Author Topic: Import Blocks fails (tweak LM code)  (Read 1558 times)
lamarn
« on: April 19, 2018, 05:55:17 PM »
Hi
I am writing something with the use of Lee Mac block [insert block routine] to insert some stamp as blocks.
http://www.lee-mac.com/copyblockfromdrawing.html
I've written the subroutines. These work well. However, what i want is to place these subroutines in a main routine (different departments)
I can't get it to work passing to the next phase. Anybody have a clue where this might hang? To be honest , the code Lee writes is just above my league.
Attached is a screenshot of this problem with the succesful ending of dialog.
subroutine that works
(defun c:HI_PARAAF_tbb (/ *error* abc blk dbx dch dcl des doc dwg ins itm lst)
    (VL-LOAD-COM)
    (defun *error* (msg)
        (if (and (= 'vla-object (type dbx)) (not (vlax-object-released-p dbx)))
            (vlax-release-object dbx)
        (if (= 'file (type des))
            (close des)
        (if (and (= 'str (type dcl)) (findfile dcl))
            (vl-file-delete dcl)
        (if (< 0 dch)
            (unload_dialog dch)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
    (setq dwg "C:\\_Data\\Heijmans\\AutoCAD_Tool\\user\\parafen-TBB.dwg")    ; THIS CAN BE DIFFERENT DWG'S DEPENDING ON A CHOICE
        ((= (strcase dwg)
            (strcase
                (vla-get-fullname
                    (setq doc (vla-get-activedocument (vlax-get-acad-object)))
         (princ " ")
        ((not (setq dbx (LM:GetDocumentObject dwg))) (princ " "))
        ((progn (vlax-for def (vla-get-blocks dbx)
                    (if (and (= :vlax-false (vla-get-isxref def))
                             (= :vlax-false (vla-get-islayout def))
                             (not (wcmatch (vla-get-name def) "`**,*|*"))
                        (setq lst (cons (vla-get-name def) lst))
                (not (setq
                         lst (vl-sort
                                 (vl-remove-if '(lambda (x) (tblsearch "block" x))
                                               lst
         (princ "\nNo distinct TBB blocks found in selected drawing.")
        ((not
             (and
                 (setq dcl (vl-filename-mktemp nil nil ".dcl"))
                 (setq des (open dcl "w"))
                 (write-line
                     "importblock : dialog { label = \"Select TBB Block to Import\"; spacer;"
                     des
                 (write-line ": list_box { key = \"lst\"; } spacer; ok_cancel; }"
                             des
                 (not (setq des (close des)))
                 (< 0 (setq dch (load_dialog dcl)))
                 (new_dialog "importblock" dch)
         (princ "\nUnable to load \"Import Block\" dialog.")
        (t
         (start_list "lst")
         (foreach itm lst (add_list itm))
         (end_list)
         (set_tile "lst" (setq itm "0"))
         (action_tile "lst" "(setq itm $value)")
         (if (= 1 (start_dialog))
             (if (and
                     (not (vl-catch-all-error-p
                              (vl-catch-all-apply
                                  'vlax-invoke
                                  (list dbx
                                        'copyobjects
                                        (list (LM:getitem
                                                  (setq blk (nth (atoi itm) lst))
                                        (setq abc (vla-get-blocks doc))
                     (LM:getitem abc blk)
                 )  (if (setq ins (getpoint "\nSpecify point for TBB block: "))
                        (vla-insertblock
                            (vlax-get-property doc
                                               (if (= 1 (getvar 'cvport))
                                                   'paperspace
                                                   'modelspace
                            (vlax-3D-point (trans ins 1 0))
                            blk
                            1.0
                            1.0
                            1.0
                            (angle '(0.0 0.0)
                                   (trans (getvar 'ucsxdir)
                                          0
                                          (trans '(0.0 0.0 1.0) 1 0 t)
                                          t
                        (princ "\nUnable to import TBB block from selected drawing.")
             (princ "\n*Cancel*")
    (*error* nil)
Part that fails..
There is some conflict with this menu code that interrupts the code above.
(defun PARAAFSETMMMENU ()
    (setq DCL_ID
             (load_dialog
                 " .. support\\PARAAF_menu.dcl" ; A STANDARD BUTTON DIALOG
    (if (not (new_dialog "PARAAF_menu" DCL_ID))
        (progn (alert "File PARAAF_menu.dcl not found.") (exit)) ;progn
    ) ;_ end of if
    (action_tile "PARAAFSET_tbb" "(PARAAFSET_tbb) (done_dialog 1)")
    (action_tile "cancel" "(setq cancel t)(done_dialog)")
    (start_dialog)
(defun c:HI_PARAAF_MENU
       (/ *error* OLDERR abc blk dbx dch dcl des doc dwg ins itm lst)
    (graphscr)
    (setq  PARAAFSETTBBS NIL
          CANCEL nil
    ) ;_ end of setq
    (PARAAFSETMMMENU)
    (if PARAAFSETTBBS
        (cond ((= SEL 4) (PARAAFSET_TBB)))                                  ; THIS DOES NOT WORKING, FAILING TO END DIALOG SUCCESFUL)
    (if CANCEL
        (princ "\nPROGRAM CANCELLED!")
    ) ;_ end of if
(defun PARAAFSET_TBB () (setq PARAAFSETTBBS t)  (c:HI_PARAAF_tbb))     ; THIS WORKS
« Last Edit: April 19, 2018, 06:15:48 PM by lamarn »
roy_043
  • BricsCAD 18
Re: Import Blocks fails (tweak LM code)
« Reply #1 on: April 20, 2018, 04:28:17 AM »
I have not looked at your video. To close a DCL dialog you would use the done_dialog function. It is unclear how the SEL variable receives its value. Perhaps some actions are defined in the DCL and you forgot to include a call to done_dialog there?
lamarn
« Reply #2 on: April 20, 2018, 09:37:15 AM »
The dialog indeed does not close properly
I can't figure out how this is done in order to start the next defun normal.
1. (action_tile "PARAAFSET_m" "(PARAAFSET_m) (done_dialog) ")   ; next function does not work
2. (action_tile "PARAAFSET_m" "(done_dialog) (PARAAFSET_m)")   ; does not close  the dialog
3. (action_tile "PARAAFSET_m" "(PARAAFSET_m) (exit)")               ; kills everything
(done_dialog [status])
status
Type: Integer
A positive integer that start_dialog will return instead of returning 1 for OK or 0 for Cancel. The meaning of any status value greater than 1 is determined by your application. [/i]
4. (action_tile "PARAAFSET_m"  "(c:HI_PARAAF_we) (done_dialog 2) ") ; same as 1.
5. (term_dialog)   ; same as 2.
« Last Edit: April 20, 2018, 09:46:50 AM by lamarn »
roy_043
  • BricsCAD 18
« Reply #3 on: April 21, 2018, 06:53:38 AM »
I have watched the movie now and IMO there are many inconsistencies. But I'll only address the problem that is preventing the code from working.
  1. (defun PARAAFSETMMMENU ( / dcl ret)
  2.   (if
  3.     (or
  4.       (and
  5.         (<
  6.           0
  7.           (setq dcl
  8.             (load_dialog "PARAAF_menu.dcl") ; A STANDARD BUTTON DIALOG
  9.           )
  10.         )
  11.         (new_dialog "PARAAF_menu" dcl)
  12.       )
  13.       (progn
  14.         (alert "Problem with the PARAAF_menu dialog")
  15.         (exit)
  16.       )
  17.     )
  18.     (progn
  19.       ; (action_tile "cancel"      "(done_dialog 0)") ; This is the default action.
  20.       ; (action_tile "accept"      "(done_dialog 1)") ; This is the default action.
  21.       (action_tile "kunstwerken" "(done_dialog 2)")
  22.       (action_tile "tbb"         "(done_dialog 3)")
  23.       (action_tile "wegen"       "(done_dialog 4)")
  24.       ; etc.
  25.       (setq ret (start_dialog))
  26.       (unload_dialog dcl)
  27.       (cond
  28.         ((= ret 2) "KUNSTWERKEN")
  29.         ((= ret 3) "TBB")
  30.         ((= ret 4) "WEGEN")
  31.         ; etc.
  32.       )
  33.     )
  34.   )
  35. )
  36.
  37. (defun c:HI_PARAAF_MENU ( / opt)
  38.   (setq opt (PARAAFSETMMMENU))
  39.   (cond
  40.     ((= opt "KUNSTWERKEN")
  41.       ; Do something
  42.     )
  43.     ((= opt "TBB")
  44.       ; Do something
  45.     )
  46.     ((= opt "WEGEN")
  47.       ; Do something
  48.     )
  49.     ; etc.
  50.   )
  51.   ; ...
  52.   ; ...
  53.   (princ)
  54. )
lamarn
« Reply #4 on: April 22, 2018, 04:52:07 PM »
Thanks for your help.
Posted a 'full working version' in the zip for somebody else. :)
lamarn
« Reply #5 on: April 23, 2018, 05:17:43 PM »
Regarding the original code of mr. Lee. http://www.lee-mac.com/copyblockfromdrawing.html
How to make the 'NOT' part of the work as 'OR' ?
Would be really good to have some insert regardless if it was allready 'stolen' or not.
-------------------------=={ Import Block }==-------------------------
  This program allows a user to import a block from a selected
  drawing into the active drawing, without opening the external file.
  Upon calling the program with 'IB' at the command line, the user
  is prompted to select a drawing file from which to source the
  block to be imported.
  Following a valid response, a dialog is displayed prompting the
  user to select a block from the list of blocks defined in the
  selected drawing *NOT* (WISH FOR : OR) already present in the current drawing.
  Following selection, the definition of the chosen block is imported
  into the drawing and the user is prompted to specify a block
  insertion point at which a block reference of the imported block
  is inserted.
  The program will perform successfully in all UCS/Views and is also
  compatible with Dynamic Blocks.
  Author:  Lee Mac, Copyright © 2013  -  www.lee-mac.com
  Version 1.2    -    16-06-2013
(   (progn
                        (and
                (not (setq lst (vl-sort[b][i] (vl-remove-if '(lambda ( x ) (tblsearch "block" x)) lst)[/i][/b] '<)))
            (princ "\nNo distinct blocks found in selected drawing.")
This part? (vl-remove-if '(lambda ( x ) (tblsearch "block" x))
