Author Topic: setvariable fails in 2018, works in previous versions?  (Read 1890 times)
« on: September 20, 2017, 12:33:39 PM »
Riddle me this.... at the command line in 2018 this works.
Command: DYNMODE
Enter new value for DYNMODE <-3>: 3
Command: SETVAR
Enter variable name or [?] <DYNMODE>:
Enter new value for DYNMODE <3>: -3
Command: (setq *doc* (vla-get-activedocument (vlax-get-acad-object)))
#<VLA-OBJECT IAcadDocument 00000000293ddd08>
Command: (vla-setvariable *doc* "dynmode" 3)  ;;<<<<<works in earlier versions
; error: Automation Error. Error setting system variable;;; yet 2018 throws this
Re: setvariable fails in 2018, works in previous versions?
« Reply #1 on: September 20, 2017, 12:47:58 PM »
Same behavior here .. although (SETVAR 'DYNMODE 3) works fine.
« Reply #2 on: September 20, 2017, 01:03:00 PM »
Thanks, ronjonp!
« Reply #3 on: September 20, 2017, 01:11:54 PM »
Does it work if you supply a variant?, e.g.:
  1. (vla-setvariable *doc* "dynmode" (vlax-make-variant 3))
« Reply #4 on: September 20, 2017, 02:12:40 PM »
Command: (vla-setvariable *doc* "dynmode" (vlax-make-variant 3))
ChrisCarlson
« Reply #5 on: September 20, 2017, 03:01:14 PM »
Interesting, modifying it to vla-GetVariable works as expected.
dgorsman
« Reply #6 on: September 21, 2017, 12:40:30 PM »
Don't have it installed here, so another diagnostic stab in the dark - what does the "available" function say (I think it's vlax-property-available-p...) about read-write status?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
BIGAL
  • 40 + years of using Autocad
« Reply #7 on: September 22, 2017, 04:39:20 AM »
Just a dumb suggestion is it 3 or "3" some bright spark may have changed something.
Did not work on civ3d 2018 ???
« Last Edit: September 22, 2017, 04:47:25 AM by BIGAL »
