Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Not able to find vla-get-TwistAngle of selected Viewport
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Not able to find vla-get-TwistAngle of selected Viewport (Read 1365 times)
mailmaverick
Bull Frog
on:
November 08, 2017, 07:39:06 AM »
Hi
I have a Viewport which is rotated and I want to find its angle of rotation. When I run the command :
(setq ang (vla-get-TwistAngle (vlax-ename->vla-object (car (entsel)))))
it gives error. Please help.
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: Not able to find vla-get-TwistAngle of selected Viewport
Reply #1 on:
November 08, 2017, 08:00:45 AM »
Check if the entity is the VP and not the clipping boundary entity belonging to the VP.
Code - Auto/Visual Lisp:
[Select]
setq
elist
entget
ename
or
"VIEWPORT"
cdr
assoc
0
elist
and
setq
ename
cdadr
member
102
"{ACAD_REACTORS"
elist
setq
elist
entget
ename
"VIEWPORT"
cdr
assoc
0
elist
prompt
\n
Error: not a viewport "
Last Edit: November 08, 2017, 08:08:03 AM by roy_043
Logged
Needs a day job
Reply #2 on:
November 08, 2017, 09:09:36 AM »
Another to return the ename:
[Select]
defun
_getvport
e
if
'ename
type
e
cond
"VIEWPORT"
cdr
assoc
0
entget
e
e
and
setq
e
cdr
assoc
330
entget
e
"VIEWPORT"
cdr
assoc
0
entget
e
e
;; Usage
if
setq
e
_getvport
car
entsel
setq
a
cdr
assoc
51
entget
e
Logged
Seagull
London, England
WWW
Reply #3 on:
November 08, 2017, 12:37:34 PM »
And another:
[Select]
defun
c:test
sel
if
setq
sel
ssget
"_+.:E:S"
0
"VIEWPORT"
cdr
assoc
51
entget
ssname
sel
0
Logged
Lee Mac Programming
Twitter
Exchange App Store
mailmaverick
Bull Frog
Reply #4 on:
November 08, 2017, 12:44:24 PM »
Thanks a lot. Problem Solved !!!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
