using Autodesk.AutoCAD.PlottingServices;
using System;
using System.IO;
using System.Windows.Forms;
namespace ProCadCommands
public partial class UserControl1 : UserControl
public UserControl1()
InitializeComponent();
private void pc_updateviews_Click(object sender, EventArgs e)
// Get the current document and database, and start a transaction
System.IO.Stream myStream;
OpenFileDialog thisDialog
= new OpenFileDialog
thisDialog.InitialDirectory = "C:\\";
thisDialog.FilterIndex = 2;
thisDialog.RestoreDirectory = true;
thisDialog.Multiselect = true;
thisDialog.Title = "Please Select Source File(s) for Conversion";
var collection
= new List
<string>(); if (thisDialog.ShowDialog() == DialogResult.OK)
foreach (String file in thisDialog.FileNames)
if ((myStream = thisDialog.OpenFile()) != null)
using (myStream)
collection.Add(file);
for (int i = 0; i < collection.Count; i++)
var dwg = collection[i];
var dir = Path.GetDirectoryName(dwg);
var fn = Path.GetFileNameWithoutExtension(dwg);
string strFileName = collection[i];
DocumentCollection acDocMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
acDocMgr.Open(strFileName, false);
Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database acCurDb = acDoc.Database;
Editor ed = acDoc.Editor;
using (DocumentLock acLckDoc = acDoc.LockDocument())
using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
HostApplicationServices.WorkingDatabase = acCurDb;
LayoutManager acLayoutMgr = LayoutManager.Current;
// Get the current layout and output its name in the Command Line window
Layout acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForRead) as Layout;
// Get the PlotInfo from the layout
using (PlotInfo acPlInfo
= new PlotInfo
acPlInfo.Layout = acLayout.ObjectId;
// Get a copy of the PlotSettings from the layout
using (PlotSettings acPlSet
= new PlotSettings
(acLayout
.ModelType)) {
acPlSet.CopyFrom(acLayout);
// Update the PlotSettings object
PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
// Set the plot type
acPlSetVdr.SetPlotType(acPlSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
// Set the plot scale
acPlSetVdr.SetUseStandardScale(acPlSet, true);
acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.ScaleToFit);
// Center the plot
acPlSetVdr.SetPlotCentered(acPlSet, true);
// Set the plot device to use
acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", "ARCH_D_(24.00_x_36.00_Inches)");
// Set the plot info as an override since it will
// not be saved back to the layout
acPlInfo.OverrideSettings = acPlSet;
// Validate the plot info
using (PlotInfoValidator acPlInfoVdr
= new PlotInfoValidator
acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
acPlInfoVdr.Validate(acPlInfo);
// Check to see if a plot is already in progress
if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
using (PlotEngine acPlEng = PlotFactory.CreatePublishEngine())
// Track the plot progress with a Progress dialog
using (PlotProgressDialog acPlProgDlg
= new PlotProgressDialog
(false,
1,
true)) {
using ((acPlProgDlg))
// Define the status messages to display
// when plotting starts
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Plot Progress");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
// Set the plot progress range
acPlProgDlg.LowerPlotProgressRange = 0;
acPlProgDlg.UpperPlotProgressRange = 100;
acPlProgDlg.PlotProgressPos = 0;
// Display the Progress dialog
acPlProgDlg.OnBeginPlot();
acPlProgDlg.IsVisible = true;
// Start to plot the layout
acPlEng.BeginPlot(acPlProgDlg, null);
// Define the plot output
acPlEng.BeginDocument(acPlInfo, acDoc.Name, null, 1, true, "c:\\myplot");
// Display information about the current plot
acPlProgDlg.set_PlotMsgString(PlotMessageIndex.Status, "Plotting: " + acDoc.Name + " - " + acLayout.LayoutName);
// Set the sheet progress range
acPlProgDlg.OnBeginSheet();
acPlProgDlg.LowerSheetProgressRange = 0;
acPlProgDlg.UpperSheetProgressRange = 100;
acPlProgDlg.SheetProgressPos = 0;
// Plot the first sheet/layout
using (PlotPageInfo acPlPageInfo
= new PlotPageInfo
acPlEng.BeginPage(acPlPageInfo, acPlInfo, true, null);
acPlEng.BeginGenerateGraphics(null);
acPlEng.EndGenerateGraphics(null);
// Finish plotting the sheet/layout
acPlEng.EndPage(null);
acPlProgDlg.SheetProgressPos = 100;
acPlProgDlg.OnEndSheet();
// Finish plotting the document
acPlEng.EndDocument(null);
// Finish the plot
acPlProgDlg.PlotProgressPos = 100;
acPlProgDlg.OnEndPlot();
acPlEng.EndPlot(null);
