *Prompt* "/Note"))
            (if *Typ*
                (setq *Prompt* (strcat *Prompt* "/** Typical **"))
                (setq *Prompt* (strcat *Prompt* "/Typical"))
            (if (not *POC*)
                (setq *Prompt* (strcat *Prompt* "/Poc(d)"))
                (setq *Prompt* (strcat *Prompt* *POC*))
            (setq *prompt* (strcat *Prompt* "/Arrowheads/Exit]:"))
            (if *Align*
                (setq *Prompt* (strcat *Prompt* " " *Align*))
            (if *Match*
                (setq *Prompt* (strcat *Prompt* " " *Match*))
            (princ *Prompt*)
                (setq Input (grread t 4 4)
                      Data (cadr Input)
                      Code (car Input)
                    ((= Code 2);Handle all keypresses
                            ((= data 15); Change Orthomode when F8 is pressed
                                (if (= (getvar "orthomode") 1)
        (setvar "orthomode" 0)
        (setvar "orthomode" 1)
                            ((= data 21); Toggle Polarmode when F10 is pressed
        (setvar "autosnap" (bitcodef (getvar "autosnap") 8))
        ((or (= data 67) (= data 99))
            (setq POS (vl-position *Content* *Types*))
            (if (< POS (length *Types*))
                (setq *Content* (nth (+ POS 1) *Types*))
                (setq *Content* (nth 0 *Types*))
« Last Edit: July 23, 2018, 06:27:53 PM by cmwade77 »
kpblc
Re: Nil function definition when key is pressed
« Reply #1 on: July 24, 2018, 01:05:54 AM »
I think error is in string
  1. (command "._-layer" "n" "LEADER" "color" "WHITE" "" "lweight" "DEFAULT" "" "ltype" "CONTINUOUS" "" "pstyle" "BLACK" "" "")
There is no option "pstyle" (ACAD2018):
Command: ._-layer
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]:
Sorry for my English.
cmwade77
« Reply #2 on: July 24, 2018, 11:41:25 AM »
No, that one is quite correct when using style based plotting and not color based plotting and the if statement checks to make sure if style based or color based plotting is used.
No, the only issue with the posted code is pressing F10 causes an error at present. It should toggle polar snapping on and off, not cause an error.
« Reply #3 on: July 24, 2018, 01:24:38 PM »
A few things jump out:
  1.     (defun bitcodef (value bit)
  2.         ;; Originally Written by Lee Ambrosius on: 6/6/04
  3.         ;; Modified by Chris Wade 1/13/2010
  4.         (if (zerop(logand bit value))
  5.             nil
  6.             T
  7.         );;
  8.     ) ;defun bitcode
Could be written more succinctly as:
  1. (defun bitcodef ( v b ) (< 0 (logand b v)))
  1.     (defun PolarRound (ang deg)
  2.         (* (/ pi (/ 180 (r2d deg))) (fix (/ (+ (/ pi (/ 360 (r2d deg))) ang) (/ pi (/ 180 (r2d deg))))))
  3.     )
  4.     (defun D2R (numberOfDegrees)
  5.         (* pi (/ numberOfDegrees 180.0))
  6.     ) ;_ end of defun
  7.     (defun R2D (nbrOfRadians)
  8.         (* 180.0 (/ nbrOfRadians pi))
  9.     )
These functions are not evaluated anywhere in the code and could therefore be removed.
  1.         *Space*
  2.             (if (zerop (vla-get-activespace *ThisDrawing*))
  3.                 (if (= (vla-get-mspace *ThisDrawing*) :vlax-true)
  4.                     (vla-get-modelspace *ThisDrawing*) ; active VP
  5.                     (vla-get-paperspace *ThisDrawing*)
  6.                 )
  7.                 (vla-get-modelspace *ThisDrawing*)
  8.             )
This could be written more succinctly as:
  1.         *Space* (vlax-get-property *ThisDrawing* (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
This:
  1. (if (= (getvar "orthomode") 1)
  2.     (setvar "orthomode" 0)
  3.     (setvar "orthomode" 1)
  4. )
Could become:
  1. (setvar 'orthomode (- 1 (getvar 'orthomode)))
This:
  1. (setvar "autosnap" (bitcodef (getvar "autosnap") 8))
Should be changed to the following to XOR bit 8:
  1. (setvar 'autosnap (boole 6 8 (getvar 'autosnap)))
Since your bitcodef function will return a boolean value, not an integer.
An error of 'no function definition: nil' would indicate that you are attempting to evaluate a symbol with no value as a function, however, I can't see anywhere in your code where this is occurring. As such, I would suggest following this process to determine the line on which the code fails.
cmwade77
« Reply #4 on: July 24, 2018, 01:30:35 PM »
Sorry, I should have mentioned the code is a work in progress, the functions that aren't currently being called will be in the end code. And as always, thank you Lee, lots of great info. And I as I mentioned about, I got rid of the nil error, it was stupidity on my part not adding a (cond) that should have been there.
gile
  • Marseille, France
« Reply #5 on: July 24, 2018, 01:42:00 PM »
Not so often... ;)
  1. *Space* (vla-get-Block (vla-get-ActiveLayout *ThisDrawing*))
« Reply #6 on: July 24, 2018, 01:48:11 PM »
This won't return Modelspace for an active Paperspace viewport...  :wink:
cmwade77
« Reply #7 on: July 24, 2018, 01:49:08 PM »
Gile, your code is a very close second to Lee's as to how often it appears in our routines. Honestly, I think you have had some solutions that no one else could have solved. In the end this will be a complex piece of code, but I hope to get it working more reliably than my old uleader routine, so starting off with these recommendations is very helpful.
« Reply #8 on: July 24, 2018, 01:49:47 PM »
You're welcome Chris, the F10 issue should be solved when you implement my suggestion:
cmwade77
« Reply #9 on: July 24, 2018, 02:05:53 PM »
Ok, I have implemented several of the recommendations so far and made some tweaks, as well as added some additional code, so here is where things stand now:
(defun c:uleader (/ *ThisDrawing* *Space* *Scale* *IsCivil* *Path* *Prompt* *Align* *Match* *Types* *Style* *POC* *POCS* *Typ* *Note* Pt1 Pt2 Input Data Code Ent1 POS Pt1Tst)
          *POCS* (list nil "-Poc" "-Pod")
            (vla-delete obj)
    ) ;_ end of defun
      *Space* (vlax-get-property *ThisDrawing* (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)); Code adjustment from Lee Mac at: http://www.theswamp.org/index.php?topic=54349.msg589159#msg589159
      *Scale* (if (zerop (vla-get-activespace *ThisDrawing*))
                            (GetVportScale)
                            1.0
                        (getvar "DimScale")
    (setq *IsCivil* T)
            (setq *Scale* 1.0)
    ;ERROR HANDLER
        (if mlObj
                (EraseOld mlObj)
(while (not Pt1)
        ((= Pt1 "Select")
            (while (not Ent1)
                (if (not Ent1)
(if (not Ent1)
(if Ent1
        (while (not Pt2)
            (If (= *Content* "MTEXT")
                    (if *IsCivil*
                        (setq *Arrowheads* (list "CIVIL" "BEIOB-R1" "BEINOB-R1" "BOX-R1" "LOOP-R1" "BEISPL"))
                        (setq *Arrowheads* (list "BEIOB-R1" "BEINOB-R1" "BOX-R1" "LOOP-R1" "BEISPL"))
                    (if *IsCivil*
                        (setq *Arrowheads* (list "CIVIL" "BEIOB-R1" "BEINOB-R1" "BOX-R1" "LOOP-R1"))
                        (setq *Arrowheads* (list "BEIOB-R1" "BEINOB-R1" "BOX-R1" "LOOP-R1"))
            (setq *Prompt* (strcat "\rSpecify second point [Content (" *Content* ")"))
            (if (or (not *Style*) (= *Style* ""))
                (setq *Style* (nth 0 *Arrowheads*))
            (if (and (/= *Content* "1M08") (/= *Content* "MTEXT"))
                    (if *Note*
                (if (/= *Content* "MTEXT")
                    (if *Typ*
            (if (not *POC*)
                (setq *Prompt* (strcat *Prompt* "/" (substr *POC* 2)))
            (setq *prompt* (strcat *Prompt* "/Arrowheads (" *Style* ")/Exit]:"))
            (if *Align*
            (if *Match*
            (princ *Prompt*)
                      Data (cadr Input)
                      Code (car Input)
                                ;Code adjustment from Lee at http://www.theswamp.org/index.php?topic=54349.msg589159#msg589159
        ((or (= data 65) (= data 97)); Change arrowheads when A is pressed
            (setq POS (vl-position *Style* *Arrowheads*))
            (if (< POS (length *Arrowheads*))
                (setq *Style* (nth (+ POS 1) *Arrowheads*))
        ((or (= data 67) (= data 99)); Change content when C is pressed
        ((or (= data 80) (= data 112)); Cycle through Point of connection/disconnection when P is pressed
            (setq POS (vl-position *POC* *POCS*))
            (if (< POS (length *POCS*))
                (setq *POC* (nth (+ POS 1) *POCS*))
                (setq *POC* (nth 0 *POCS*))
        ((and (or (= data 78) (= data 110)) (/= *Content* "1M08") (/= *Content* "MTEXT")); Change Note when N is pessed
            (if *Note*
                (setq *Note* nil)
                (setq *Note* T)
        ((and (or (= data 84) (= data 116)) (/= *Content* "MTEXT")); Change Typical when T is pessed
            (if *Typ*
                (setq *Typ* nil)
                (setq *Typ* T)
I will have more changes coming, but I am wondering if there are things I can do to simplify this code further.
cmwade77
« Reply #10 on: July 24, 2018, 03:04:17 PM »
As promised, here is more, for some reason when I put the style to the leader, the leader always ends at 0,0, does anyone have an idea as to why?
(defun c:uleader (/ *ThisDrawing* *Space* *Scale* *IsCivil* *Path* *Prompt* *Align* *Match* *Types* *Style* *POC* *POCS* *Typ* *Note* *NewPoints* *MlObj* Pt1 Pt2 FxPt Input Data Code Ent1 POS Pt1Tst)
            (vla-delete obj)
    ) ;_ end of defun
                            (GetVportScale)
                            1.0
                        (getvar "DimScale")
(setq newpoints (vlax-make-safearray vlax-vbDouble '(1 . 6)))
    (setq *IsCivil* T)
            (setq *Scale* 1.0)
    ;ERROR HANDLER
        (if mlObj
                (EraseOld mlObj)
(while (not Pt1)
        ((= Pt1 "Select")
            (while (not Ent1)
                (if (not Ent1)
(vlax-safearray-put-element newpoints 1 (car pt1))
(vlax-safearray-put-element newpoints 2 (cadr pt1))
(vlax-safearray-put-element newpoints 3 (caddr pt1))
(if (not Ent1)
(if Ent1
    (if (/= (cdr (assoc 0 (entget (car Ent1)))) "MULTILEADER")
            (setq *STYLE* "BEIOB-R1"
                  Ent1 nil
        (setq *STYLE* "BEINOB-R1")
(if Ent1
        (while (not Pt2)
                    (if *IsCivil*
                    (if *IsCivil*
                    (if *Note*
                    (if *Typ*
            (if (not *POC*)
            (setq *prompt* (strcat *Prompt* "/Arrowheads (" *Style* ")]:"))
            (if *Align*
            (if *Match*
            (princ *Prompt*)
                      Data (cadr Input)
                      Code (car Input)
            (if *Note*
                (setq *Note* nil)
                (setq *Note* T)
            (if *Typ*
                (setq *Typ* nil)
                (setq *Typ* T)
                    ((= Code 5)
                        (setq FxPt (trans data 1 0))
                        (EraseOld *MlObj*)
                        (vlax-safearray-put-element newpoints 4 (car FxPt))
(vlax-safearray-put-element newpoints 5 (cadr FxPt))
(vlax-safearray-put-element newpoints 6 (caddr FxPt))
(setq *MlObj* (vla-AddMleader *Space* newpoints 0))
(vla-put-stylename *MlObj* *Style*);Something appears to be wrong with this line, it causes the leader to always end at 0,0
(vla-put-layer *MlObj* "LEADER")
