Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Edit Block Attribute
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Edit Block Attribute (Read 1303 times)
amc.dicsac
Newt
Autocad 2008
WWW
on:
December 12, 2017, 01:08:51 PM »
Hello, I have the following code that allows me to select polylines to save the distance and then insert a block with an attribute, but the problem is how I add the distance to the attribute.
Code - Auto/Visual Lisp:
[Select]
defun
c:pee
s i e Long Cadena BlockEsc BlockName Msj_Bloque
vl-load-com
setvar
"cmdecho"
0
setq
s
ssget
0
"ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE"
4
"<NOT"
4
"<AND"
0
"POLYLINE"
4
70
80
4
"AND>"
4
"NOT>"
setq
i
sslength
s
setq
e
ssname
s
setq
i
1-
i
setq
Long
rtos
vlax-curve-getdistatparam
e
vlax-curve-getendparam
e
2
2
setq
Cadena
strcat
"L="
Long
"m"
setq
BlockEsc
"1"
setq
BlockName
"1-DZL-BLOCK PENDIENTE"
setq
Msj_Bloque
strcat
\n
>> Especifica inserción del bloque [ "
BlockName
princ
Msj_Bloque
command
"._insert"
BlockName
"_s"
BlockEsc Cadena
while
logand
getvar
"cmdactive"
1
1
command
pause
setvar
"cmdecho"
1
princ
Logged
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
BIGAL
Swamp Rat
40 + years of using Autocad
Re: Edit Block Attribute
Reply #1 on:
December 13, 2017, 05:45:46 AM »
If you have say a block with a single attribute length then just
Code:
[Select]
(command "-insert" Blockname pt 1 1 0 attributevalue)
Logged
HasanCAD
Swamp Rat
Reply #2 on:
December 13, 2017, 07:45:41 AM »
I belive you have to save the block in a seperete file to call if not exist in file.
filename should has file extention
[Select]
setq
BlockName
"c:/MyBlocks/1-DZL-BLOCK PENDIENTE.dwg"
And this line changed too
[Select]
command
"._insert"
BlockName Msj_Bloque BlockEsc BlockEsc BlockEsc Cadena
Not Tested
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
