Author Topic: I need a blank Georefrenced file in CA83-VF  (Read 3012 times)
dubb
« on: September 05, 2017, 02:31:42 PM »
I don't have map3d or civil 3d. However if someone can create a Georeferenced map like the one attached but in a different coordinate system.
Instead of CA83-VIF I need CA83-VF.
What I hate about autocad's Geographic function is how they implement the marker position the true "0,0" position the marker position. Whereas the true "0,0" position should be somewhere in the pacific ocean.
Sorry I'm not sure how to explain this. The reason I use this is for inserting converted shape files into a georeferenced autocad dwg at "0,0" which should make things line up to the bing aerials with autocad's Geographic function.
2017 or older format please.
« Last Edit: September 05, 2017, 02:37:30 PM by dubb »
steve.carson
Re: I need a blank Georefrenced file in CA83-VF
« Reply #1 on: September 05, 2017, 02:56:55 PM »
Here you go. I agree I find it a pain to set the coordinate system in anything other than Civil3D.
dubb
« Reply #2 on: September 05, 2017, 03:27:33 PM »
Awesome! Thanks Steve!
dubb
« Reply #3 on: September 05, 2017, 03:28:26 PM »
How did you create this? Was it with C3D or M3D?
steve.carson
« Reply #4 on: September 05, 2017, 03:30:18 PM »
No problem. I used C3D.
