Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Error in vlax-3d-point
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Error in vlax-3d-point (Read 2143 times)
@_Bilal
Mosquito
on:
March 05, 2018, 04:22:37 PM »
Hello,
Could some one help me to fix this error or explain to me why I get this error
"Error: Automation Error. UCS X axis and Y axis are not perpendicular" when
runing the below routine, noting that the the 2 segments are perpendicular.
Code - Auto/Visual Lisp:
[Select]
defun
ucsadd
ORg Xpt Ypt NAME
acaddoc_obj ucs_obj item
vl-load-com
;; V^V
;; Cross product of two vectors
defun
v
v
u v
list
cadr
u
caddr
v
caddr
u
cadr
v
caddr
u
car
v
car
u
caddr
v
car
u
cadr
v
cadr
u
car
v
;; Endof//v^v
;; Calculate the yptp which is perpendicular to segment Org and Xpt
;; u and v vectors
setq
u
list
car
Xpt
car
ORg
cadr
Xpt
cadr
ORg
caddr
Xpt
caddr
ORg
setq
v
list
car
Ypt
car
ORg
cadr
Ypt
cadr
ORg
caddr
Ypt
caddr
ORg
setq
z
v
v u v
;; calculate z vector
setq
Yptp
v
v z u
;;;Start adding UCS
setq
acaddoc_obj
vla-get-activedocument
vlax-get-acad-object
setq
ucs_obj
vla-get-UserCoordinateSystems
acaddoc_obj
setq
item
vla-add
ucs_obj
vlax-3d-point
org
;;origin
vlax-3d-point
Xpt
;;x axis point
vlax-3d-point
Yptp
;;y axis point
name
;;name
;_ end of vla-add
;_ end of setq
princ
;; Endof//ucsadd
Logged
Stefan
Bull Frog
The most I miss IRL is the Undo button
Re: Error in vlax-3d-point
Reply #1 on:
March 05, 2018, 05:09:50 PM »
Xpt is in WCS and Yptp is relative to origin.
Change this line
Code:
[Select]
(setq Yptp (mapcar '+ org (v^v z u)))
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Reply #2 on:
March 05, 2018, 05:12:34 PM »
Try changing this line :
[Select]
setq
Yptp
v
v z u
To this :
[Select]
setq
Yptp
mapcar
ORg
v
v z u
Note that your Yptp in your code is vector, and you need point at position of ORg + vector...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
@_Bilal
Mosquito
Reply #3 on:
March 05, 2018, 05:33:46 PM »
Thank you very much Ribarm and Stefan
I changed this line, the routine and i get accurate result
I understand where was my fault
thanks again
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
