Author Topic: How to Automate AutoCad  (Read 1366 times)
jthos
« on: September 21, 2017, 04:15:54 AM »
Hi everybody,
I'm new with AutoCad.
I'd like to ask you on what would be the best (or more simple) way to run an AutoCad command from command line.
What I really need is a command showing the list of referenced files inside a dwg file. Can it be done from command line in some way? May be using Accoreconsole.exe? Or it must be done from an AutoCad instance? How can it be automated?
Thank you in advance for your tips.
Regards,
« Last Edit: September 21, 2017, 04:20:39 AM by jthos »
hudster
Re: How to Automate AutoCad
« Reply #1 on: September 21, 2017, 05:35:47 AM »
You can get a list of Xrefs direct from the command line by typing this
-xref
jthos
« Reply #2 on: September 21, 2017, 06:48:48 AM »
Thank you,
But I mean windows command line (DOS window)
tombu
  • ByLayer=>Not0
« Reply #3 on: September 21, 2017, 12:23:02 PM »
Reference Manager is what you're looking for.
You can start it from Windows Aplications list under AutoCAD or in AutoCAD with lisp: http://forums.augi.com/showthread.php?164118-Select-multiple-Reference-Name-and-set-one-new-file-path-at-same-time&p=1302861&viewfull=1#post1302861
« Last Edit: September 21, 2017, 12:30:22 PM by tombu »
Tom Beauford P.S.M.
