When you list both blocks, you'll notice a difference of the extrusion direction relative to UCS. The blocks are not on the same UCS.
Z=-1 means that you look at that block from behind.
You can fix this with the ALIGN command.
You'll need 3 points:
- end of arc > other end of arc
- corner 1 > opposite of corner 1
- other corner > opposite of other corner
