Author Topic: Xref Image thru Lisp  (Read 4701 times)
0 Members and 4 Guests are viewing this topic.
GDF
Re: Xref Image thru Lisp
« Reply #15 on: May 02, 2018, 07:20:54 PM »
 :smitten:
GDF
« Reply #16 on: May 02, 2018, 09:16:52 PM »
Just playing around with the enclosed routine, and was wondering how to rename the raster images to their ".png" file name?
I'm getting names like: "OAImg-4702128" in lieu of "Vicinity Map"
The code works great as is.
(defun C:IMG-vicinity   (/ d pvicinity i p)
  (setq d (vla-get-activedocument (vlax-get-acad-object)))
  (setvar "ctab" "A0-0 COVER")
  (setvar 'filedia 0)
  (setq i "V")
    (and (findfile (setq f (strcat (getvar 'dwgprefix)
               (car   (vl-remove-if-not
                 '(lambda (x) (wcmatch x (strcat i "*")))
                 '("Vicinity Map.png")
    (setq pvicinity '(3.85156 14.0 0.0))
    (vlax-invoke (vla-get-paperspace d) 'addraster f pvicinity 10.0 0.0)
    (print (strcat f " NOT FOUND!!!"))
  (setvar 'filedia 1)
(defun C:IMG-aerial   (/ d paerial i p)
  (setvar 'filedia 0)
  (setq i "A")
                 '("Aerial Image.png")
    (setq paerial '(3.85156 2.39844 0.0))
    (vlax-invoke (vla-get-paperspace d) 'addraster f paerial 10.0 0.0)
  (setvar 'filedia 1)
(defun C:IMG-front   (/ d pfront i p)
  (setvar 'filedia 0)
  (setq i "F")
                 '("Front Elevation.png")
    (setq pfront '(19.4766 2.39844 0.0))
    (vlax-invoke (vla-get-paperspace d) 'addraster f pfront 10.0 0.0)
  (setvar 'filedia 1)
(C:IMG-FRONT)
(C:IMG-AERIAL)
(C:IMG-VICINITY)
« Reply #17 on: May 03, 2018, 08:58:25 AM »
Are you talking about the name in the xref manager?
Something like this should consolidate those 3 routines:
  1. (defun c:images (/ d i o)
  2.   (cond
  3.     ((vl-position "A0-0 COVER" (mapcar 'strcase (layoutlist)))
  4.      (setvar 'ctab "A0-0 COVER")
  5.      (setvar 'filedia 0)
  6.      (initget 0 "V A F")
  7.      (setq i (cond ((getkword "\nXref Images[Vicinity Map/Aerial image/Front elevation] <V>: "))
  8.                    ("V")
  9.              )
  10.      )
  11.      (cond ((and (setq i (assoc i
  12.                                 '(("V" "Vicinity Map.png" (3.85156 14. 0.))
  13.                                   ("A" "Aerial Image.png" (3.85156 2.39844 0.))
  14.                                   ("F" "Front Elevation.png" (19.4766 2.39844 0.))
  15.                                  )
  16.                          )
  17.                  )
  18.                  (findfile (cadr i))
  19.                  (setq o (vlax-invoke (vla-get-paperspace d) 'addraster (cadr i) (last i) 10. 0.))
  20.             )
  21.             (vl-catch-all-apply 'vla-put-name (list o (vl-filename-base (cadr i))))
  22.            )
  23.            ((print (strcat (cadr i) " NOT FOUND!!!")))
  24.      )
  25.      (setvar 'filedia 1)
  26.     )
  27.     ((alert "TAB 'A0-0 COVER' DOES NOT EXIST!"))
  28.   )
  29.   (princ)
« Last Edit: May 03, 2018, 09:34:31 AM by ronjonp »
GDF
« Reply #18 on: May 03, 2018, 09:21:15 AM »
Thanks again RON
GDF
« Reply #19 on: May 03, 2018, 09:21:46 AM »
Yes the name in the xref manager.
« Reply #20 on: May 03, 2018, 09:34:51 AM »
Thanks again RON
You're welcome Gary :)
« Reply #21 on: May 03, 2018, 09:39:41 AM »
Code updated above to rename in the xref manager. Be aware that that sometimes the name does not update in the xref manager palette, but it should be renamed.
GDF
« Reply #22 on: May 03, 2018, 09:46:39 AM »
SWEET...works perfectly
Thanks again
« Reply #23 on: May 03, 2018, 10:38:08 AM »
Thanks again
Anytime Gary :)
« Reply #24 on: May 03, 2018, 12:25:25 PM »
If you rename an xref / image def thru code you can force it to update in the xref palette by forcing a reload (vla-reload block_or_image_def).
« Reply #25 on: May 03, 2018, 12:34:48 PM »
Good to know .. thanks! :)
« Reply #26 on: May 03, 2018, 12:43:05 PM »
My pleasure, I do it all the time.
