Author Topic: Poltergeist?  (Read 4538 times)
Pepe
Poltergeist?
« on: October 18, 2017, 08:13:02 AM »
Hi, everybody!
Lets see if anybody can help me. I have a dwg file in my intranet server that auto-dissapears  :uglystupid2: (I've got back-up, so there's no problem). I tried a copy in the server drive from our back-up drive, but dissapears automatically again  :evillaugh:. I've copied it with another name and stays...  :? I've tried to rename the new one with the old name and dissapears again  :tickedoff:.
Did anyone had the same problem and knows why does it happens (and how solved it, of course)  :idea:?
Thanks in advance.
  • Custom Title
Re: Poltergeist?
« Reply #1 on: October 18, 2017, 08:29:08 AM »
No clue. Sorry. But I do like the subject title. :)
What OS does the server have running on it?
Re: Poltergeist?
« Reply #2 on: October 18, 2017, 08:39:30 AM »
what IF you add something like DrawingName001.dwg does the file stay or does it hide?
Krushert
  • FREE BEER Tomorrow!!
Re: Poltergeist?
« Reply #3 on: October 18, 2017, 09:04:34 AM »
Sounds like to me that there is an ITbot on the server that has it parameters settings to "anal"
Pepe
Re: Poltergeist?
« Reply #4 on: October 18, 2017, 09:28:41 AM »
  :2funny:
Now, seriously... Anybody can help. (System is Windows 10)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Poltergeist?
« Reply #5 on: October 18, 2017, 09:35:58 AM »
We'll need a lot more information.
What are you naming the drawing ?
Is it the only drawing this happens to ?
Are you using any synchronising software ?
etc ...
Called Kerry in my other life
I live at UTC + 13.00
Pepe
Re: Poltergeist?
« Reply #6 on: October 18, 2017, 09:52:26 AM »
Hi, Kdub.
The name is like "XXX_03 Y.1.1.ABCDEFG HI JKLMNOPQRST.dwg"; is in the only file that it happens; no, we don't use any synchronising software.
The path is like "I:\Folder01\Folder02\Folder03\Folder04\Folder05\Folder06\Folder07" (sorry, i'm not allowed to show true name and path). The longest folder name is Folder03 with 47chars, and includes two "." and five spaces.
Thanks!
Re: Poltergeist?
« Reply #7 on: October 18, 2017, 10:02:10 AM »
what if you put some other file type like a document or a picture in the folder structure with the same name, does it stay
or also disappear?
Trying to rule out file type or file name being the cause of it's problem.
  • Custom Title
Re: Poltergeist?
« Reply #8 on: October 18, 2017, 10:11:25 AM »
What is the character limit in file names on Windows?
Krushert
Re: Poltergeist?
« Reply #9 on: October 18, 2017, 10:12:50 AM »
Dammit, Mark!  I was going to say that.   :-P
Re: Poltergeist?
« Reply #10 on: October 18, 2017, 10:24:23 AM »
Individual components of a filename (i.e. each subdirectory along the path, and the final filename) are limited to 255 characters, and the total path length is limited to approximately 32,000 characters. However, you should generally try to limit path lengths to below 260 characters ( MAX_PATH ) when possible.
Re: Poltergeist?
« Reply #11 on: October 18, 2017, 11:00:22 AM »
Placing periods anywhere in a path or filename except to delineate the file extension is asking for worlds of pain. Just don't. Notwithstanding path length limitations.
Pepe
Re: Poltergeist?
« Reply #12 on: October 18, 2017, 11:28:39 AM »
or also disappear?
Thanks mjfarrell: I've changed original file extension to PDF with the same name and stays there, unscathed. So, I conclude that it must be a problem with the file name and extension and only with that file name and extension.
Re: Poltergeist?
« Reply #13 on: October 18, 2017, 11:36:19 AM »
or also disappear?
Now we are getting somewhere....
not sure if the signpost up ahead reads The Twilight Zone or not just yet.   :)
alterego
Re: Poltergeist?
« Reply #14 on: October 18, 2017, 11:40:33 AM »
Do you have some sort of EDMS?  could that be causing issues?
Re: Poltergeist?
« Reply #15 on: October 18, 2017, 11:51:43 AM »
What antivirus are you using? Perhaps a false positive?
  • Custom Title
Re: Poltergeist?
« Reply #16 on: October 18, 2017, 11:57:31 AM »
Where is your sense of adventure MP? LOL
Re: Poltergeist?
« Reply #17 on: October 18, 2017, 12:25:43 PM »
Between advantage and adversity.  :-P
Pepe
Re: Poltergeist?
« Reply #18 on: October 18, 2017, 12:26:39 PM »
As far as I know, no EMDS is used, Alterego.
McAfee, ronjonp. Checked the file and absolutely clean.
Entering the Twilight Zone.. (teenee-nee-nee...teenee-nee-nee...)
Re: Poltergeist?
« Reply #19 on: October 18, 2017, 12:28:00 PM »
Does it disappear immediately, or over night? If over night .. perhaps a cleanup script is being run?
Pepe
Re: Poltergeist?
« Reply #20 on: October 18, 2017, 12:54:45 PM »
Hi ronjonp,
(CET time...) Today about 10:00h the file was Ok; about 12:30h began the mess...
Greg B
  • Tell me a Joke!
Re: Poltergeist?
« Reply #21 on: October 18, 2017, 01:37:25 PM »
Someone else screwing with you in the office, or on a more serious note, someone else working in the project as well?
Krushert
Re: Poltergeist?
« Reply #22 on: October 18, 2017, 02:54:38 PM »
He said it was a Poltergeist.  Duhhhhh  :tongue2:
Chaif
Re: Poltergeist?
« Reply #23 on: October 26, 2017, 09:44:01 AM »
As it's a server. Do you sure it's not someone's joke?
