Author Topic: Xref Image thru Lisp  (Read 4706 times)
GDF
« on: May 02, 2018, 09:38:53 AM »
I'm looking to xref an image thru a lisp routine. Any ideas?
(setvar "filedia" 0)
(setenv "XLOADPATH" (getvar "dwgprefix"))
name of image  "Front Elevation.png"
(command "-xref"...
I have tried XATTACH, IMAGEATTACH...with no luck.
Re: Xref Image thru Lisp
« Reply #1 on: May 02, 2018, 09:43:44 AM »
Set FILEDIA to 0 then use IMAGEATTACH.
GDF
« Reply #2 on: May 02, 2018, 09:48:34 AM »
I tried that and get this message...
GDF
« Reply #3 on: May 02, 2018, 09:55:18 AM »
Ok, this works...but I'm looking to do it without opening any dialog boxes.
(defun C:TEST ()
  (setvar "ctab" "A0-0 COVER")
  (command "IMAGEATTACH" "Front Elevation.png")
  (princ))
GDF
« Reply #4 on: May 02, 2018, 10:09:19 AM »
This is the best I can do...
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Xref Images Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun C:Images ()
  (initget 1 "V A F")
  (setq tmp (getkword "\n* Xref Images: [V]icinity map   [A]erial image   [F]ront elevation *"))
  (if (not tmp)
    (setq tmp "P"))
  (cond ((= "V" tmp) (command "IMAGEATTACH" "Vicinity Map.png"))
        ((= "A" tmp) (command "IMAGEATTACH" "Aerial Image.png"))
        ((= "F" tmp) (command "IMAGEATTACH" "Front Elevation.png")))
  (setvar "filedia" 1)
  (princ))
« Reply #5 on: May 02, 2018, 12:15:32 PM »
Gary,
Look at the method 'AddRaster'.
Code - Text: [Select]
  1. (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  2. (setq spc (vla-get-ModelSpace doc))
  3. (vlax-invoke spc 'AddRaster <path> (getpoint) 1. 0.)
  4.
« Reply #6 on: May 02, 2018, 12:15:36 PM »
No time to play but here's a little snip ...
(setq
    owner           (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
    imageName       "c:\\legit_path\\legit_file_name.cal"
    insertionPoint '(0.0 0.0 0.0)
    scalefactor     1.0
    rotationAngle   0.0
(vlax-invoke owner 'AddRaster imageName insertionPoint scalefactor rotationAngle)
« Reply #7 on: May 02, 2018, 12:55:57 PM »
And some more food for thought :)
  1.
  2. (defun c:images (/ d f i p)
  3.   (cond
  4.     ((vl-position "A0-0 COVER" (mapcar 'strcase (layoutlist)))
  5.      (setvar 'ctab "A0-0 COVER")
  6.      (setvar 'filedia 0)
  7.      (initget 0 "V A F")
  8.      (setq i (cond ((getkword "\nXref Images[Vicinity Map/Aerial image/Front elevation] <V>: "))
  9.                    ("V")
  10.              )
  11.      )
  12.      (if
  13.        (and
  14.          (findfile (setq f (strcat (getvar 'dwgprefix)
  15.                                    (car (vl-remove-if-not
  16.                                           '(lambda (x) (wcmatch x (strcat i "*")))
  17.                                           '("Vicinity Map.png" "Aerial Image.png" "Front Elevation.png")
  18.                                         )
  19.                                    )
  20.                            )
  21.                    )
  22.          )
  23.          (setq p (getpoint "\nPick a point to place image: "))
  24.        )
  25.         (vlax-invoke (vla-get-paperspace d) 'addraster f p 1. 0.)
  26.         (print (strcat f " NOT FOUND!!!"))
  27.      )
  28.      (setvar 'filedia 1)
  29.     )
  30.     (alert "Tab 'A0-0 COVER' DOES NOT EXIST!")
  31.   )
  32.   (princ)
  33. )
« Last Edit: May 03, 2018, 09:03:00 AM by ronjonp »
GDF
« Reply #8 on: May 02, 2018, 01:40:26 PM »
As soon as I get home I’ll try them out
GDF
« Reply #9 on: May 02, 2018, 02:44:44 PM »
Ron, your routine works like mine. I would like to set the image without the dialog box...Setting the insertion point, scale etc thru lisp.
Tim and MP, your routine works, but the image is not displaying.
« Reply #10 on: May 02, 2018, 05:43:22 PM »
I think Tim and MP's code is not working for you because you're inserting on a paperspace tab and their examples are using modelspace.
« Reply #11 on: May 02, 2018, 05:48:43 PM »
Updated above to use addraster.
GDF
« Reply #12 on: May 02, 2018, 06:33:24 PM »
Slapping my face now...
GDF
« Reply #13 on: May 02, 2018, 07:03:37 PM »
Ron, what is spc
(vlax-invoke (vla-get-paperspace spc) 'addraster f p 1. 0.)
« Reply #14 on: May 02, 2018, 07:16:00 PM »
Ron, what is spc
Oops. .. updated above.
