Author Topic: Name of Dimension Style Child  (Read 1990 times)
MSTG007
« on: September 28, 2017, 02:57:49 PM »
Drawing a blank here. I am trying to access the Dimstyle Childs name via the (-dimstyle) command. I am actually trying to change the precision from hundredths to tenths.
Thanks for the help!
Civil3D 2020
Crank
Re: Name of Dimension Style Child
« Reply #1 on: September 28, 2017, 03:21:32 PM »
name         Parent (main)
name$0       Linear
name$2       Angular
name$3       Diameter
name$4       Radial/jogged
name$6       Ordinate
name$7       Leader
I don't know if a 'name$1' or 'name$5' exist nor what they represent.
« Reply #2 on: September 28, 2017, 03:30:36 PM »
pretty sure you can't  with -dimstlye
Crank
« Reply #3 on: September 28, 2017, 03:36:59 PM »
Make an override of the parent dimstyle and then save the dimstyle with the substyle name.
For new dimensions the substyle will automaticly be used if the parent dimstyle is current.
Existing dimensions need to be updated.
MSTG007
« Reply #4 on: September 29, 2017, 10:21:46 AM »
Crank,
Could you walk me through alittle bit more on your idea? Not following it totally.
Civil3D 2020
« Reply #5 on: September 29, 2017, 10:47:17 AM »
or rename the 'child style'
it then becomes a style you can access with -DIMSTYLE
Crank
« Reply #6 on: October 03, 2017, 05:28:53 PM »
Crank,
Here's an example of very basic code that may help you:
; https://www.theswamp.org/index.php?topic=53489.0
(defun c:DimDef18 () (MakeDstyle "CROC" 1.8))
(defun c:DimDef25 () (MakeDstyle "CROC" 2.5))
(defun c:DimDef35 () (MakeDstyle "CROC" 3.5))
(defun MakeDstyle (dimname th / ts)
;********************************************** Variables for parent:
(if (not (tblsearch "STYLE" "SWAMP"))(progn
(setq ts (getvar "TEXTSTYLE"))
(command-s ".-style" "SWAMP" "romanc.shx" "A" "y" "n" "" "1.0" "0.0" "N" "N" "N")
(setvar "TEXTSTYLE" ts)
(setvar "DIMARCSYM" 0) (setvar "DIMADEC" 0) (setvar "DIMALT" 0) (setvar "DIMALTD" 2) (setvar "DIMALTF" (/ 1.0 25.4))
(setvar "DIMALTRND" 0.0)(setvar "DIMALTTD" 2) (setvar "DIMALTTZ" 0) (setvar "DIMALTU" 8)
(setvar "DIMALTZ" 0) (setvar "DIMAPOST" ".") (setvar "DIMASSOC" 2)
(setvar "DIMASZ" 2.5) (setvar "DIMATFIT" 0) (setvar "DIMAUNIT" 0) (setvar "DIMAZIN" 2)
(setvar "DIMBLK" ".") (setvar "DIMBLK1" ".") (setvar "DIMBLK2" ".") (setvar "DIMCEN" 2.0)
(setvar "DIMCLRD" 0) (setvar "DIMCLRE" 0) (setvar "DIMCLRT" 2) (setvar "DIMDEC" 3)
(setvar "DIMDLE" 0.0) (setvar "DIMDLI" (fix (* th 2.86))) (setvar "DIMDSEP" ",") (setvar "DIMEXE" 1.0)
(setvar "DIMEXO" 3.0) (setvar "DIMFIT" 4) (setvar "DIMFRAC" 0) (setvar "DIMGAP" (* 0.2 th))
(setvar "DIMJOGANG" (dtr 60))(setvar "DIMJUST" 0) (setvar "DIMLDRBLK" ".")(setvar "DIMLFAC" 1.00)
(setvar "DIMLIM" 0) (setvar "DIMLTEX1" "BYBLOCK") (setvar "DIMLTEX2" "BYBLOCK") (setvar "DIMLTYPE" "BYBLOCK")
(setvar "DIMLUNIT" 2) (setvar "DIMLWD" -2) (setvar "DIMLWE" -2) (setvar "DIMPOST" ".")
(setvar "DIMRND" 0.000) (setvar "DIMSAH" 0) (setvar "DIMSD1" 0) (setvar "DIMSD2" 0)
(setvar "DIMSCALE" 0) (setvar "DIMSE1" 0) (setvar "DIMSE2" 0) (setvar "DIMSOXD" 0)
(setvar "DIMTAD" 1) (setvar "DIMTDEC" 3) (setvar "DIMTFAC" 1.0) (setvar "DIMTFILL" 0) (setvar "DIMTFILLCLR" 0)
(setvar "DIMTIH" 0) (setvar "DIMTIX" 1) (setvar "DIMTM" 0.0) (setvar "DIMTMOVE" 1) (setvar "DIMTOFL" 1)
(setvar "DIMTOH" 0) (setvar "DIMTOL" 0) (setvar "DIMTOLJ" 1) (setvar "DIMTP" 0.0)
(setvar "DIMTSZ" 0.0) (setvar "DIMTVP" 0.0) (setvar "DIMTXSTY" "SWAMP")(setvar "DIMTXT" 2.5)
(setvar "DIMTZIN" 0) (setvar "DIMUPT" 0) (setvar "DIMZIN" 8)
;********************************************** Settings for textheigth:
(setvar "DIMTXT" th)(setvar "DIMCLRT" (fix th))
(setq dimname (strcat dimname (rtos (* th 10))))
;********************************************** Make sure the parent dimstyle exists:
(if (not (tblsearch "DIMSTYLE" dimname))
(savedimstyle dimname "")
;********************************************** Substyles with overrides:
; lineair
(make_SWAMPTICK); create block
(setvar "DIMBLK" "SWAMPTICK")
(if (< th 2)(setvar "DIMASZ" 0.7)(setvar "DIMASZ" 1.0))
(savedimstyle dimname "$0")
; angular
(setvar "DIMDEC" 0)
(setvar "DIMADEC" 2)
(setvar "DIMATFIT" 1)
(setvar "DIMTMOVE" 2)
(setvar "DIMTIX" 0)
(setvar "DIMTIH" 1)
(setvar "DIMTOH" 1)
(savedimstyle dimname "$2")
; diameter
(setvar "DIMATFIT" 2)
(setvar "DIMTMOVE" 0)
(setvar "DIMTIX" 0)
(savedimstyle dimname "$3")
; radial
(setvar "DIMTIX" 0)
(setvar "DIMPOST" "r=<>")
(savedimstyle dimname "$4")
; coords
; (setvar )
(savedimstyle dimname "$6")
; leader
; (setvar )
(savedimstyle dimname "$7")
(defun savedimstyle (parent sub / )
(setq name (strcat parent sub))
(if (tblsearch "DIMSTYLE" name)
(command-s ".-dimstyle" "ANnotative" "yes" name "YES" "SAVE" name "YES")
(command-s ".-dimstyle" "ANnotative" "yes" name "SAVE" name "YES")
(command-s ".dim1" "restore" parent); Restore Parent dimstyle <<<<<<<<<<<
(defun dtr ( deg ) (* pi (/ deg 180.0)))
(defun make_SWAMPTICK ()
(setvar "NOMUTT" 1)
(entmake '((0 . "BLOCK") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockReference") (2 . "SWAMPTICK") (10 0 0 0) (70 . 0)))
(entmake '((0 . "LINE")  (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 0) (6 . "ByBlock") (100 . "AcDbLine") (10 0 -2 0) (11 0 2 0)))
(entmake '((0 . "LINE")  (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 0) (6 . "ByBlock") (100 . "AcDbLine") (10 -2 0 0) (11 2 0 0)))
(entmake '((0 . "LINE")  (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 2) (6 . "ByBlock") (100 . "AcDbLine") (10 -1 -1 0) (11 1 1 0)))
(entmake '((0 . "ENDBLK")(100 . "AcDbBlockEnd")        (8 . "0")))
(setvar "NOMUTT" 0)
First a parent dimstyle is created and current.
If you need a substyle, then change some dim variables. At this point you have a parent dimstyle with overrides.
Save these dim variables to a new dimstyle with the proper name for the substyle.
Repeat this for every substyle and be sure the parent style is current again.
So basicly all you have to do is change a variable and then save the dimstyle.
Nb.: Your varibles will be different. Use the following command to find the settings of your dimstyle:
SETVAR ?
DIM*
« Last Edit: October 03, 2017, 05:39:11 PM by Crank »
