I do trigger my export during the SaveComplete event:
public void Initialize()
Application.DocumentManager.DocumentCreated += DocumentManager_DocumentCreated;
foreach (Document doc in Application.DocumentManager)
doc.Database.SaveComplete += OnDatabaseSaveComplete;
and my event handler:
private void OnDatabaseSaveComplete(object sender, DatabaseIOEventArgs e)
// ignore when the document is being auto saved
if (e.FileName.Contains(".sv$"))
return;
var currentFilename = doc.Name;
if ((currentFilename.Contains("-CSA-")) ||
(currentFilename.Contains("-S-")) ||
(currentFilename.Contains("-B-")) ||
(currentFilename.Contains("-F-")))
ExportTo3dDwf();
and ExportTo3dDwf detaches all xrefs and thaws all layers... but my intention is to not modify the database.. I want to leave the DWG as is before I detach xrefs and thaw layers in preparation to export to dwf.
So I am using some of the nifty routines found here.. this is the how I am Thawing all layers:
[CommandMethod("Thawall")]
public static void ThawAll()
LayerTableRecord layer;
string curLayer = (string)Application.GetSystemVariable("CLayer");
LayerTable lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
foreach (ObjectId layerId in lt)
layer = tr.GetObject
(layerId, OpenMode.ForWrite) as LayerTableRecord;
if (layer.Name != curLayer)
layer.IsFrozen = false;
tr.Commit();
Application.DocumentManager.MdiActiveDocument.Editor.Regen();
So how can I do this, and NOT save / modify the DWG? I have tried removing the commit, but it still modifies the DWG.
In some old LISPs, I see (acad-push-dbmod)
to prevent saving the changes to the drawing. How do I do that in C#?
