Thanks for the note Tharwat.
It has me stumped.
The file is on the AutoCAD trusted path.
This only happens when the LSP file is modified and not saved.
When I get a chance I'll move the file location and see what happens.
The Project file is pretty simple.
;;; VLisp project file [V2.0] SD_MemberInfo saved to:[L:/Projects-VisualLisp-2017/SD210/SD_Memberinfo] at:[2/22/17]
:name
sd_memberinfo
("sd201_Library"
"sd_MemberInfo" "sd_MemberInfo_GUI"
"sd201_leaderandballoon" "sd201_leaderAndText"
"sd_Config" "sd_HoleData"
"sd_ItemData" "sd_3d_solidlayer"
"SD201_NUKE_XDATA"
:fas-directory
"L:\\Projects-VisualLisp-2017\\FAS"
:tmp-directory
"L:\\Projects-VisualLisp-2017\\TEMP"
:project-keys
(:build (:standard) :merged t :safe-mode t :msglevel 2)
:context-id
:autolisp
;;; EOF
