Author Topic: Calling ACET-UI-Status to close  (Read 1636 times)
MSTG007
« on: December 13, 2017, 07:38:25 AM »
Just messing around with this.
(acet-ui-status "Attach XREFs\nXREF1  XREF2\nXREF3" "Do the following:")
Is there a way to close this modeless window?
Civil3D 2020
PKENEWELL
Re: Calling ACET-UI-Status to close
« Reply #1 on: December 13, 2017, 01:08:12 PM »
Just call (acet-ui-status) like shown with no arguments and it will close the box.
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
MSTG007
« Reply #2 on: December 13, 2017, 01:13:25 PM »
Any way to control the location it pops up? If not, not a big deal. Sometimes I call the crew command and it’s in the back so I can’t see the box lol. Thank you for sharing. Helps a lot.
Civil3D 2020
MSTG007
« Reply #3 on: December 14, 2017, 08:46:10 AM »
Is there a way I could pause a routine to have the user slide this box to the right so they can see it, then continue with the rest of the routine?
(defun c:SAMPLE()
;;Currently Popups in the middle of the screen
(acet-ui-status "Move Floating information Popup to the right of your screen" "Move this Box Right.")
;;Looking for a way for the user to drag the box to the right before the rest of the routine runs.
;;(command "._delay" 3000);<--3 seconds delay
(command "_pause")
(acet-ui-status "Attach XREFs 1 & 2" "Title")
(command "-layer" "make" "-XREF" "")
(command "_xattach")
); defun
(C:SAMPLE)
Civil3D 2020
PKENEWELL
« Reply #4 on: December 14, 2017, 11:57:04 AM »
I am not aware of any method to move the starting position of the Status box. It will remember it's last position however in the same session as far as I can tell.
Personally I would just note to users that they can move this status box anyplace that's convenient for them.
MSTG007
« Reply #5 on: December 14, 2017, 11:57:42 AM »
Thought I would share my work around...
(defun c:SAMPLE()
(acet-ui-status "Move Floating information Popup to the right of your screen.\nOnce Moved Click Once in Modelspace." "Move this Box Right.")
(command "_.point")
(while (= 1 (logand 1 (getvar 'CMDACTIVE))) (command pause))
(command "erase" (ssget "x" '((0 . "point"))) "")
(acet-ui-status)
); defun
(C:SAMPLE)
Civil3D 2020
PKENEWELL
« Reply #6 on: December 14, 2017, 12:07:19 PM »
Instead of "(command "erase" (ssget "x" '((0 . "point"))) "")", it would be better to use "last" in the command to remove the last entity. What if the user has other points in the drawing that they want to retain?
MSTG007
« Reply #7 on: December 14, 2017, 12:08:39 PM »
ah.... yes. Thank you. But it does work.
Civil3D 2020
