Author Topic: BricsCAD  (Read 2721 times)
GDF
BricsCAD
« on: September 03, 2017, 08:05:57 PM »
I have started using this CAD program, and I really like it so far.
How many users are there in the swamp?
MickD
Re: BricsCAD
« Reply #1 on: September 03, 2017, 09:34:50 PM »
Yo! :)
I use it for development these days and the user base is steadily growing here in Aus. The app store is getting better all the time and some of the better-known acad app's are being ported over as well.
The platinum version has sheet metal, architecture and a constraint based 3d modelling engine (think Inventor) built in, all these disciplines save to dwg!
It starts fast too!
J.R.R. Tolkien
roy_043
  • BricsCAD 18
Re: BricsCAD
« Reply #2 on: September 04, 2017, 10:31:50 AM »
+1
Note: BricsCAD Sheet Metal and BIM require separate licenses on top of a Platinum license.
Re: BricsCAD
« Reply #3 on: September 04, 2017, 02:36:08 PM »
I jumped from ACAD 2006 to BC16.
Like it so far, love the price, but I miss VLIDE.
So I still crank up ACAD for that.
GDF
Re: BricsCAD
« Reply #4 on: September 05, 2017, 12:28:37 PM »
I will also miss the .vlx files
roy_043
  • BricsCAD 18
Re: BricsCAD
« Reply #5 on: September 05, 2017, 02:38:32 PM »
Why? BricsCAD has DESCoder.exe that can encrypt LSP, DCL and TXT files into a single DES file. AFAIAA a DES file is very similar to a VLX file, although separate-namespace functionality is missing.
The Lisp Developer Support Package in the BricsCAD App Catalog may be of interest.
« Last Edit: September 05, 2017, 03:04:17 PM by roy_043 »
lamarn
Re: BricsCAD
« Reply #6 on: September 05, 2017, 05:44:59 PM »
things for DWG are happening ..
https://construction.cioreview.com/vendor/2017/bricsys
Autodesk  :knuppel2:
Design is something you should do with both hands. My 2d hand , my 3d hand ..
MatGrebe
  • Mosquito
Re: BricsCAD
« Reply #7 on: September 06, 2017, 02:39:37 AM »
How do you use vlx-files from others ? I think there is a reason to miss them...
Mathias
lamarn
Re: BricsCAD
« Reply #8 on: September 06, 2017, 11:58:59 AM »
Good question..
Or the other way around. How can one use .Des in AutoCAD
(..probable a simple answer to it, but it will remain food for thoughts..)
