Author Topic: SUDOKU Challenge  (Read 11892 times)
Re: SUDOKU Challenge
« Reply #15 on: October 27, 2017, 02:40:19 PM »
Hello everyone
Here is my solution. It is very slow, but it can solve even the allegedly hardest sudoku in the world (btw, i couldn't solve it on paper...); the grid is supposed to be fair (no conflicts in the initial grid) and solvable.
That is slick  8)
  1. (sudoku '((8 nil nil nil nil nil nil nil nil)
  2.           (nil nil 3 6 nil nil nil nil nil)
  3.           (nil 7 nil nil 9 nil 2 nil nil)
  4.           (nil 5 nil nil nil 7 nil nil nil)
  5.           (nil nil nil nil 4 5 7 nil nil)
  6.           (nil nil nil 1 nil nil nil 3 nil)
  7.           (nil nil 1 nil nil nil nil 6 8)
  8.           (nil nil 8 5 nil nil nil 1 nil)
  9.           (nil 9 nil nil nil nil nil nil nil)
  10.          )
  11. )
  12. ;;< Elapsed time: 5.968000 seconds. >
  13. ;;; 8 1 2 | 7 5 3 | 6 4 9
  14. ;;; 9 4 3 | 6 8 2 | 1 7 5
  15. ;;; 6 7 5 | 4 9 1 | 2 8 3
  16. ;;; ---------------------
  17. ;;; 1 5 4 | 2 3 7 | 8 9 6
  18. ;;; 3 6 9 | 8 4 5 | 7 2 1
  19. ;;; 2 8 7 | 1 6 9 | 5 3 4
  20. ;;; ---------------------
  21. ;;; 5 2 1 | 9 7 4 | 3 6 8
  22. ;;; 4 3 8 | 5 2 6 | 9 1 7
  23. ;;; 7 9 6 | 3 1 8 | 4 5 2
  24.
  25.
  26. (sudoku '((nil nil 2 nil nil 9 1 nil nil)
  27.           (nil nil nil 8 3 6 nil 7 nil)
  28.           (nil nil nil nil nil nil nil 8 nil)
  29.           (nil nil 1 nil nil nil 2 4 nil)
  30.           (3 nil nil 6 5 4 nil nil 7)
  31.           (nil 7 9 nil nil nil 6 nil nil)
  32.           (nil 5 nil nil nil nil nil nil nil)
  33.           (nil 3 nil 4 1 5 nil nil nil)
  34.           (nil nil 4 2 nil nil 3 nil nil)
  35.          )
  36. )
  37. ;;< Elapsed time: 0.453000 seconds. >
  38. ;;; 7 8 2 | 5 4 9 | 1 6 3
  39. ;;; 9 1 5 | 8 3 6 | 4 7 2
  40. ;;; 6 4 3 | 7 2 1 | 5 8 9
  41. ;;; ---------------------
  42. ;;; 5 6 1 | 9 7 3 | 2 4 8
  43. ;;; 3 2 8 | 6 5 4 | 9 1 7
  44. ;;; 4 7 9 | 1 8 2 | 6 3 5
  45. ;;; ---------------------
  46. ;;; 1 5 6 | 3 9 8 | 7 2 4
  47. ;;; 2 3 7 | 4 1 5 | 8 9 6
  48. ;;; 8 9 4 | 2 6 7 | 3 5 1
« Last Edit: October 27, 2017, 03:18:12 PM by ronjonp »
Grrr1337
« Reply #16 on: November 02, 2017, 06:18:51 PM »
BTW, I have an idea about the actual game (which includes DCL) but I must have more free time to write it. :idea:
Although it doesn't include sudoku solvers - just initial list of unsolved sudoku, like the above, along with user input and IsSudokuValid checking.
Here it is (better to be late than never) :
  1. ; https://www.theswamp.org/index.php?topic=53547.0
  2. (defun PlaySudoku ( aL / _MatrixSubstNth PlaySudoku:IsSudokuValid txt2num *error* dcl des dch dcf deferrmsg nL row col kL rL )
  3.   '(87 114 105 116 116 101 110 32 98 121 32 71 114 114 114)
  4.   ; _$ (_MatrixSubstNth '(1 2) "K" '(("A" "B" "C")("D" "E" "F")("G" "H" "I"))) -> (("A" "B" "C") ("D" "E" "K") ("G" "H" "I"))
  5.   ; _$ (_MatrixSubstNth '(1 8) "K" '(("A" "B" "C")("D" "E" "F")("G" "H" "I"))) -> (("A" "B" "C") ("D" "E" "F") ("G" "H" "I"))
  6.   (defun _MatrixSubstNth ( NthL NewItm aL / r c )
  7.     (setq r -1) (mapcar (function (lambda (row) (setq r (1+ r)) (setq c -1) (mapcar (function (lambda (itm) (setq c (1+ c)) (if (equal (list r c) NthL 1e-1) NewItm itm))) row))) aL)
  8.   ); defun _MatrixSubstNth
  9.
  10.   (defun PlaySudoku:IsSudokuValid ( aL / InvalidAt GroupByN ValidRowColp cols tmpL r )
  11.
  12.     ; _$ (InvalidAt '(lambda (a) (= a 5)) '(lambda (a b) (print (strcat "Error at item n."  b " :\n" (vl-prin1-to-string a)))) '(1 2 3 4 5 6 7 8 9)) -> "Error at item n.1 :\n1" T
  13.     ; _$ (InvalidAt '(lambda (a) (/= a 5)) '(lambda (a b) (print (strcat "Error at item n."  b " :\n" (vl-prin1-to-string a)))) '(1 2 3 4 5 6 7 8 9)) -> "Error at item n.5 :\n5" T
  14.     ; _$ (InvalidAt '(lambda (a) (/= a 15)) '(lambda (a b) (print (strcat "Error at item n."  b " :\n" (vl-prin1-to-string a)))) '(1 2 3 4 5 6 7 8 9)) -> nil
  15.     (setq InvalidAt
  16.       (lambda ( f mf L / i )
  17.         (setq i 0) (setq f (eval f)) (setq mf (eval mf))
  18.         (vl-some (function (lambda (x) (setq i (1+ i)) (if (not (f x)) (progn (mf x (itoa i)) T)))) L)
  19.       )
  20.     ); setq InvalidAt
  21.
  22.     (defun GroupByN ( n L / r )
  23.       (repeat n (and L (setq r (cons (car L) r))) (setq L (cdr L)) r)
  24.       (if L (cons (reverse r) (GroupByN n L)) (list (reverse r)))
  25.     ); defun GroupByN
  26.
  27.     ; _$ (ValidRowColp '(1 2 3 6 5 4 7 8 9)) -> T
  28.     ; _$ (ValidRowColp '(1 2 3 6 9 4 7 8 9)) -> nil
  29.     (defun ValidRowColp ( L / nL )
  30.       (setq nL '(1 2 3 4 5 6 7 8 9))
  31.       (vl-every (function (lambda (x) (if (member x nL) (progn (setq nL (vl-remove x nL)) T)))) L)
  32.     ); defun ValidRowColp
  33.
  34.     (cond
  35.       ( (not (vl-consp aL)) (prompt "\n#1. Not vl-consp.") )
  36.       ( (/= 9 (length aL)) (prompt "\n#2. Invalid length.") )
  37.       ( (InvalidAt '(lambda (x) (and (vl-consp x) (= 9 (length x)))) '(lambda (a b) (print (strcat "\nError[basic] at row n." b " :\n" (vl-prin1-to-string a)))) aL) )
  38.       ; ( (InvalidAt '(lambda (x) (and (eq 'INT (type x)) (<= 1 x 9))) '(lambda (a b) (print (strcat "\nError at atom n." b " :\n" (vl-prin1-to-string a)))) (apply 'append aL)) )
  39.       ( (progn (setq cols (apply 'mapcar (cons 'list aL))) nil) )
  40.       ( (InvalidAt 'ValidRowColp '(lambda (a b) (set_tile "error" (strcat "*Error at row n." b " : " (vl-prin1-to-string a) "*"))) aL) )
  41.       ( (InvalidAt 'ValidRowColp '(lambda (a b) (set_tile "error" (strcat "*Error at col n." b " : " (vl-prin1-to-string a) "*"))) cols) )
  42.       (
  43.         (and (setq tmpL (mapcar (function (lambda (x) (GroupByN 3 x))) aL))
  44.           (not
  45.             (InvalidAt '(lambda (x) (ValidRowColp (apply 'append x))) '(lambda (a b) (set_tile "error" (strcat "Error at sector n." b " : " (vl-prin1-to-string a) "*")))
  46.               (append ; Check 3x3 Matrix Sublists
  47.                 (GroupByN 3 (mapcar 'car tmpL))
  48.                 (GroupByN 3 (mapcar 'cadr tmpL))
  49.                 (GroupByN 3 (mapcar 'caddr tmpL))
  50.               ); append
  51.             )
  52.           )
  53.           (setq r T)
  54.         ); progn
  55.       )
  56.     ); cond
  57.     r
  58.   ); defun IsSudokuValid
  59.
  60.   (setq txt2num (lambda ( txt / num ) (if (and txt (numberp (setq num (vl-some '(lambda (x) (distof txt x)) (list (getvar 'lunits) 1 2 3 4 5))))) num)))
  61.
  62.   (defun *error* ( msg )
  63.     (and (< 0 dch) (unload_dialog dch))
  64.     (and (eq 'FILE (type des)) (close des))
  65.     (and (eq 'STR (type dcl)) (findfile dcl) (vl-file-delete dcl))
  66.     (and msg (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\nError: " msg)) ))
  67.     (princ)
  68.   ); defun *error*
  69.
  70.   (cond
  71.     ( (not (vl-consp aL)) (princ "\nInvalid input - aL is not a list.") )
  72.     ( (or (/= 9 (length aL)) (not (vl-every '(lambda (x) (and (vl-consp x) (= 9 (length x)) (vl-every '(lambda (i) (or (not i) (eq 'INT (type i)))) x))) aL)))
  73.       (princ "\nInvalid list, the format must be 9x9 assoc list of integers and nils")
  74.     )
  75.     ( (progn (setq nL (apply 'mapcar (cons 'list aL))) nil) ) ; Thats right, I'll write it with column-mode, cause of aligning issues
  76.     (
  77.       (not
  78.         (and (setq dcl (vl-filename-mktemp nil nil ".dcl")) (setq des (open dcl "w"))
  79.           (mapcar (function (lambda (x) (princ (strcat "\n" x) des)))
  80.             (list
  81.               "PlaySudoku : dialog"
  82.               "{ label = \"Sudoku\"; children_alignment = centered; spacer;"
  83.               (strcat
  84.                 "\n: row"
  85.                 "{"
  86.                 (apply 'strcat
  87.                   (progn (setq col -1)
  88.                     (mapcar
  89.                       (function
  90.                         (lambda ( _col ) (setq col (1+ col))
  91.                           (strcat
  92.                             "\n: column"
  93.                             "\n{ children_fixed_width = true; children_alignment = centered; "
  94.                             (apply 'strcat
  95.                               (progn (setq row -1)
  96.                                 (mapcar
  97.                                   (function
  98.                                     (lambda ( x / k ) (setq row (1+ row))
  99.                                       (setq k (apply 'strcat (mapcar 'itoa (list row col))))
  100.                                       (setq kL (cons k kL))
  101.                                       (cond
  102.                                         ( (null x)
  103.                                           (strcat
  104.                                             "\n: edit_box { key = \"" k "\"; alignment = centered; edit_width = 3; }"
  105.                                           ); strcat
  106.                                         ) ; (null x)
  107.                                         ( (eq 'INT (type x))
  108.                                           (strcat
  109.                                             "\n: edit_box { value = \"" (strcat "   " (itoa x)) "\"; key = \"" k "\"; alignment = centered; edit_width = 3; is_enabled = false; }"
  110.                                             ; "\n: button { label = \"" (itoa x) "\"; key = \"" k "\"; width = 1; height = 1; is_enabled = true; }"  ; button tile just can't align properly along with the edit_box
  111.                                           ); strcat
  112.                                         )
  113.                                       ); cond
  114.                                     ); lambda (x)
  115.                                   )
  116.                                   _col
  117.                                 ); mapcar
  118.                               ); progn
  119.                             ); apply 'strcat
  120.                             "\n}"
  121.                           ); strcat
  122.                         ); lambda ( _col )
  123.                       ); function
  124.                       nL
  125.                     ); mapcar
  126.                   ); progn
  127.                 ); apply 'strcat
  128.                 "}"
  129.               ); strcat
  130.               (strcat "  spacer; ok_cancel; : text { label = \"" (setq deferrmsg ">> Solve this Sudoku / Use [TAB] and [1-9] keys <<") "\"; key = \"error\"; }") ; deferrmsg = default error message
  131.               "}"
  132.             ); list
  133.           ); mapcar
  134.           (not (setq des (close des))) (< 0 (setq dch (load_dialog dcl)))
  135.         ); and
  136.       ); not
  137.       (princ "\nUnable to write or load the DCL file.")
  138.     )
  139.     ( (not (new_dialog "PlaySudoku" dch)) (princ "\nUnable to display the dialog") )
  140.     (
  141.       (progn
  142.         (setq kL (reverse kL)) ; zero-based matrix string list: "00", "01" ... "88"
  143.         (mapcar (function (lambda (x) (client_data_tile x (get_tile x)))) kL)
  144.         (setq rL (mapcar 'cons kL (mapcar 'get_tile kL))) ; initially set the return list
  145.         (mapcar
  146.           (function
  147.             (lambda (x)
  148.               (action_tile x
  149.                 (vl-prin1-to-string
  150.                   (quote
  151.                     (
  152.                       (lambda ( / v r c )
  153.                         (mapcar (function (lambda (xx / vi vs) (and (setq vi (txt2num (setq vs (get_tile xx)))) (<= 1 vi 9) (set_tile xx (strcat "   " (itoa (read vs))))))) kL) ; acts like an reactor - prety cool, huh?
  154.                         (set_tile "error" deferrmsg)
  155.                         (mapcar 'set '(r c) (mapcar 'itoa (mapcar '1+ (mapcar 'read (mapcar 'chr (vl-string->list $key))))))
  156.                         (cond
  157.                           ( (= $data $value) )
  158.                           ( (and (setq v (txt2num $value)) (<= 1 v 9))
  159.                             (client_data_tile $key $value)
  160.                             (setq rL (subst (cons $key $value) (assoc $key rL) rL))
  161.                           )
  162.                           ( (progn (set_tile $key $data) (set_tile "error" (strcat "*Error: Invalid input at tile [" r "-" c "].*")) (mode_tile $key 2)) )
  163.                         ); cond
  164.                         ; (setq keys (subst (cons $key $data) (assoc $key keys) keys)) ; QUOTE/apostrophe ruins the 'strcase' status
  165.                       ); lambda ( / v )
  166.                     )
  167.                   ); quote
  168.                 ); vl-prin1-to-string
  169.               ); action_tile x
  170.             ); lambda
  171.           ); function
  172.           kL
  173.         ); mapcar
  174.         (action_tile "accept"
  175.           (vl-prin1-to-string
  176.             '(
  177.               (lambda nil
  178.                 (mapcar
  179.                   (function
  180.                     (lambda (x / k kx ky v ) ; _$ (substr "ab" 1 1) -> "a" ; _$ (substr "ab" 2 2) -> "b"
  181.                       (setq k (car x))
  182.                       (setq kx (atoi (substr k 1 1)))
  183.                       (setq ky (atoi (substr k 2 2)))
  184.                       (setq v (read (cdr x)))
  185.                       (setq aL (_MatrixSubstNth (list kx ky) v aL))
  186.                     )
  187.                   )
  188.                   rL
  189.                 ); mapcar
  190.                 (cond
  191.                   ; ( (not (IsSudokuValid aL)) (set_tile "error" "*** Error: Invalid sudoku! ***") )
  192.                   (
  193.                     (vl-some
  194.                       (function
  195.                         (lambda (x / a b v r c )
  196.                           (setq a (car x)) (setq b (cdr x)) (setq v (read b))
  197.                           (cond
  198.                             ( (and (eq 'INT (type v)) (<= 1 v 9)) nil)
  199.                             (
  200.                               (progn
  201.                                 (mapcar 'set '(r c) (mapcar 'itoa (mapcar '1+ (mapcar 'read (mapcar 'chr (vl-string->list a))))))
  202.                                 (set_tile "error" (strcat "*Error, empty item at Row: " r ", Column: " c "*"))
  203.                                 (mode_tile a 2) T
  204.                               ); progn
  205.                             )
  206.                             ; ( (progn (set_tile "error" (strcat "*** Error: Invalid item: " a "! ***")) (mode_tile a 3) T) )
  207.                           ); cond
  208.                         ); lambda
  209.                       ); function
  210.                       rL
  211.                     ); vl-some
  212.                   )
  213.                   ( (not (PlaySudoku:IsSudokuValid aL))  )
  214.                   ( (done_dialog 1) )
  215.                 ); cond
  216.               ); lambda ( L )
  217.             )
  218.           )
  219.         ); action_tile "accept"
  220.         (/= 1 (setq dcf (start_dialog)))
  221.       ); progn
  222.       (princ "\nUser cancelled the dialog.")
  223.     )
  224.     ( (progn (alert "You won! Next time I'll put some picture here.") T) )
  225.   ); cond
  226.   (*error* nil) (princ) aL
  227. ); defun PlaySudoku
Example:
(PlaySudoku
    (nil nil  4   8  nil nil nil  1   7 )
    ( 6   7  nil  9  nil nil nil nil nil)
    ( 5  nil  8  nil  3  nil nil nil  4 )
    ( 3  nil nil  7   4  nil  1  nil nil)
    (nil  6   9  nil nil nil  7   8  nil)
    (nil nil  1  nil  6   9  nil nil  5 )
    ( 1  nil nil nil  8  nil  3  nil  6 )
    (nil nil nil nil nil  6  nil  9   1 )
    ( 2   4  nil nil nil  1   5  nil nil)
; Answer is:
  (9 3 4 8 2 5 6 1 7)
  (6 7 2 9 1 4 8 5 3)
  (5 1 8 6 3 7 9 2 4)
  (3 2 5 7 4 8 1 6 9)
  (4 6 9 1 5 3 7 8 2)
  (7 8 1 2 6 9 4 3 5)
  (1 9 7 5 8 2 3 4 6)
  (8 5 3 4 7 6 2 9 1)
  (2 4 6 3 9 1 5 7 8)
The dialog is based on a technique I demonstrated here.
And I'm still thankful to Lee Mac for tutoring me on DCL and other different LISP stuff.
BTW I thought about including "I'm giving up" button - that solves the sudoku, by using a subfunction like Stefan's. But at this point I'm leaving the routine like this.
(apply ''((a b c)(a b c))
vevo.bg
ribarm
  • Marko Ribar, architect
« Reply #17 on: November 03, 2017, 06:38:20 AM »
Thanks Grrr, you saved us from typing boring DCL... Nice usage of your subs, btw... Now I shell start torturing people with the hardest one posted by Stefan...
 :evil:
M.R. on Youtube
Grrr1337
« Reply #18 on: November 03, 2017, 08:26:17 AM »
Thanks Marko, I rather find DCL very interesting :)
BTW I think it would be handy if someone wrote an UnSolvedSudokuGenerator routine, that will return a sudoku list (like in our inputs) to be solved.
The only way I could figure out to start with is this:
  1. ; note: 'x' stands for nil symbol (I used it for a better readability)
  2. (foo n)
  3. ->
  4. '( ; argument 'n' will fill for each Sector n amounth of random [1-9] items
  5.   (x x x  x x x  x x x)
  6.   (x x x  x x x  x x x)
  7.   (x x x  x x x  x x x)
  8.
  9.   (x x x  x x x  x x x)
  10.   (x x x  x x x  x x x)
  11.   (x x x  x x x  x x x)
  12.
  13.   (x x x  x x x  x x x)
  14.   (x x x  x x x  x x x)
  15.   (x x x  x x x  x x x)
  16. )
  17.
  18. ; Examples:
  19. (foo 1) -> ; Hard/Impossible ?
  20. '( ; argument 'n' will fill for each Sector n amounth of random [1-9] items
  21.   (1 x x  x x x  x x x)
  22.   (x x x  x 3 x  x x 7)
  23.   (x x x  x x x  x x x)
  24.
  25.   (x x x  4 x x  x x x)
  26.   (x 3 x  x x x  x x x)
  27.   (x x x  x x x  x x 2)
  28.
  29.   (x x x  x x x  x 5 x)
  30.   (2 x x  6 x x  x x x)
  31.   (x x x  x x x  x x x)
  32. )
  33.
  34. (foo 2) -> ; Medium/Hard ?
  35. '( ; argument 'n' will fill for each Sector n amounth of random [1-9] items
  36.   (x 2 x  x x 5  x x x)
  37.   (3 x x  x x x  x x x)
  38.   (x x x  4 x x  1 5 x)
  39.
  40.   (x x 6  x x 3  x x 1)
  41.   (x 1 x  x 7 x  x x x)
  42.   (x x x  x x x  9 x x)
  43.
  44.   (x x x  2 x x  x x 7)
  45.   (x x 2  x x 1  x x x)
  46.   (x 6 x  x x x  x 8 x)
  47. )
  48.
  49. (foo 3) -> ; Easy/Medium
  50. '( ; argument 'n' will fill for each Sector n amounth of random [1-9] items
  51.   (x 2 x  x x 5  x 4 x)
  52.   (3 x x  x 1 x  x x x)
  53.   (x x 4  4 x x  1 5 x)
  54.
  55.   (x x 6  x x 3  x x 1)
  56.   (x 1 x  x 7 x  x x x)
  57.   (5 x x  8 x x  9 x 4)
  58.
  59.   (1 x x  2 x x  2 x 7)
  60.   (x x 2  x x 1  x x x)
  61.   (x 6 x  x 3 x  x 8 x)
  62. )
To split the above task, maybe just generate a different (1 2 3 4 5 6 7 8 9) lists, say given 'n = 3', generate list with random [1-9] numbers on random positions of the list.
Say 9 list outputs like: (nil nil 2 nil 9 nil 6 nil nil) merged into assoc list.
Then use Lee's bar subfunction he posted in Reply #10 to re-assemble the whole list.
Might be required IsUnSolvedSudokuValid function.
Ofcourse before giving any return, must make sure generator's output to be valid/solvable, hence should be wrapped within a loop and tested if the sudoku is solvable(with a routine like Stefan's).
I know my idea doesn't cover all types unsolved sudoku generators, since 'n' amount is not fixed always for the sectors, but would be a good start.
:idea: Then, the future ideas for the DCL work would be:
Initial Dialog Prompt with Buttons (choose difficulty):
[Easy/Medium]
[Medium/Hard]
[Hard/Impossible]
And after all this, the top of the cake would be to make it competitive, where each user collects points for different solved sudoku.
+ wrapping all posted suggestions in this thread will make the overall code better (like including buttons [I'm giving up, show answer] ).
vevo.bg
« Reply #19 on: November 07, 2017, 07:26:49 PM »
Nice DCL Grrr1337 - how about we add some gridlines  :-)
Grrr1337
« Reply #20 on: November 08, 2017, 11:07:31 AM »
Thanks, Lee!
Your dialog looks prettier, so I shall rewrite that code, using your suggestion..
Most importantly for me is that I could learn some new stuff from your code, like the custom predefined tiles and using the dialog's key to set a label - so thanks for sharing!  :-D
BTW I think it would look even better with outer borders, but I'm not good with using/visualising the vector_image funciton, so heres something I can be a shame of  :nerdyembarassed: :...
vevo.bg
pBe
« Reply #21 on: November 08, 2017, 11:48:40 AM »
excellent codes everyone :)
Stefan
« Reply #22 on: November 09, 2017, 10:30:26 AM »
That is slick  8)
  10.          )
  11. )
  13. ...
Thanks for the test ronjonp. On my computer it takes 20sec and 700+ iterations.
I do have another version that takes only 5 sec in my computer and 161 iterations, but at a closer look, it is just by chance. For the reverse matrix, it would take 3000+ iterations and a very long time.
And this is my unfinished sudoku dialog.
« Reply #23 on: November 09, 2017, 10:36:47 AM »
I compiled your code and optimized the '(lambda  to (function (lambda ...  it solved that puzzle in about 1/2 a second. Nice work  :)
« Reply #24 on: November 09, 2017, 12:28:30 PM »
Great dialog Stefan - a shame that the colours invert when an image button is clicked...  :|
Stefan
« Reply #25 on: November 09, 2017, 01:05:19 PM »
Yes, exactly my thoughts... That's why I used 252 for the background. It's very close to its complementary color. What you see flickering is the text and the grid.
Stefan
« Reply #26 on: November 11, 2017, 08:57:46 AM »
New dialog.
Grrr1337
« Reply #27 on: November 11, 2017, 09:24:29 AM »
New dialog.
Wow, this one looks insane!  :-o
Did you use standard DCL or Open/Object DCL to code it?
vevo.bg
« Reply #28 on: November 11, 2017, 10:05:53 AM »
Awesome work Stefan, I'm impressed.
« Reply #29 on: November 11, 2017, 10:41:16 AM »
Impressive work Stefan, kudos.
