Author Topic: Civil 3d Notes  (Read 4471 times)
nobody
  • .net stuff
Civil 3d Notes
« on: December 10, 2017, 07:34:42 AM »
Is there a feature like the revit key notes in civil 3d?
MSTG007
Re: Civil 3d Notes
« Reply #1 on: December 11, 2017, 06:59:29 AM »
Not that I am aware of... Its interesting you bringing that up. I have had an idea kinda like that for Civil Plan Sheets. Where the Note Bubble links to the keynotes. But as you select an object via xref. It would read the layer name or something to know what it is called.
Like I said, its an idea just playing around with. Good Question though.
Civil3D 2020
Re: Civil 3d Notes
« Reply #2 on: December 11, 2017, 08:36:24 AM »
One might be able to implement something using sheet set manager and call out block(s)....but I imagine it would be tedious and or cumbersome.
Re: Civil 3d Notes
« Reply #3 on: December 11, 2017, 09:59:03 AM »
I submitted this idea to the Civil 3D Idea station a few years ago. It has been accepted, no telling when it will actually be implemented. Why it takes so long to do so is a bit baffling, since the code is all there already in the AEC base code which C3D uses for many other things.
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/adding-construction-notes-bubble-notes/idi-p/5785353
Re: Civil 3d Notes
« Reply #4 on: December 11, 2017, 10:01:12 AM »
They haven't figured out how to muck it up yet....as soon as they do it will be a new nuisance to deal with.
nobody
  • .net stuff
Re: Civil 3d Notes
« Reply #5 on: December 12, 2017, 02:14:26 AM »
Appreciate the feedback guys, thanks!
