Author Topic: L-99: Ninety-Nine Lisp Problems  (Read 3998 times)
« on: October 19, 2017, 03:31:50 PM »
Just found this while surfing the net and thought I'd share.
NOTE: these challenges are for another lisp language (so "answers" to these problems will do you only so much good). Also, keep in mind that other lisp based languages will have other tools available to them or the standard functions may return different items (work slightly different then how/what AutoLisp functions do).
http://www.ic.unicamp.br/~meidanis/courses/mc336/2006s2/funcional/L-99_Ninety-Nine_Lisp_Problems.html
Enjoy!
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: L-99: Ninety-Nine Lisp Problems
« Reply #1 on: October 19, 2017, 06:56:09 PM »
fun find John.
Could lead to some interesting translations.
Called Kerry in my other life
I live at UTC + 13.00
Grrr1337
« Reply #2 on: October 20, 2017, 04:50:03 AM »
Cool stuff! :)
I think it would be fun to solve the first several problems with recursions (attempting yourself ofcourse, no hinting with the answers).
(apply ''((a b c)(a b c))
vevo.bg
ribarm
  • Marko Ribar, architect
« Reply #3 on: October 20, 2017, 05:05:36 AM »
I just did sudoku-mr.lsp... Thanks for inspirations...
M.R. on Youtube
Grrr1337
« Reply #4 on: October 20, 2017, 05:56:24 AM »
Just leaving the crazy idea of creating ACAD_TABLE and populating with as sudoku table,
then wire that ACAD_TABLE with object reactor that constantly checks if the sudoku is solved - if so, say recolor the table in green. :D
But IMO even a sudoku generator is impressive enough.
vevo.bg
ribarm
« Reply #5 on: October 20, 2017, 06:09:16 AM »
I noticed that my algorithm isn't so sophisticated, so it can solve only simple ones like in John's link... But in newspaper that I bought there are less numbers specified and it goes into endless loop... Maybe I need extra logic to implement that I don't know... That's why perhaps there is competition in solving sudoku puzzles...
M.R. on Youtube
« Reply #6 on: October 20, 2017, 07:38:21 AM »
Cool stuff! :)
Ha! I don't know Autolisp anymore (I moved on to other languages a long time ago). Besides, no one want's me back in the lisp world; I think they still have a few t-shirts with some of my "logic rants" on them.
Sounds like you are just learning about recursion. Recursion is very natural and powerful but you need to understand when and when not to use it. For example (step one), do you understand what is meant when AutoCAD returns something about a stack limit/error?
Anyways, I'll take you up on your challenge to do the first few myself. However, recursion certainly isn't needed for those simple ones. If I remember right, Autolisp has a "LAST" function so my first attempt will try to NOT use it (keep with the spirit of the test).
#1
  1. (defun my-last ( lst )
  2.   (car (reverse lst)) )
  3. ; (my-last '(a b c d))
#2
  1. (defun my-but-last ( lst )
  2.      (list (car (reverse lst))
  3.         (cadr (reverse lst)))) )
  4. ; (my-but-last '(a b c d))
#8 (almost; I wanted to `use recursion' as requested and this was kind of an attempt down the path of removing duplicates).
  1. (defun remove-duplicates ( lst )
  2.   (if (null lst)
  3.     nil
  4.     (cons
  5.       (if (member (car lst) (cdr lst))
  6.         'nil
  7.         (list (car lst)))
  8.       (remove-duplicates (cdr lst))) ))
  9.
  10. (defun clean-list ( lst )
  11.   (apply 'append lst) )
  12. ; (clean-list (remove-duplicates '(a a a a b c c a a d e e e e)))
Well, that was fun. Thanks for the challenge. Take care.
« Reply #7 on: October 20, 2017, 08:11:04 AM »
:) ...I built a recursive example for #14. Not at all efficient but it should be a fairly good recursive lesson if anyone's wiling to study it; It's kind of a different take on how the function MAPCAR works.
#14
  1. (defun map-car-iter ( proc lst)
  2.    (map-iter '() proc lst) )
  3.
  4. (defun map-iter (sofar proc lis)
  5.    (if (null lis)
  6.        (reverse sofar)
  7.        (map-iter (cons (proc (car lis))
  8.                        sofar)
  9.                  proc
  10.                  (cdr lis))) )
  11.
  12. (defun dupli (lst)
  13.          (map-car-iter
  14.            (lambda (x) (list x x))
  15.            lst)) )
  16. ; (dupli '(a b c c d))
Actually, I shouldn't say that this is how MAPCAR works because it's not entirely true (sorry). MAPCAR works slightly differently and would be written like this:
  1. (defun map (proc items)
  2.  (if (null items)
  3.     nil
  4.     (cons (proc (car items))
  5.           (map proc (cdr items)))) )
  6.
...Okay, I'm done now. Sorry.
EDIT: Fixed error in code.  "(if (atom lis)  --> (if (null lis)"
« Last Edit: October 20, 2017, 09:42:12 AM by John Kaul (Se7en) »
Grrr1337
« Reply #8 on: October 20, 2017, 08:21:00 AM »
Not really, but its always like a challenge when you have to deal with it (especially if you try to avoid as much as you can LISP functions - say omit reverse, last).
Here are a few attempts of mine (sorry no time to play) :
  1. ; #1
  2. ; _$ (my-last nil '(a b c d)) -> D
  3. (defun my-last ( i L )
  4.   (if L (my-last (car L) (cdr L)) i)
  5. )
  6.
  7. ; #2
  8. ; _$ (my-but-last nil nil '(a b c d)) -> (C D)
  9. (defun my-but-last ( a b L )
  10.   (if L (my-but-last (car L) (cadr L) (cddr L)) (list a b))
  11. )
  12.
  13. ; #3
  14. ; _$ (element-at -1 '(a b c d e) 3) -> D
  15. (defun element-at ( n L i )
  16.   (cond
  17.     ( (not L) L)
  18.     ( (= (setq n (1+ n)) i) (car L) )
  19.     ( (element-at n (cdr L) i) )
  20.   )
  21. )
  22.
  23. ; #4
  24. ; _$ (_length 0 '(a b c d e)) -> 5
  25. (defun _length ( i L )
  26.   (if L (_length (1+ i) (cdr L)) i)
  27. )
  28.
Good stuff John!
vevo.bg
« Reply #9 on: October 20, 2017, 08:38:56 AM »
ah, you're a bare-metal kind of person huh? I was too.
Nonetheless, at one time I was going to help translate some recursion lessons written by ElpanovEvgeniy (member here) written in Russian (not that I speak Russian though and he's damn near a genius so not sure what I was ever going to do) but you may want to see if that exists if you're at all interested in recursion. There was some good stuff in there (pick up more tips and whatnot).
« Reply #10 on: October 20, 2017, 09:05:20 AM »
Didn't anyone think of THIS (NSFW) from the title? :)
Here's some easy 'my-last':
  1. (defun my-last (l) (last l))
  2.
  3.
  4. (defun my-last (l) (nth (1- (length l)) l))
  5.
  6.
  7. (defun my-last (l) (car (reverse l)))
Grrr1337
« Reply #11 on: October 20, 2017, 11:28:30 AM »
Russians do impressive stuff, the only bad thing is that its all written in russian.  :laugh:
I do speak and understand the language but I'm not comfortable with it, due my thoughts are in english.
BTW I just checked in that website what were the answers to my attempts and found some of them are more cleverly written - hopefuly that would flex my thinking for the future.
vevo.bg
« Reply #12 on: October 20, 2017, 11:47:16 AM »
Ugh! Looks like those are in common lisp (yuck!). A lot of that language's features area not implemented in Autolisp. I suppose you could glean more from Scheme (closer--a little--to Autolisp).
With both common lisp and Scheme you have to be extra careful. Some of these guys write crazy code for seemingly obscure reasons not to mention that those languages are far more developed then Autolisp (Scheme at least is object orientated and .net-ified these days).
http://community.schemewiki.org/?ninety-nine-scheme-problems
