Author Topic: vla-rotate selection set  (Read 1183 times)
mailmaverick
« on: September 13, 2017, 01:41:46 AM »
How to rotate a selection set using vla-rotate.
roy_043
  • BricsCAD 18
Re: vla-rotate selection set
« Reply #1 on: September 13, 2017, 02:41:18 AM »
You will have to iterate over the selection set and rotate each object separately.
« Reply #2 on: September 13, 2017, 09:23:31 PM »
Convert SS to list & use:
   (defun GroupRotate (objects bpt ang)
      (setq bpt (vlax-3D-point bpt))
      (mapcar(function(lambda(x)
        (vl-catch-all-apply 'vla-rotate (list x bpt ang))))
       Objects)
mailmaverick
« Reply #3 on: September 14, 2017, 10:12:13 AM »
Thanks.
