Hi to all,
I have a question regarding ROTATE command... When I use that command and firstly specify angle, the next time I run it again CAD prompts last used value informing me that I can repeat last input automatically... The problem is when I use some random mouse clicked rotation angle, the angle next time shows up, but rounded to 8 digits and I've checked real angle is at 15 digits precision... So the question - how can I retrieve that angle or how can I force displaying at 15 decimal digits... Either answer is welcomed - right now as it is it is programmed at 8 digits :
Command: ROTATE
Current positive angle in UCS: ANGDIR=counterclockwise ANGBASE=0.00000000
Select objects: Specify opposite corner: 1 found
Select objects:
Specify base point: _endp of
Specify rotation angle or [Copy/Reference] <45.00000000>:
