Hello all,
I'm working with a developer on a C# plugin for AutoCAD that inserts blocks of a certain geometry to fill a geometry specified by the user. Within the last few months, we noticed an issue on our laptops (same make, model, hardware, etc.) where AutoCAD would either 1) crash, 2) insert the blocks successfully, but remove the dynamic controls for the block, or 3) insert the blocks successfully, but change all annotative objects within the drawing to not annotative.
Prior to completely closing, AutoCAD will provide these two error messages:
INTERNAL ERROR: !dbobji.cpp@720: eInvalidOpenState
or
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at e735bfd0h
After installing Visual Studio on one of the laptops (developer could not recreate the issue due to different machine), we were to debug the issue which showed this error:
AutoCAD error: Unhandled exception at 0x00007FFE5B048363 (ntdll.dll) in acad.exe: 0xC0000374: A heap has been corrupted (parameters: 0x00007FFE5B0A06B0).
I believe the issue is related to the GPU on the laptops as the same program runs just fine on a beefier system. The question I have for you all is if it's possible to reduce the demand on the GPU by changing or including something new in the transaction that adds the blocks? I hope this isn't too vague of a request.
Thank you in advance
