Author Topic: Is it possible to recreate hatch boundary with c#  (Read 4117 times)
nobody
  • .net stuff
« on: November 23, 2017, 03:30:35 AM »
Anyone know any tricks to recreate hatch boundary from hatch?
n.yuan
Re: Is it possible to recreate hatch boundary with c#
« Reply #1 on: November 23, 2017, 09:43:26 AM »
If you have already had a known Hatch, shouldn't is boundarys (loops) be also known?
Assume you have a simple Hatch with only outloop (no island in it), you can
HatchLoop loop=theHatch.GetLoopAt(0);
Curve2DCollection curves=loop.Curves;
The Curve2dCollection is the geometries of the boundary of the Hatch;
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #2 on: November 23, 2017, 01:07:35 PM »
It is possible: http://adn-cis.org/kak-vosstanovit-poteryannyie-graniczyi-shtrixovki.html
Code - C#: [Select]
  1. using System;
  2.     using System.Reflection;
  3.     using Autodesk.AutoCAD.Runtime;
  4.     using Autodesk.AutoCAD.ApplicationServices;
  5.     using Autodesk.AutoCAD.DatabaseServices;
  6.     using Autodesk.AutoCAD.Geometry;
  7.     using Autodesk.AutoCAD.EditorInput;
  8.
  9.     [assembly: CommandClass(typeof(Rivilis.HatchUtils))]
  10.
  11.     namespace Rivilis
  12.     {
  13.       public class HatchUtils
  14.       {
  15.         [CommandMethod("RHB", CommandFlags.Modal)]
  16.         public void RHB()
  17.         {
  18.           Document doc = Application.DocumentManager.MdiActiveDocument;
  19.           Editor ed = doc.Editor;
  20.           PromptEntityOptions prOps = new PromptEntityOptions("\nSelect Hatch: ");
  21.           prOps.SetRejectMessage("\nNot a Hatch");
  22.           prOps.AddAllowedClass(typeof(Hatch), false);
  23.           PromptEntityResult prRes = ed.GetEntity(prOps);
  24.           if (prRes.Status != PromptStatus.OK) return;
  25.           using (Transaction tr = doc.TransactionManager.StartTransaction()) {
  26.             Hatch hatch = tr.GetObject(prRes.ObjectId, OpenMode.ForRead) as Hatch;
  27.             if (hatch != null) {
  28.               BlockTableRecord btr = tr.GetObject(hatch.OwnerId, OpenMode.ForWrite) as BlockTableRecord;
  29.               if (btr == null) return;
  30.               Plane plane = hatch.GetPlane();
  31.               int nLoops = hatch.NumberOfLoops;
  32.               for (int i = 0; i < nLoops; i++) {
  33.                 HatchLoop loop = hatch.GetLoopAt(i);
  34.                 if (loop.IsPolyline) {
  35.                   using (Polyline poly = new Polyline()) {
  36.                     int iVertex = 0;
  37.                     foreach (BulgeVertex bv in loop.Polyline) {
  38.                       poly.AddVertexAt(iVertex++, bv.Vertex, bv.Bulge, 0.0, 0.0);
  39.                     }
  40.                     btr.AppendEntity(poly);
  41.                     tr.AddNewlyCreatedDBObject(poly, true);
  42.                   }
  43.                 } else {
  44.                   foreach (Curve2d cv in loop.Curves) {
  45.                     LineSegment2d line2d = cv as LineSegment2d;
  46.                     CircularArc2d arc2d = cv as CircularArc2d;
  47.                     EllipticalArc2d ellipse2d = cv as EllipticalArc2d;
  48.                     NurbCurve2d spline2d = cv as NurbCurve2d;
  49.                     if (line2d != null) {
  50.                       using (Line ent = new Line()) {
  51.                         ent.StartPoint = new Point3d(plane, line2d.StartPoint);
  52.                         ent.EndPoint = new Point3d(plane, line2d.EndPoint);
  53.                         btr.AppendEntity(ent);
  54.                         tr.AddNewlyCreatedDBObject(ent, true);
  55.                       }
  56.                     } else if (arc2d != null) {
  57.                       if (Math.Abs(arc2d.StartAngle - arc2d.EndAngle) < 1e-5) {
  58.                         using (Circle ent = new Circle(new Point3d(plane, arc2d.Center), plane.Normal, arc2d.Radius)) {
  59.                           btr.AppendEntity(ent);
  60.                           tr.AddNewlyCreatedDBObject(ent, true);
  61.                         }
  62.                       } else {
  63.                         double angle = new Vector3d(plane, arc2d.ReferenceVector).AngleOnPlane(plane);
  64.                         using (Arc ent = new Arc(new Point3d(plane, arc2d.Center), arc2d.Radius, arc2d.StartAngle + angle, arc2d.EndAngle + angle)) {
  65.                           btr.AppendEntity(ent);
  66.                           tr.AddNewlyCreatedDBObject(ent, true);
  67.                         }
  68.                       }
  69.                     } else if (ellipse2d != null) {
  70.                       //-------------------------------------------------------------------------------------------
  71.                       // &#1054;&#1096;&#1080;&#1073;&#1082;&#1072;: &#1053;&#1077;&#1083;&#1100;&#1079;&#1103; &#1087;&#1088;&#1080;&#1089;&#1074;&#1086;&#1080;&#1090;&#1100; StartParam &#1080; EndParam &#1087;&#1088;&#1080;&#1084;&#1080;&#1090;&#1080;&#1074;&#1091;  &#1101;&#1083;&#1083;&#1080;&#1087;&#1089;:
  72.                       // Ellipse ent = new Ellipse(new Point3d(plane, e2d.Center), plane.Normal,
  73.                       //      new Vector3d(plane,e2d.MajorAxis) * e2d.MajorRadius,
  74.                       //      e2d.MinorRadius / e2d.MajorRadius, e2d.StartAngle, e2d.EndAngle);
  75.                       // ent.StartParam = e2d.StartAngle;
  76.                       // ent.EndParam = e2d.EndAngle;
  77.                       // error CS0200: Property or indexer 'Autodesk.AutoCAD.DatabaseServices.Curve.StartParam' cannot be assigned to -- it is read only
  78.                       // error CS0200: Property or indexer 'Autodesk.AutoCAD.DatabaseServices.Curve.EndParam' cannot be assigned to -- it is read only
  79.                       //---------------------------------------------------------------------------------------------
  80.                       // &#1054;&#1073;&#1093;&#1086;&#1076;&#1080;&#1084; &#1101;&#1090;&#1091; &#1086;&#1096;&#1080;&#1073;&#1082;&#1091; &#1080;&#1089;&#1087;&#1086;&#1083;&#1100;&#1079;&#1091;&#1103; «&#1086;&#1090;&#1088;&#1072;&#1078;&#1077;&#1085;&#1080;&#1077;» (Reflection)
  81.                       //
  82.                       using (Ellipse ent = new Ellipse(new Point3d(plane, ellipse2d.Center), plane.Normal,
  83.                            new Vector3d(plane, ellipse2d.MajorAxis) * ellipse2d.MajorRadius,
  84.                            ellipse2d.MinorRadius / ellipse2d.MajorRadius, ellipse2d.StartAngle, ellipse2d.EndAngle)) {
  85.                         ent.GetType().InvokeMember("StartParam", BindingFlags.SetProperty, null,
  86.                           ent, new object[] { ellipse2d.StartAngle });
  87.                         ent.GetType().InvokeMember("EndParam", BindingFlags.SetProperty, null,
  88.                           ent, new object[] { ellipse2d.EndAngle });
  89.                         btr.AppendEntity(ent);
  90.                         tr.AddNewlyCreatedDBObject(ent, true);
  91.                       }
  92.
  93.                     } else if (spline2d != null) {
  94.                       if (spline2d.HasFitData) {
  95.                         NurbCurve2dFitData n2fd = spline2d.FitData;
  96.                         using (Point3dCollection p3ds = new Point3dCollection()) {
  97.                           foreach (Point2d p in n2fd.FitPoints) p3ds.Add(new Point3d(plane, p));
  98.                           using (Spline ent = new Spline(p3ds, new Vector3d(plane, n2fd.StartTangent), new Vector3d(plane, n2fd.EndTangent),
  99.                             /* n2fd.KnotParam, */  n2fd.Degree, n2fd.FitTolerance.EqualPoint)) {
  100.                             btr.AppendEntity(ent);
  101.                             tr.AddNewlyCreatedDBObject(ent, true);
  102.                           }
  103.                         }
  104.                       } else {
  105.                         NurbCurve2dData n2fd = spline2d.DefinitionData;
  106.                         using (Point3dCollection p3ds = new Point3dCollection()) {
  107.                           DoubleCollection knots = new DoubleCollection(n2fd.Knots.Count);
  108.                           foreach (Point2d p in n2fd.ControlPoints) p3ds.Add(new Point3d(plane, p));
  109.                           foreach (double k in n2fd.Knots) knots.Add(k);
  110.                           double period = 0;
  111.                           using (Spline ent = new Spline(n2fd.Degree, n2fd.Rational,
  112.                                    spline2d.IsClosed(), spline2d.IsPeriodic(out period),
  113.                                    p3ds, knots, n2fd.Weights, n2fd.Knots.Tolerance, n2fd.Knots.Tolerance)) {
  114.                             btr.AppendEntity(ent);
  115.                             tr.AddNewlyCreatedDBObject(ent, true);
  116.                           }
  117.                         }
  118.                       }
  119.                     }
  120.                   }
  121.                 }
  122.               }
  123.             }
  124.             tr.Commit();
  125.           }
  126.         }
  127.       }
  128.     }
nobody
  • .net stuff
« Reply #3 on: November 23, 2017, 02:31:12 PM »
Thanks!
