Author Topic: How to develop this lisp to avoid Xref layers?  (Read 3306 times)
HasanCAD
« on: September 27, 2017, 05:11:54 AM »
This lispd draws a line and a text with layer name and description for each layer
I am wondering, How to avoid layers for XREFs to apply
  1. (defun c:LLD () (c:LayerLegend))
  2.
  3. (defun c:LayerLegend ( / df i ln p1 pt sp ) ;; Lee Mac 2011
  4.   (if
  5.     (and
  6.       (setq pt (getpoint "\nSpecify Point for Legend: "))
  7.       (setq ln (* 100 (getvar 'TEXTSIZE))) ;(getdist  "\nSpecify Length of Lines: " pt))
  8.       (setq pt (trans pt 1 0))
  9.       (setq i -1)
  10.       (setq sp (* 1.5 (getvar 'TEXTSIZE)))
  11.     )
  12.     (while (setq df (tblnext "LAYER" (null df)))
  13.       (setq ent (vlax-ename->vla-object (tblobjname "LAYER" (cdr (assoc 2 df)))))
  14.       (setq dsc (vlax-get-property ent 'Description))
  15.       (setq nm  (vlax-get-property ent 'name))
  16.       (entmakex (list
  17.                   (cons 0 "LINE")
  18.                   (cons 8 (cdr (assoc 2 df)))
  19.                   (cons 6 "ByLayer")
  20.                   (cons 62 256)
  21.                   (cons 10
  22.                         (setq p1 (polar pt (* 1.5 pi) (* (setq i (1+ i)) sp)))
  23.                         )
  24.                   (cons 11 (polar p1 0. ln))
  25.                   (cons 370 -1)
  26.                   )
  27.                 )
  28.
  29.       (entmakex (list (cons 0 "TEXT")   ;***
  30.                  (cons 1 (strcat (cdr (assoc 2 df)) " : " dsc))         ;* (the string itself)
  31.                  (cons 6 "BYLAYER")     ; Linetype name
  32.                  (cons 7 (getvar 'TEXTSTYLE))           ;* Text style name, defaults to STANDARD, not current
  33.                  (cons 8 (cdr (assoc 2 df)))            ; layer
  34.                  (cons 10 p1)           ;* First alignment point (in OCS)
  35.                  (cons 11 p1)           ;* Second alignment point (in OCS)
  36.                  (cons 39 0.0)          ; Thickness (optional; default = 0)
  37.                  (cons 40 (getvar 'TEXTSIZE))           ;* Text height
  38.                  (cons 41 1.0)          ; Relative X scale factor, Width Factor, defaults to 1.0
  39.                  (cons 62 256)          ; color
  40.                  (cons 71 0)            ; Text generation flags
  41.                  (cons 72 0)            ; Horizontal text justification type
  42.                  (cons 73 1)            ; Vertical text justification type
  43.                  (cons 210 (list 0.0 0.0 1.0))
  44.                  (cons 370 -1)
  45.                       ))
  46.       )    )
  47.   (princ)
  48.   )
« Last Edit: September 27, 2017, 06:55:20 AM by HasanCAD »
Grrr1337
Re: How to develop this lit to avoid Xref layers?
« Reply #1 on: September 27, 2017, 06:00:25 AM »
Like this, I guess:
  1. (defun GetNonXrefLayers ( / d L )
  2.   (while (setq d (tblnext "LAYER" (not d)))
  3.     (and
  4.       (/= 16 (logand 16 (cdr (assoc 70 d))))
  5.       (setq L (cons (cdr (assoc 2 d)) L))
  6.     )
  7.   )
  8.   L
  9. ); defun GetNonXrefLayers
(apply ''((a b c)(a b c))
vevo.bg
HasanCAD
Re: How to develop this lisp to avoid Xref layers?
« Reply #2 on: September 27, 2017, 09:27:25 AM »
Thanks Grrr1337
Working perfict
Grrr1337
« Reply #3 on: September 27, 2017, 10:18:56 AM »
Thanks Grrr1337
Working perfict
No problem, I'm glad this helped. :)
vevo.bg
cmwade77
« Reply #4 on: October 02, 2017, 07:51:01 PM »
Like this, I guess:
  3.     (and
  6.     )
  7.   )
  8.   L
Much more elegant than what I as going to suggest, my suggestion was going to be to see if the layername has | in it, if it does, it is an xRef layer since you can't add that character yourself to layer names.
Grrr1337
« Reply #5 on: October 02, 2017, 08:19:33 PM »
Yeah, the other option would be:
  1. (wcmatch (cdr (assoc 2 d)) "~*|*")
vevo.bg
HasanCAD
« Reply #6 on: October 03, 2017, 10:47:08 AM »
Thanks Grrr1337
Both solutions working very well
Grrr1337
« Reply #7 on: October 03, 2017, 04:41:02 PM »
Thanks Grrr1337
No problem. I've got null experience when dealing with xref layers, so I'm happy to learn something new by a little practice.
I guess that the name wcmatching approach is rarely used because...
_$ (vla-Add (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) "MyNew|Layer")
#<VLA-OBJECT IAcadLayer 00000093e05a3198>
One could add programatically layer with a "xref" name.
vevo.bg
roy_043
  • BricsCAD 18
« Reply #8 on: October 04, 2017, 11:25:40 AM »
@Grrr1337: In BricsCAD the _Audit command will fix such faulty names.
« Reply #9 on: October 04, 2017, 11:40:53 AM »
Same in AutoCAD:
Command: AUDIT
Fix any errors detected? [Yes/No] <N>: y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 200     objects audited
Non XREF-dependent record "Test|Test" contains vertical bar.
  Changed to "AUDIT_I_171004093954-0".
Grrr1337
« Reply #10 on: October 04, 2017, 01:38:17 PM »
Thanks guys, I was not aware that AUDIT does that.
vevo.bg
