Author Topic: Write DCL codes to temporary file  (Read 1346 times)
Coder
« on: December 29, 2017, 04:40:54 AM »
Hello everyone.
I am trying to write the codes of DCL to temporary file and everything work very good til now but I am facing a problem in converting the labels ( 14 and 26 ) to inches to show them in buttons with inch value.
Thanks in advance.
": boxed_row { label = \"Specs\";
 : button { label = \"14\";  key = \"wid\";}
 : button { label = \"26\";  key = \"hgt\";}
« Last Edit: December 29, 2017, 04:43:58 AM by Coder »
roy_043
  • BricsCAD 18
Re: Write DCL codes to temporary file
« Reply #1 on: December 29, 2017, 06:33:34 AM »
Maybe this helps:
(vl-prin1-to-string "1'6\"") => "\"1'6\\\"\""
Coder
« Reply #2 on: December 29, 2017, 06:56:06 AM »
Maybe this helps:
Great, thank you so much.
