Hi guys
I found this routine on the web, to rename anonymous blocks, the problem is that in the case of having more than one block I must run the routine for each of the blocks otherwise it does not work, the help I ask is if there is any way to modify the routine in such a way that allows me to make a multiple selection.
Very grateful for the help.;===============================================
; UnAnon.Lsp Jul 05, 1998
(princ "\nCopyright (C) 1998, Fabricated Designs, Inc.")
(princ "\nLoading UnAnon v1.0 ")
(setq uan_ nil lsp_file "UnAnon")
;================== For Automated Calling From Another Program =========
(defun uan_auto (ar1) (UnAnon ar1))
;================== Macros =============================================
(defun PDot ()(princ "."))
(PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++
(defun uan_smd ()
(SetUndo)
(setq olderr *error*
*error* (lambda (e)
(and (/= e "quit / exit abort")
(princ (strcat "\nError: *** " e " *** ")))
(command "_.UNDO" "_END" "_.U")
(uan_rmd))
uan_var '(
("CMDECHO" . 0) ("MENUECHO" . 0) ("MENUCTL" . 0) ("MACROTRACE" . 0)
("OSMODE" . 0) ("SORTENTS" . 119)("MODEMACRO" . ".")
("BLIPMODE" . 0) ("EXPERT" . 0) ("SNAPMODE" . 1) ("PLINEWID" . 0.0)
("ORTHOMODE" . 1) ("GRIDMODE" . 0) ("ELEVATION" . 0) ("THICKNESS" . 0)
("FILEDIA" . 0) ("FILLMODE" . 0) ("SPLFRAME" . 0) ("UNITMODE" . 0)
("TEXTEVAL" . 0) ("ATTDIA" . 0) ("AFLAGS" . 0) ("ATTREQ" . 1)
("ATTMODE" . 1) ("UCSICON" . 1) ("HIGHLIGHT" . 1) ("REGENMODE" . 1)
("COORDS" . 2) ("DRAGMODE" . 2) ("DIMZIN" . 1) ("PDMODE" . 0)
("CECOLOR" . "BYLAYER") ("CELTYPE" . "BYLAYER")))
(foreach v uan_var
(setq m_v (cons (getvar (car v)) m_v)
m_n (cons (car v) m_n))
(setvar (car v) (cdr v)))
(princ (strcat (getvar "PLATFORM") " Release " (substr (ver) 18 2)
" - Convert To Anonymous Blocks ....\n"))
(princ))
(PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++
(defun uan_rmd ()
(setq *error* olderr)
(mapcar 'setvar m_n m_v)
(command "_.UNDO" "_END")
(prin1))
(PDot);++++++++++++ Set And Start An Undo Group ++++++++++++++++++++++++
(defun SetUndo ()
(and (zerop (getvar "UNDOCTL"))
(command "_.UNDO" "_ALL"))
(and (= (logand (getvar "UNDOCTL") 2) 2)
(command "_.UNDO" "_CONTROL" "_ALL"))
(command "_.UNDO" "_END"))
(command "_.UNDO" "_GROUP"))
(PDot);++++++++++++ Get Entity Name ++++++++++++++++++++++++++++++++++++
(defun GetOne (/ st os)
(setq os (getvar "SNAPMODE") s nil)
(setvar "SNAPMODE" 0)
(while (not st)
(setq st (ssget)))
(while (> (sslength st) 1)
(setq st nil)
(princ "\nOnly 1 At A Time Please\n")
(while (not st)
(setq st (ssget))))
(setvar "SNAPMODE" os)
(setq s (ssname st 0)))
(PDot);++++++++++++ Convert An Anonymous Block To Named Block ++++++++++
(defun UnAnon (b / tdef en ed bc bn bd in) ;Supply ename
(setq bn "TEMP1" bc 1)
(while (tblsearch "BLOCK" bn)
(setq bc (1+ bc) bn (strcat "TEMP" (itoa bc))))
(and (= (type b) 'ENAME)
(setq bd (entget b)
in (cdr (assoc 2 bd))))
(if (or (not bd)
(not in)
(/= "INSERT" (cdr (assoc 0 bd)))
(/= "*U" (substr in 1 2))
(= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 4) 4)
(= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 16) 16)
(= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 32) 32))
(princ "*** Not An Anonomymous Block *** ")
(setq bn nil bc nil bd nil in nil b nil)
(exit)))
(setq tdef (tblsearch "BLOCK" in)
en (cdr (assoc -2 tdef))
ed (entget en))
(entmake (list (cons 0 "BLOCK")
(cons 2 bn)
(cons 70 0)
(cons 10 (cdr (assoc 10 tdef)))))
(entmake ed)
(while (setq en (entnext en))
(setq ed (entget en))
(entmake ed))
(entmake (list (cons 0 "ENDBLK")))
(setq bd (subst (cons 2 bn) (assoc 2 bd) bd))
(entmod bd)
(entupd b)
(princ (strcat "\n" bn)))
(PDot);************ Main Program ***************************************
(defun uan_ (/ m_v m_n olderr uan_var s)
(uan_smd)
(GetOne)
(UnAnon s)
(uan_rmd))
(defun c:UnAnonall (/ ss i)
(setq ss (ssget "X" (list (cons 0 "INSERT")(cons 67 (if (= (getvar "TILEMODE") 1) 0 1)))))
(and ss
(setq i (sslength ss))
(while (not (minusp (setq i (1- i))))
(setq en (ssname ss i))
(if (= "*U" (substr (cdr (assoc 2 (entget en))) 1 2))
(UnAnon en))))
(prin1))
(PDot);************ Load Program ***************************************
(defun C:UnAnon () (uan_))
(if uan_ (princ "\nUnAnon Loaded\n"))
(prin1)
;================== End Program ========================================
