Author Topic: Overwrite existing PDF plot  (Read 1915 times)
« on: September 13, 2017, 11:12:07 AM »
Why is it I can overwrite and existing PDF file using the PLOT command but not the PUBLISH command? Doesn't matter where the folder is located or its attributes.
AutoCAD 2017
ChrisCarlson
Re: Overwrite existing PDF plot
« Reply #1 on: September 13, 2017, 02:20:23 PM »
Cannot replicate on Vanilla 2018
dgorsman
« Reply #2 on: September 13, 2017, 07:01:17 PM »
Multi-sheet or single-sheet PDF output?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #3 on: September 14, 2017, 07:34:29 AM »
either.
« Reply #4 on: September 14, 2017, 09:49:57 AM »
Same thing with Map - 2017
alterego
« Reply #5 on: September 14, 2017, 10:10:51 AM »
I have had that message at a previous place I worked at. If I had opened the PDF once during the day and closed it, it seemed to still have a "lock" on the file until I rebooted the computer.
MSTG007
« Reply #6 on: September 14, 2017, 10:21:50 AM »
Do you have to delete the file PDF then re print? I have to do that sometimes in certain network folders.
Civil3D 2020
« Reply #7 on: September 14, 2017, 10:39:08 AM »
Yes I do. This is a local drive.
