Author Topic: Deleting revclouds deletes the revision  (Read 119 times)
hudster
« on: November 01, 2017, 05:42:42 am »
I revised a sheet up and deleted the revcloud from the previous revision, but it also deleted the revision they were associated with from the revisions on sheet.
It doesn't do this on every sheet, just ones at random.
The revision wasn't marked as issued, and no matter how I try I can't replicate the process that caused this.
Anyone have any ideas of how this happened?
rvhwlc
Re: Deleting revclouds deletes the revision
« Reply #1 on: November 13, 2017, 02:16:42 pm »
why delete..? do not delete.. to go sheet rev manager and set rev to none under show column, if revision is complete .. then it will show in sheet and always be docu mented..
hudster
« Reply #2 on: November 14, 2017, 04:22:01 am »
Can't do that, it's a UK job, each sheet is only re-issued as and when it's revised, so if I turn off the clouds for a particular revision, its also turned off on sheets which may not have been revised in this issue.
John Kaul (Se7en)
« Reply #3 on: November 14, 2017, 06:46:12 am »
Keep an individual PDF copy and merge the documents into a set instead of reprinting the whole set from Revit (turn rev clouds off, of course to NOT delete the revision before you reprint the plan).
“Common sense is not so common.” ~Voltaire
--> Donate to TheSwamp.org <--
tedg
« Reply #4 on: November 14, 2017, 01:00:36 pm »
Couldn't you set it to Revisions per Sheet vs per Project?
And then you can control what you show on each sheet?
Windows 7 Pro 64bit, AutoCAD 2017, REVIT 2017, Inventor Professional 2015
Krushert
  • "GRAMR? I need no stinkin' gramr!"
« Reply #5 on: November 14, 2017, 04:29:33 pm »
Don't pay attention to him.  What does a Ted know?   :sleezy:
« Last Edit: November 14, 2017, 04:33:06 pm by Krushert »
Don't ask me questions without answers.
42
« Reply #6 on: November 15, 2017, 07:31:01 am »
No. The sheet option allows you place revisions on any number of sheets. If as has been suggested, a particular revision cloud is unticked, then all sheets with that revision will loose their clouds. What I tend to do, and its not perfect, is to hide the rev clouds on the sheet in question, so this will allow sheets with various revisions to be published together. As I said not perfect but does work.
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
hudster
« Reply #7 on: November 16, 2017, 03:55:58 am »
we have a project with per sheet revisions, its a nightmare, I might have the same revision on 3 sheets, but they might be at different revisions, so need to add it 3 times to the revision list
tedg
« Reply #8 on: November 16, 2017, 07:07:12 am »
Well I HAVE been drinking so there is that...
 8) :P
