Author Topic: Assoc List - Group By Keys  (Read 8243 times)
Marc'Antonio Alessi
  • Marco
Re: Assoc List - Group By Keys
« Reply #15 on: October 09, 2017, 03:38:51 PM »
Just a little faster
(defun ALE_GroupByKey2 (lst / TKey OKey RKey keys tmpL OutLst)
  (setq TKey (strcat "#" (caar lst))  keys (list TKey))
  (set (read TKey) (list (caar lst) (cdar lst)))
  (foreach itm (cdr lst)
    (setq OKey (car itm)   tmpL (cdr itm) TKey (strcat "#" OKey)  RKey (read TKey))
    (if (vl-position TKey keys)
      (set RKey (vl-list* OKey tmpL (cdr (eval RKey))))
        (set RKey (list OKey tmpL))
        (setq keys (cons TKey keys))
  (foreach itm keys
    (setq RKey (read itm)  OutLst (cons (eval RKey) OutLst))
    (set RKey nil)
  OutLst
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 1 iteration(s):
    (ALE_GROUPBYKEY2 TEST1)......2547 / 1.05 <fastest>
    (GROUPBYKEY-FOOLS TEST1).....2672 / 1 <slowest>
Marc'Antonio Alessi
  • Marco
« Reply #16 on: October 10, 2017, 08:46:18 AM »
Other 2 versions slower on big lists:
(defun ALE_GroupByKey3 (l / k s r p)
  (foreach i l
    (if (vl-position (setq k (car i)) s)
      (setq p (assoc k r)  r (subst (vl-list* (car i) (cdr i) (cdr p)) p r))
      (setq s (cons k s)   r (cons (list k (cdr i)) r))
(defun ALE_GroupByKey4 (l / k s r p x)
  (foreach i l
    (if (setq x (vl-position (setq k (car i)) s))
      (setq p (nth x r)    r (subst (vl-list* (car i) (cdr i) (cdr p)) p r))
Marc'Antonio Alessi
  • Marco
« Reply #17 on: October 10, 2017, 10:10:59 AM »
; UltraDemential > ALE_List_Nth see: https://www.theswamp.org/index.php?topic=46419.msg514475#msg514475
(defun ALE_GroupByKeyUD (l / k s r p x)
  (foreach i l
      (setq p (ALE_List_Nth x r)   r (subst (vl-list* (car i) (cdr i) (cdr p)) p r))
