Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
convert 2d polyline to 3d polyline from contours
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: convert 2d polyline to 3d polyline from contours (Read 3440 times)
pedroantonio
Guest
on:
November 22, 2017, 01:01:16 PM »
Hi ,this lisp code convert lines to 3d polylines from contours .I need this code to convert lines and polylines to 3d polylines from contours. Can any one help?
the names of the layers of the contous is
Contour Major Natural Ground color 72
Contour Minor Natural Ground color 23
Code - Auto/Visual Lisp:
[Select]
;Drapes a 3dpolyline over polylines along a selected line.
vl-load-com
defun
c:sample
pl
li
ModSpc
ActDoc
Acad lobj p1 p2 ss sslen i plobj pnts n li pntli finli var
setq
li
nil
setq
ModSpc
vlax-get-property
setq
ActDoc
vlax-get-property
setq
acad
vlax-get-acad-object
'ActiveDocument
'ModelSpace
setq
lobj
vlax
ename
vla-object
car
entsel
\n
Select Line Object: "
setq
p1
vlax
safearray
list
vlax
variant-value
vlax-get-property
lobj 'StartPoint
setq
p2
vlax
safearray
list
vlax
variant-value
vlax-get-property
lobj 'EndPoint
setq
ss
ssget
"f"
list
p1 p2
0
"LWPOLYLINE"
setq
sslen
sslength
ss
setq
i
0
repeat
sslen
setq
plobj
vlax
ename
vla-object
ssname
ss i
setq
el
vlax-get-property
plobj 'Elevation
vlax-put-property
plobj 'Elevation
0
setq
pnts
vlax-invoke
lobj 'IntersectWith plobj acExtendNone
vlax-put-property
plobj 'Elevation el
vlax-release-object
plobj
setq
n
0
repeat
length
pnts
3
setq
li
append
li
list
nth
n
0
pnts
setq
li
append
li
list
nth
n
1
pnts
setq
li
append
li
list
el
drxc
list
nth
n
0
pnts
nth
n
1
pnts
el
2
setq
n
n
3
setq
i
1+
i
setq
n
0
setq
pntli
nil
repeat
length
li
3
setq
pntli
append
pntli
list
cons
distance
list
nth
n
0
li
nth
n
1
li
list
nth
0
p1
nth
1
p1
list
list
nth
n
0
li
nth
n
1
li
nth
n
2
li
setq
n
n
3
setq
pntli
vl-sort
pntli
function
lambda
d1 d2
car
d1
car
d2
setq
n
0
setq
finli
nil
repeat
length
pntli
setq
finli
append
finli
cadr
nth
n pntli
setq
n
1+
n
setq
var
pl
var finli
setq
3dobj2
vlax-invoke-method
ModSpc 'Add3DPoly var
vlax-put-property
3dobj2 'Color
1
vlax-release-object
3dobj2
;Given Pointlist returns pointlist in variant form
defun
PL
VAR
pl
pl ub sa var
setq
ub
length
pl
1
setq
sa
vlax
make
safearray
vlax-vbdouble
cons
0
ub
setq
var
vlax
make
variant
setq
sa
vlax-safearray-fill
sa pl
;Graphically at given point and color Example (drxc '( 1 2 3) 1) draws x at x=1 y=2 z=3 in the color red
defun
drxc
ctr color
vs xs xs2 cor1 cor2 cor3 cor4 ctr color
setq
vs
getvar
"viewsize"
setq
xs
vs
20
setq
xs2
xs
2
setq
cor1
polar
ctr
pi
0.25
xs2
setq
cor2
polar
ctr
pi
0.75
xs2
setq
cor3
polar
ctr
pi
1.25
xs2
setq
cor4
polar
ctr
pi
1.75
xs2
grdraw
ctr cor1 color
0
grdraw
ctr cor2 color
0
grdraw
ctr cor3 color
0
grdraw
ctr cor4 color
0
;The following was written by LEE MAC ~ Cadtutor
;in response to my posting of the above code.
defun
c:LWPolySample
_dxf doc spc lobj p1 ss ev tmp lst
vl-load-com
;; © Lee Mac 2010
defun
_dxf
code entity
cdr
assoc
code
entget
entity
LM:ActiveSpace 'doc 'spc
COMMAND
"_layer"
"_m"
"3d section"
"_c"
"55"
if
and
setq
lobj
car
entsel
\n
Επιλέξτε μια γραμμή: "
eq
"LINE"
_dxf
0
lobj
ssget
"_F"
list
setq
p1
_dxf
10
lobj
_dxf
11
lobj
0
"LWPOLYLINE"
progn
setq
lobj
vlax
ename
vla-object
lobj
vlax-for
obj
setq
ss
vla-get-ActiveSelectionSet
doc
setq
ev
vla-get-Elevation
obj
vla-put-Elevation
obj
0.0
setq
lst
cons
mapcar
function
lambda
x
list
car
x
cadr
x
ev
GroupByNum
vlax-invoke
obj 'IntersectWith lobj acExtendNone
3
lst
vla-put-Elevation
obj ev
vla-delete
ss
vla-put-Color
vlax-invoke
spc 'Add3DPoly
apply
append
vl-sort
apply
append
lst
lambda
a b
distance
p1
list
car
a
cadr
a
distance
p1
list
car
b
cadr
b
princ
defun
GroupByNum
l n
r
;; © Lee Mac 2010
setq
r
list
car
l
if
l
cons
reverse
repeat
1-
n
setq
l
cdr
l
r
cons
car
l
r
GroupByNum
cdr
l
n
;;--------------------=={ ActiveSpace }==---------------------;;
;; Retrieves pointers to the Active Document and Space ;;
;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;;
;; Arguments: ;;
;; *doc - quoted symbol (other than *doc) ;;
;; *spc - quoted symbol (other than *spc) ;;
defun
LM:ActiveSpace
doc
spc
;; © Lee Mac 2010
set
spc
vlax-get-property
set
doc
vla-get-ActiveDocument
if
1
getvar
'CVPORT
'PaperSpace 'ModelSpace
thanks
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: convert 2d polyline to 3d polyline from contours
Reply #1 on:
November 23, 2017, 01:00:48 AM »
http://www.cadtutor.net/forum/showthread.php?100610-longitudinal-profile-from-3D-polyline/page2&p=#12
http://www.cadtutor.net/forum/showthread.php?100571-project-polyline-to-contour-line-with-interpolation-each-vertex-of-polyline&p=#9
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
pedroantonio
Guest
Reply #2 on:
November 23, 2017, 01:37:29 AM »
thank you
Logged
mailmaverick
Bull Frog
Reply #3 on:
November 24, 2017, 05:22:52 AM »
Dear Topographer, please let me know what is the use of having a 3D polyline with every vertex at same elevation (Z value) as compared to a 2D Polyline with elevation ?
Logged
pedroantonio
Guest
Reply #4 on:
November 24, 2017, 08:29:40 AM »
i am using it to draw cross sections
Logged
pedroantonio
Guest
Reply #5 on:
November 26, 2017, 05:19:03 AM »
Hi ribarm i use your code and works fine . As i said in the first post the names of the contour layers is
color 72 and
color 23 , and the contours is
LWPOLYLINE
. Is it possible to understand the contours without need to delect them?
[Select]
defun
c:pl3dpl
;fencelwpoly23dpolyelevations
*error*
bbucs ucsf osm cec ss1 ss2 i lw pl sss ssl sspl e
vl-load-com
defun
*error*
msg
if
ucsf
command
"_.UCS"
"_P"
command
"_.ZOOM"
"_P"
if
osm
setvar
'osmode osm
if
cec
setvar
'cecolor cec
if
msg
prompt
msg
princ
defun
bbucs
ss
UCS2WCSMatrix WCS2UCSMatrix n ent minpt maxpt minptlst maxptlst minptbbx minptbby minptbbz minptbb maxptbbx maxptbby maxptbbz maxptbb
vl-load-com
;; Doug C. Broad, Jr.
;; can be used with vla-transformby to
;; transform objects from the UCS to the WCS
defun
UCS2WCSMatrix
vlax-tmatrix
append
mapcar
lambda
vector origin
append
trans
vector
1
0
t
list
origin
list
1
0
0
0
1
0
0
0
1
trans
0
0
0
0
1
list
0
0
0
1
;; transform objects from the WCS to the UCS
defun
WCS2UCSMatrix
vlax-tmatrix
append
mapcar
lambda
vector origin
append
trans
vector
0
1
t
list
origin
list
1
0
0
0
1
0
0
0
1
trans
0
0
0
1
0
list
0
0
0
1
if
ss
progn
repeat
setq
n
sslength
ss
setq
ent
ssname
ss
setq
n
1-
n
vla-TransformBy
vlax
ename
vla-object
ent
UCS2WCSMatrix
vla-getboundingbox
vlax
ename
vla-object
ent
'minpoint 'maxpoint
vla-TransformBy
vlax
ename
vla-object
ent
WCS2UCSMatrix
setq
minpt
vlax
safearray
list
minpoint
setq
maxpt
vlax
safearray
list
maxpoint
setq
minptlst
cons
minpt minptlst
setq
maxptlst
cons
maxpt maxptlst
setq
minptbbx
caar
vl-sort
minptlst '
lambda
a b
car
a
car
b
setq
minptbby
cadar
vl-sort
minptlst '
lambda
a b
cadr
a
cadr
b
setq
minptbbz
caddar
vl-sort
minptlst '
lambda
a b
caddr
a
caddr
b
setq
maxptbbx
caar
vl-sort
maxptlst '
lambda
a b
car
a
car
b
setq
maxptbby
cadar
vl-sort
maxptlst '
lambda
a b
cadr
a
cadr
b
setq
maxptbbz
caddar
vl-sort
maxptlst '
lambda
a b
caddr
a
caddr
b
setq
minptbb
list
setq
maxptbb
list
list
minptbb maxptbb
if
0
getvar
'worlducs
progn
command
"_.UCS"
"_W"
command
"_.PLAN"
setq
ucsf t
command
"_.PLAN"
setq
osm
getvar
'osmode
setvar
'osmode
0
setq
cec
getvar
'cecolor
setvar
'cecolor
"3"
prompt
\n
Select OPEN
STRAIGHT
LWPOLYLINES that lie in plane parallel to WCS - PROJECTION LWPOLYLINES (NOT ELEVATION)..."
setq
ss1
ssget
list
0
"LWPOLYLINE"
4
"<or"
70
0
70
128
4
"or>"
4
"<or"
210
0.0
0.0
1.0
210
0.0
0.0
1.0
4
"or>"
4
"<not"
4
42
0.0
4
"not>"
while
or
not
ss1
vl-every
lambda
x
not
equal
caddar
bbucs
ssadd
x
caddr
cadr
bbucs
ssadd
x
1e
6
vl
remove
if
listp
mapcar
cadr
ssnamex
ss1
prompt
\n
Empty sel.set... Please reselect again..."
setq
ss1
ssget
list
0
"LWPOLYLINE"
4
"<or"
70
0
70
128
4
"or>"
4
"<or"
210
0.0
0.0
1.0
210
0.0
0.0
1.0
4
"or>"
4
"<not"
4
42
0.0
4
"not>"
prompt
\n
Select LWPOLYLINES that lie in plane parallel to WCS - ELEVATION LWPOLYLINES (NOT PROJECTION)..."
setq
ss2
ssget
list
0
"LWPOLYLINE"
4
"<or"
210
0.0
0.0
1.0
210
0.0
0.0
1.0
4
"or>"
while
not
ss2
prompt
\n
setq
ss2
ssget
list
0
"LWPOLYLINE"
4
"<or"
210
0.0
0.0
1.0
210
0.0
0.0
1.0
4
"or>"
repeat
setq
i
sslength
ss1
setq
lw
ssname
ss1
setq
i
1-
i
setq
pl
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
10
entget
lw
setq
sss
ssget
"_F"
pl
list
0
"LWPOLYLINE"
4
"<or"
210
0.0
0.0
1.0
210
0.0
0.0
1.0
4
"or>"
setq
ssl
ssnamex
sss
setq
ssl
vl
remove
if
lambda
x
eq
cadr
x
lw
ssl
setq
sspl
mapcar
cadr
apply
append
mapcar
lambda
x
vl
remove
if
not
listp
x
ssl
setq
sspl
vl-sort
sspl '
lambda
a b
vlax-curve-getparamatpoint
lw
vlax-curve-getclosestpointto
lw
list
car
a
cadr
a
cdr
assoc
38
entget
lw
lw
lw
list
car
b
cadr
b
cdr
assoc
38
entget
lw
command
"_.3DPOLY"
foreach
p sspl
if
vl-some
lambda
x
if
x
list
car
p
cadr
p
cdr
assoc
38
entget
x
setq
e x
vl
remove
if
listp
mapcar
cadr
ssnamex
ss2
command
"_non"
list
car
p
cadr
p
cdr
assoc
38
entget
e
command
*error*
nil
Logged
pedroantonio
Guest
Reply #6 on:
November 28, 2017, 02:13:21 AM »
Hi ribarm. I did this change in the code but didn't work
[Select]
;(prompt "\nSelect LWPOLYLINES that lie in plane parallel to WCS - ELEVATION LWPOLYLINES (NOT PROJECTION)...")
;(setq ss2 (ssget (list '(0 . "LWPOLYLINE") '(-4 . "<or") '(210 0.0 0.0 1.0) '(210 0.0 0.0 -1.0) '(-4 . "or>"))))
; (while (not ss2)
; (prompt "\nEmpty sel.set... Please reselect again...")
; (setq ss2 (ssget (list '(0 . "LWPOLYLINE") '(-4 . "<or") '(210 0.0 0.0 1.0) '(210 0.0 0.0 -1.0) '(-4 . "or>"))))
setq
sss
ssget
"_F"
pl
list
0
"LWPOLYLINE"
4
"<or"
4
"or>"
Any ideas . Thanks
Logged
pedroantonio
Guest
Reply #7 on:
November 29, 2017, 11:08:08 AM »
Any ideas?. Thanks
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
