Dear Guys,
Now i try to develop an function for joining two arcs at there tangential point. First of all, how to find this point on an fast way. Based on the true, the small arc below (Arc2) the longe one on top (Arc2) is the one which is to be aligned to the other, by rotating at the point P1.
The way to 'cut' the Arc2 into several segments or calcolate a lot of points along this and than verify each one of this by using the vlax-curve-getClosestPointTo methode seems to be to slow. Also if you'll find the closest Point, its not the tangential point when i want to join this both curves tangential.
Maybee its more easy to find this point while constructing the 2. arc. If there are some ideas, may this wouls also help.
For better understanding. Both arcs have an defined startpoint and an fixed (known) radius. Only the second Point of the Arc2 is unknown.
Afterall i want an figur like second image.
May there are some suggestions, please?
