Author Topic: cannot create layer through my custom panel?  (Read 2345 times)
netcai
  • Mosquito
« on: September 25, 2017, 10:07:12 PM »
I create a panel with one button,when I click the button,it will call a command to create a layer and linetype, but autocad always prompt me a "eLockViolation" error.
If I do not use panel,the code create layers and linetype correctly.
public class Command
        static PaletteSet palette;
        static bool wasVisible;
        /// <summary>
        /// Creates the palette if it did not already exist, and shwos it.
        /// </summary>
        [CommandMethod("test" )]
        public static void CreateGridPanel()
            if (palette == null)
                palette = new PaletteSet("CaiGrid", "CONVPALETTE", new Guid("{929CAC46-8606-4580-A953-238B70CA76A1}"));
                palette.Style =
                    PaletteSetStyles.ShowAutoHideButton |
                    PaletteSetStyles.ShowCloseButton |
                    PaletteSetStyles.ShowPropertiesMenu;
                palette.MinimumSize = new System.Drawing.Size(410, 240);
                palette.AddVisual("CaiGrid", new GridView());
                // Automatically hides the palette while there is no active document.
                var docs = Application.DocumentManager;
                docs.DocumentBecameCurrent += (s, e) => palette.Visible = e.Document == null ? false : wasVisible;
                docs.DocumentCreated += (s, e) => palette.Visible = wasVisible;
                docs.DocumentToBeDeactivated += (s, e) => wasVisible = palette.Visible;
                docs.DocumentToBeDestroyed += (s, e) =>
                    if (docs.Count == 1)
                        palette.Visible = false;
            palette.Visible = true;
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: cannot create layer through my custom panel?
« Reply #1 on: September 25, 2017, 10:47:04 PM »
Investigate
Document.LockDocument()
and google eLockViolation Autocad
https://www.google.com.au/search?q=elockviolation+AutoCad
Called Kerry in my other life
I live at UTC + 13.00
netcai
  • Mosquito
« Reply #2 on: September 25, 2017, 10:56:21 PM »
thanks kdub,It's work now.
 I wonder if all the modeless winform or panel need to lock the document ?
gile
  • Marseille, France
« Reply #3 on: September 26, 2017, 01:25:06 AM »
From Kean Walmsley's blog:
Once again there’s our important rule of thumb when it comes to implementing a modeless UI: rather than manually locking the current document, it’s safer to define a command – which will implicitly lock the current document – and call that from the UI via SendStringToExecute().
nobody
  • .net stuff
« Reply #4 on: September 27, 2017, 02:37:23 AM »
How does one "manually" lock a document anyway XD ?
gile
  • Marseille, France
« Reply #5 on: September 27, 2017, 02:50:35 AM »
Code - C#: [Select]
  1.             Document doc = Application.DocumentManager.MdiActiveDocument;
  2.             if (doc != null)
  3.             {
  4.                 using (doc.LockDocument())
  5.                 {
  6.                     // you can safely use doc here
  7.                 }
  8.             }
