Author Topic: Move point perpendicular to line  (Read 2970 times)
lkrkck
  • Mosquito
« on: September 12, 2017, 07:29:03 AM »
Hello,
I've this code to move some AcadPoints tPerpendicular of one 2DPoliline.
The problem: I've this points with Z value, when i run the code this points goes perpendicular to line but with Z=0.
(defun c:SnapToObj ( / en obj pts_ss ss_len c pten ptobj pted pt pt2)
(setq en (car (entsel "\nSelect Object: ")))
(setq obj (vlax-ename->vla-object en))
(princ "\nSelect points: ")
(setq pts_ss (ssget (list (cons 0 "POINT"))))
(setq ss_len (sslength pts_ss))
(setq c 0)
(while (< c ss_len)
(setq pten (ssname pts_ss c))
(setq ptobj (vlax-ename->vla-object pten))
(setq pted (entget pten))
(setq pt (cdr (assoc 10 pted)))
(setq pt2 (vlax-curve-getClosestPointTo obj pt))
(vla-move ptobj (vlax-3d-point pt) (vlax-3d-point pt2))
(setq c (+ c 1))
roy_043
  • BricsCAD 18
roy_043
  • BricsCAD 18
Re: Move point perpendicular to line
« Reply #3 on: September 12, 2017, 09:20:59 AM »
The point Z value should equal whatever elevation the polyline it is snapping to ?  Here's a quick one to retain the original Z value:
  1. (defun c:s2o (/ e el p p2 s)
  2.   ;; RJP - 9/12/2017
  3.   (if (and (setq e (car (entsel "\nSelect Object: ")))
  4.            (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list e))))
  5.            (princ "\nSelect points: ")
  6.            (setq s (ssget ":L" (list '(0 . "POINT"))))
  7.       )
  8.     (foreach pt (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  9.       (setq p (cdr (assoc 10 (setq el (entget pt)))))
  10.       (entmod (append el (list (cons 10 (list (car p2) (cadr p2) (caddr p))))))
  11.     )
  12.   )
  13.   (princ)
  14. )
« Last Edit: September 12, 2017, 09:26:32 AM by ronjonp »
lkrkck
  • Mosquito
« Reply #4 on: September 12, 2017, 09:25:34 AM »
Good Job ronjonp!
Thank you...
  4.            (princ "\nSelect points: ")
  5.            (setq s (ssget ":L" (list '(0 . "POINT"))))
  6.       )
  7.     (foreach pt (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  8.       (setq p (cdr (assoc 10 (setq el (entget pt)))))
  9.       (entmod (subst (cons 10 (list (car p2) (cadr p2) (caddr p))) (assoc 10 el) el))
  10.     )
  11.   )
  12.   (princ)
  13. )
« Reply #5 on: September 12, 2017, 09:29:45 AM »
Glad to help :) .. btw I updated the code above to make sure the object picked to snap to is actually a curve object.
symoin
  • Mosquito
« Reply #6 on: February 11, 2024, 10:53:22 AM »
  7.       )
  11.     )
  12.   )
  13.   (princ)
  14. )
Hi RONJOP,
Instead of Moving a single point to a single line, Is it possible to copy the Multiple points to Multiple polylines ( to left and right side) as keeping the Z elevation the same?
Could you, please update the code.
Thanks in advance.
« Last Edit: February 11, 2024, 11:15:08 AM by symoin »
« Reply #7 on: February 12, 2024, 12:51:02 PM »
Do you have a sample drawing to share with the desired results? I'm not exactly sure what you need. "copy the Multiple points to Multiple polylines ( to left and right side)"
symoin
  • Mosquito
« Reply #8 on: February 14, 2024, 09:41:07 AM »
Hi RONJOP,
I have attached the sample, Here there is a point in the section before, which is then copies (approximately) to the nearest polylines. For my present requirement this approximate location is enough. But in code approximate location don't make any senes.
Thanks for your response.
ribarm
  • Marko Ribar, architect
« Reply #9 on: February 14, 2024, 10:45:22 AM »
Nothing special...
  1. (defun c:copypts2curves ( / ss s p ptx lay p2 )
  3.   ;; mod. M.R. - 02/14/2024
  4.   (if (and (princ "\nSelect curve entities : ")
  5.           (setq ss (ssget (list '(0 . "~POINT"))))
  6.           (vl-every '(lambda ( x ) (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list x))))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  7.           (princ "\nSelect points : ")
  8.           (setq s (ssget (list '(0 . "POINT"))))
  9.       )
  10.     (foreach pt (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  11.       (foreach curve (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  12.         (setq p (cdr (assoc 10 (setq ptx (entget pt)))))
  13.         (setq lay (cdr (assoc 8 ptx)))
  14.         (setq p2 (vlax-curve-getclosestpointto curve p))
  15.         (entmake (list (cons 0 "POINT") (cons 10 p2) (cons 8 lay)))
  16.       )
  17.     )
  18.   )
  19.   (princ)
  20. )
  21.
« Last Edit: February 14, 2024, 04:15:31 PM by ribarm »
M.R. on Youtube
« Reply #10 on: February 14, 2024, 05:02:11 PM »
Hahaha .. had it mostly written 7 years ago :) .. thanks Marko.
*Edit .. I'd format like this these days so only only one selection set is needed:
  1. (defun c:foo (/ crvs p p2 pts ptx ss)
  4.   (cond ((setq ss (ssget (list '(0 . "POINT,LWPOLYLINE"))))
  5.          (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  6.            (if (= "POINT" (cdr (assoc 0 (entget e))))
  7.              (setq pts (cons e pts))
  8.              (setq crvs (cons e crvs))
  9.            )
  10.          )
  11.          (foreach pt pts
  12.            (foreach curve crvs
  13.              (setq p (cdr (assoc 10 (setq ptx (entget pt)))))
  15.              (entmake (list '(0 . "POINT") (cons 10 p2) (assoc 8 ptx)))
  16.            )
  17.          )
  18.         )
  19.   )
  20.   (princ)
  21. )
« Last Edit: February 14, 2024, 05:11:13 PM by ronjonp »
symoin
  • Mosquito
« Reply #11 on: February 20, 2024, 07:50:57 AM »
Thanks,
yes it is copying, can we keep the same elevations as the original point.
