Author Topic: 3D HVAC model and separating layouts for each level  (Read 9481 times)
HVACGuy
« on: June 11, 2018, 06:47:53 AM »
I need some help me with a 3D question...
When you have a building with something like a Ground floor, First floor and a Roof and you are creating a 3D model of the lot... How do you separate each level so that the layout is seen for each level? I am stuck on this. Do you know where there is a forum or video on this?
Thanks.
ivanstarr
  • Mosquito
Re: 3D HVAC model and separating layouts for each level
« Reply #1 on: June 19, 2024, 02:39:04 PM »
You could separate it by elevation if it's 3D.  Otherwise, why not use different layers?
danAllen
« Reply #2 on: June 19, 2024, 03:59:54 PM »
I've never used it, but I think you can set front & back 3d clipping planes using DVIEW command in the viewport.
