Author Topic: How to get the same characters from a list of strings  (Read 2384 times)
fools
  • China
« on: November 22, 2017, 11:03:48 AM »
As follows, if the same characters exists in a list of strings, returns it, if not, returns empty.
I can't think of a good way to solve it. Thanks for help.
(setq str1 '("123abc-de23f" "1abc-f123" "23abc" "23abcd23" "abc31de23"))
(setq str2 '("123abc-de23f" "1abc-f123" "32acd" "23abcd23" "abc31de23"))
(fun str1) ---> ("abc" "23")
(fun str2) ---> nil
Good good study , day day up . Sorry about my Chinglish .
VovKa
  • Ukraine
Re: How to get the same characters from a list of strings
« Reply #1 on: November 22, 2017, 11:43:03 AM »
(fun str2) ---> nil
why not (fun str2) ---> ("a" "c" "2" "3") ?
« Reply #2 on: November 22, 2017, 12:54:40 PM »
Quickly written, not pretty:
  1. (defun foo ( l / i j n r s x )
  2.     (setq x (car l)
  3.           l (cdr l)
  4.           n (strlen x)
  5.           i 1
  6.     )
  7.     (while (<= i n)
  8.         (setq j 1)
  9.         (while
  10.             (and
  11.                 (<= j (- n i -1))
  12.                 (setq s (strcat "*" (substr x i j) "*"))
  13.                 (vl-every '(lambda ( y ) (wcmatch y s)) l)
  14.             )
  15.             (setq j (1+ j))
  16.         )
  17.         (if (< 1 j)
  18.             (progn
  19.                 (setq j (1- j)
  20.                       s (substr x i j)
  21.                 )
  22.                 (if (not (member s r))
  23.                     (setq r (cons (substr x i j) r))
  24.                 )
  25.             )
  26.         )
  27.         (setq i (+ i j))
  28.     )
  29.     (reverse r)
  30. )
  1. _$ (foo str1)
  2. ("23" "abc")
  3. _$ (foo str2)
  4. ("2" "3" "a" "c")
« Reply #3 on: November 22, 2017, 12:55:28 PM »
Quick and dirty:
(defun foo ( strlist / moo tmp ptn result )
    (defun moo ( s / i r )
        (while (< 0 (strlen s))
            (repeat (setq i (strlen s))
                (setq r (cons (substr s 1 i) r) i (1- i))
            (setq s (substr s 2))
        (reverse r)
    (foreach a (setq tmp (mapcar 'moo strlist))
        (foreach i a
            (and
                (vl-every
                    (function (lambda (b) (member i b)))
                    (vl-remove a tmp)
                (null (member i result))
                (setq result (cons i result))
    (foreach i (vl-sort result (function (lambda (a b) (< (strlen a) (strlen b)))))
        (and
            (setq ptn (strcat "?" i "," i "?"))
            (vl-some
                (function (lambda (s) (wcmatch s ptn)))
                (setq tmp (vl-remove i result))
            (setq result tmp)
    (vl-sort result '<)
(foo str1) >> ("23" "abc")
(foo str2) >> ("2" "3" "a" "c")
« Reply #4 on: November 22, 2017, 01:00:28 PM »
Another :)
  1. (defun foo (l / _every a b c i n out)
  2.   (defun _every (s l)
  3.     (if (vl-every (function (lambda (x) (wcmatch x (strcat "*" s "*")))) l)
  4.       s
  5.     )
  6.   )
  7.   (setq l (mapcar (function (lambda (x) (cons (strlen x) x))) l))
  8.   (setq a (car (setq l (mapcar 'cdr (vl-sort l '(lambda (a b) (< (car a) (car b))))))))
  9.   (setq i 0)
  10.   (repeat (strlen a)
  11.     (setq i (1+ i))
  12.     (setq n 0)
  13.     (setq c nil)
  14.     (while
  15.       (and (<= (setq n (1+ n)) (strlen a))
  16.            (setq b (_every (substr a i n) l))
  17.            (not (and (= 1 (strlen b)) (vl-some '(lambda (x) (wcmatch x (strcat "*" b "*"))) out)))
  18.            (setq c b)
  19.       )
  20.     )
  21.     (and c (setq out (cons c out)))
  22.   )
  23.   (acad_strlsort out)
  24. )
  25. (foo '("123abc-de23f" "1abc-f123" "23abc" "23abcd23" "abc31de23"))
  26. (foo '("123abc-de23f" "1abc-f123" "32acd" "23abcd23" "abc31de23"))
  27. ;;;_$
  28. ;;;
  29. ;;;FOO
  30. ;;;("23" "abc")
  31. ;;;("2" "3" "a" "c")
  32. ;;;_$
« Last Edit: November 22, 2017, 01:10:55 PM by ronjonp »
« Reply #5 on: November 22, 2017, 01:16:17 PM »
Another:
  1. (defun foo ( l )
  2.     (baz (bar 1 (car l) (cdr l)))
  3. )
  4. (defun bar ( n x l )
  5.     (cond
  6.         (   (< (strlen x) n) nil)
  7.         (   (vl-every '(lambda ( y ) (wcmatch y (strcat "*" (substr x 1 n) "*"))) l)
  8.             (bar (1+ n) x l)
  9.         )
  10.         (   (< 1 n)
  11.             (cons (substr x 1 (1- n)) (bar 1 (substr x 2) l))
  12.         )
  13.         (   (bar 1 (substr x 2) l))
  14.     )
  15. )
  16. (defun baz ( l )
  17.     (if l (cons (car l) (baz (vl-remove-if '(lambda ( x ) (vl-string-search x (car l))) (cdr l)))))
  18. )
VovKa
  • Ukraine
« Reply #6 on: November 22, 2017, 04:04:46 PM »
hello guys  :police:
(foo (list "cbc" "abc"))
(foo (list "babac" "ababc"))
what should they return?
« Reply #7 on: November 22, 2017, 05:00:16 PM »
Mine returns what I imagine it should:
(foo (list "cbc" "abc"))     >> ("bc")
(foo (list "babac" "ababc")) >> ("aba" "bab" "c")
In your mind should it return something else?
Thanks & cheers.
VovKa
  • Ukraine
« Reply #8 on: November 22, 2017, 05:29:08 PM »
there's nothing on my mind :)
i just see that functions presented here return different results for the same argument
fools
  • China
« Reply #9 on: November 22, 2017, 08:44:18 PM »
Thanks everybody for kind help.
For me, I got a lot of learning materials at once.
It's my mistake. I didn't make the question clear. In my actual case, scattered single identical characters will be ignored in order to prevent judgment errors.
Even without distinguishing individual characters, all of the above methods are still very helpful to me.
Theswamp is so wonderful. :laugh:
« Reply #10 on: November 23, 2017, 09:50:46 AM »
Glad to hear you're learning.
This variant eschews individual chars (changes commented).
        (while (< 1 (strlen s)) ;; was (< 0 (strlen s))
                (if (< 1 i) (setq r (cons (substr s 1 i) r) i (1- i)))
                ;; was (setq r (cons (substr s 1 i) r) i (1- i))
        (reverse r)
        (foreach i a
            (and
                (vl-every
                    (vl-remove a tmp)
        (and
            (vl-some
            (setq result tmp)
    (vl-sort result '<)
(foreach lst
        ("cbc" "abc")
        ("babac" "ababc")
    (princ
        (strcat "\n"
            (vl-prin1-to-string lst)
            (vl-prin1-to-string (foo lst))
("123abc-de23f" "1abc-f123" "23abc" "23abcd23" "abc31de23") >> ("23" "abc")
("123abc-de23f" "1abc-f123" "32acd" "23abcd23" "abc31de23") >> nil
("cbc" "abc")                                               >> ("bc")
("babac" "ababc")                                           >> ("aba" "bab")
Cheers. :)
fools
  • China
« Reply #11 on: November 25, 2017, 03:47:30 AM »
Thanks again, MP.
I learned a lot from the programs above , trying to rewrite some of the content.
  1. ;;https://www.theswamp.org/index.php?topic=53660.0
  2. ;;Based on Lee Mac, ronjonp, MP's code
  3. ;;(GetSameTxtFromLst '("123abc-de23f" "1abc-f123" "231abcf" "23abcd23f" "abc31de23f") 1) -->("23" "abc" "f")
  4. ;;(GetSameTxtFromLst '("123abc-de23f" "1abc-f123" "231abcf" "23abcd23f" "abc31de23f") 2) -->("23" "abc")
  5. ;;(GetSameTxtFromLst '("123abc-de23f" "1abc-f123" "231abcf" "23abcd23f" "abc31de23f") 3) -->("abc")
  6. ;;(GetSameTxtFromLst '("123abc-de23f" "1abc-f123" "231abcf" "23abcd23f" "abc31de23f") 4) -->nil
  7. (defun GetSameTxtFromLst (lst num / I J MINLEN MINLENSTR R S STR TMP)
  8.   (setq MinLenStr ((lambda (a b) (assoc (apply 'min a) (mapcar 'list a b))) (mapcar 'strlen lst) lst))
  9.   (setq minlen (car MinLenStr)
  10.         str    (cadr MinLenStr)
  11.         i      1
  12.   )
  13.   (and (or (zerop num) (minusp num)) (setq num 1))
  14.   (while (<= i minlen)
  15.     (setq j num)
  16.     (while (and (<= j (- minlen i -1))
  17.                 (setq tmp (substr str i j))
  18.                 (vl-every (function (lambda (y) (wcmatch y (strcat "*" tmp "*")))) lst)
  19.            )
  20.       (setq j (1+ j)
  21.             s tmp
  22.       )
  23.     )
  24.     (if (< num j)
  25.       (progn (setq i (+ i j -1))
  26.              (if (not (member s r))
  27.                (setq r (cons s r))
  28.              )
  29.       )
  30.       (setq i (1+ i))
  31.     )
  32.   )
  33.   (reverse r)
  34. )
