Author Topic: Can anyone help with stair step / slope corridor  (Read 3289 times)
nobody
  • .net stuff
« on: September 15, 2017, 09:04:38 PM »
I need to create a stair step-like corridor. See attached image.  X is 30-ft.  The steps are 5ftx5ft.  The bottom slope is 2.5:1.
When the slope can't reach the height (y) it should start adding steps.
Any assistance would be appreciated.  I tried cheating with curbs and shoulders and stuff but isn't really working out.
Attached my working drawing. I am able to do it with just benches but need to slope as much as I can to eliminate the steps.
« Last Edit: September 16, 2017, 02:42:09 PM by FriendFromArea51 »
Re: Can anyone help with stair step / slope corridor
« Reply #1 on: September 17, 2017, 10:24:22 AM »
ypu are going to want to look into "Conditional" Assembly - look at conditional Cut Fill
this will let you set your IF >>Then statement in the assemble properties.
nobody
  • .net stuff
« Reply #2 on: September 17, 2017, 01:13:51 PM »
Thanks MJ
« Reply #3 on: September 17, 2017, 02:32:01 PM »
A further note, name those conditionals very well....it helps when setting targets and the condition it looks for.
nobody
  • .net stuff
« Reply #4 on: October 08, 2017, 10:23:15 PM »
Ended up getting help with the subassembly composer. Works well.
« Reply #5 on: October 09, 2017, 09:04:08 AM »
As I've been told, IF you can do it with sub assembly links FIRST, doing it with sub assembly composer gets a little easier.
I find that sub assembly links allows one to test the logic, before going into composer, sort of a sand box.
