Author Topic: TRACKING change in Text Attribute  (Read 1217 times)
mailmaverick
« on: September 20, 2017, 09:50:42 AM »
How to change TRACKING setting (\T) setting in Attribute of a Block ?
I want \T to be 2.65.
roy_043
  • BricsCAD 18
Re: TRACKING change in Text Attribute
« Reply #1 on: September 20, 2017, 11:50:07 AM »
Of course the attribute would have to be an MTextAttribute and AFAIK adding this formatting to the attribute definition has no effect.
For an mtext attribute reference this works:
  1. (setq obj (vlax-ename->vla-object (car (nentsel))))
mailmaverick
« Reply #2 on: September 25, 2017, 03:49:37 AM »
Thanks Roy but problem is how to add Mtext Attribute ?
When i Do Right Click on Block ->Block Editor, it goes into the editor.
Then in the Menu above, there is an option of "Attribute Definition" which when i click, it always puts DTEXT and not MTEXT. And when I run TXT2MTXT Express Tool Command on it, it no longer remains an attribute and changes to Mtext.
roy_043
  • BricsCAD 18
